Question about Fender Frontman 212R 100W 2x12 Guitar Combo Amplifier
Fender frontman 212r vault
My fender frontman began to smell of burning so i turned it off. when i turned it back on, it powered up & it amplifies the guitar but the noise is very feint & overly distorted & is very crackly cant see anything blown on circuit board could it be a speaker problem?
4 Suggested Answers
  • 57 Answers
SOURCE: i cant get good distortion out of my fender
Start with everything in the 12 o' clock position. Adjust one thing at a time until it sounds good to you.
Posted on Apr 24, 2010
rokrgyrl
  • 6 Answers
SOURCE: How can I fix the buzzing noise on my Fender Frontman 212R if I've identified the cables and guitar itself as not being the problem?
... do you, by any chance, have non humbucking pick ups on your guitar? Just curious...
Posted on Sep 14, 2012
swampelectro
  • 7 Answers
SOURCE: Fender Frontman 212R 100W 2x12 Guitar Combo Amplifier has a terrible hum whether it is on or off. Can I buy a tube amp head and plug into the Frontman speakers?
Probably it´s just the filtering caps with a bad solder. This noise if lack of filtering. If its the case, no parts needed, just work.
Unplug the amp, let it rest for a while to discharge the caps. Open the amp, and check if you don't have one of the big capacitors loose.
if you are not into electronics, ask someone to do it or go to a repair shop.
Posted on Jan 29, 2015
Fender Frontman 212R crackling noise
After ruling out guitar wiring or bad cables...
Try the 2nd input on the amp
also
Is it on both channels, or just one?
Nov 01, 2013 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Can i go straight out of the pre out on my fender frontman into a powered mixer pa system
yes,, Pre means before powered or amplified ,, so yes you can do this to a powered mixer, just be sure that the power is off before making any connections,, without the ground of the rca cable touching , the blast to the speakers can invert the cone !!
Aug 26, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
Hello! I was recently playing and found out then whenever I play specific notes on any of my guitars, my Fender Frontman 212R will buzz. The notes that always buzz are drop C, drop C#, any A note, and...
There is something resonating with that note frquency. Often the grille or wiring inside will rattle at certain frequencies. You need a sustained source of these frequencies to find what is causing the noise.
Aug 25, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
Will a MP3/iPod/CD player play through a Fender Frontman 65 or 212 "Power In" input jack?
The power amp input jack takes "line level" input BUT is monaural (single channel). The output of an ipod is Stereo. Hence you would have to "mix" the two channels before connecting to the Fender. Mixing does NOT mean just tying the two channels together. A minimu thing would be a passive resistive mixer consisting of a resistor from each of the IPOD channels to the common point going to the input of the Fender. Remember if you plug into the Fender power amp input you DISCONNECT the preamp and other circuits and would ONLY hear the IPOD input.
Feb 24, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
I have a Fender Frontman 212r amp. The problem seems to be when I put the volume upto past 4/10 [40%] The amp gives out an awful crackling sound and power light etc flickers on and off. I have had the map...
When i turn on my 212R it turns on in drive channel. if footswith is plugged in, then it turns on in the clean channel, but after switching in drive it is impossible to switch it back in clean channel. What could be wrong? Swith position doesnt change anything and it seems like switch is OK.
Nov 27, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
I cant get good distortion out of my fender frontman 212R can sombody help me with the settings
Apr 23, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
Open Questions:
See all Fender Frontman 212R 100W 2x12 Guitar Combo Questions
Fender Frontman 212R 100W 2x12 Guitar Combo Amplifier Logo
55 people viewed this question
Top Fender Music Experts
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
