Question about Fuji Finepix S9600 Digital Camera
I'm unable to get a clear image on either the rear viewer or through the viewfinder when using my Finepix S 9600 on any setting, though the downloaded image seems fine.The sensors appear to be cle
    Sergeant:
  • 321 Answers
Use bulb mode do not release the click button , clean with white cottton cloths
Posted on Jan 10, 2013
cammedic
  • 667 Answers
SOURCE: finepix viewer
I have searched over time, I never have found that software for free on the net. You can get a CD off eBay for a few bucks
Posted on Mar 03, 2008
SOURCE: Finepix viewer
I had to click on the register button and register my camera for all the features to start functioning. This may be all you need to do.
Posted on Nov 01, 2008
SOURCE: I/O Error process aborted when opening finepix viewer to download
I had same problem...Deleted Finepix software and used windows media player automatic plug and play...better program and uses less hard drive space :) (im running Vista Ultimate)
Posted on Dec 17, 2008
SOURCE: i/o error occurred. Process aborted pops up
i had the same problem, whenever i connected my camera with a USB it would say "I/O error occured. process aborted."
what worked for me was taking out the memory card and directly inserting it into the computer rather than connecting via a USB cord. hope this helps!
also, the technical support at fujifilm were of no help.
Posted on Dec 29, 2009
  • 275 Answers
SOURCE: FUJIFILM FINEPIX S5000.No image on viewfinder or LCD.
I think there is a small button on the back of the camera near the bottom that turns the viewfinder off and on I think. It should be in the manual.
It might have gotten bumped while in the bag.
Posted on May 24, 2010
The software cd that came with my finepix S2900 camera will not load on any mac computer. What do I do?
The CD only has the FinePix Image Viewing software. As far as I know, tt's not needed to transfer the images from the camera to your computer, the camera's image folder should be browseable from any file utility. You can use any image viewing software you want.
You can d/l the Fuji Image Viewer software here:
http://www.fujifilm.com/support/digital_cameras/software/viewer/
Pick the version that matches your setup.
Nov 05, 2017 | FUJIFILM S2940 Digital Camera
After downloading photos, instead of them opening in Finepix viewer screen (to allow me to rotate & crop etc) I keep getting a 'Finepix Viewer - Desktop' screen. This does not show the pictures...
Hi pamelaknott3,
In this case you would have to check the autorun settings in your finepix viewer sofware , there may be a setting which would indicate autorun or autostart for the finepix viewer desktop application , once you discover it , you would have to disable it, if not then please try uninstalling the finepix software and then reinstalling it so that it loads the default settings that was ok for you earlier.
Hope this helps ..:)
If you have any further queries, just get back to me and I would love to help you out.
Jun 20, 2011 | Cameras
May 24, 2010 | Fuji Cameras
Software problems(?) with a digital camera.
You could try right clicking on finepix viewer and go properties. On the compatibility tab tick the box in "run this program for..." and select xp then go apply and ok and then try it. It might just be a compatibility issue
Jan 17, 2009 | Computers & Internet
Fuji j10 - my mac wont recognise it even using finepix
I had the same problem with my camera & mac.  I got this off the Fuji site and it worked for me:
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
Sep 09, 2008 | Fuji FinePix J10 Digital Camera
What do i do
2) Resolving the problem
1. Plug the USB cable into the camera and Macintosh again.
* If you are using a USB hub, do not connect the camera to the Macintosh via the hub.
1. Select "Other".
2. Click the "Applications" folder.
3. Click the "FinePix Viewer" folder.
4. Select "FPVBridge" and click "Open".
5. Click [OK].
1. Launch FinePix Viewer.
2. Select "Automatic Save Settings" in the Settings menu.
3. Tick the "Auto save images when the camera is connected" checkbox in "Operation Settings When Camera Is Connected".
4. Click [OK] and close the "Automatic Save Settings" window.
5. Exit FinePix Viewer.
6. Turn the camera off and then on again to test whether FinePix Viewer launches automatically.
Apr 28, 2008 | Fuji FinePix S5700 Digital Camera
Not recognizing my camera
Check your Mac OS X version number then go to the website below to download appropriate updater for your finepix viewer program.
Mar 31, 2008 | Fuji FinePix A345 Digital Camera
Downloading photos from new F40fd
!, There is no need for Software supplied with ANY camera to be installed- t is best left in the box.
Windows will detect and camera a put uo the Scanner/Camera Wizard from whence you can direct images to exazctly where you want them.
So remove any software- none required..
All images are stored by default in My Document/My pictures or [and check this before you delete any software]
My Computer/'C'/Programs/FinePix to check.
Mar 03, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Viewfinder focus
Mickykay,
Have you tried focusing the diopter? The focus wheel is just left of the viewer. If you know all this then consider one more thing. There is a plus and minus setting for your eye so roll the wheel slowly to not miss the sweet spot for your vision. goodeye
Jan 13, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Finepix s9500
you haven't knocked the dioptre adjustment wheel onto a different setting by mistake by any chance? it's to the left of the viewfinder
Sep 22, 2007 | Sakar (FJ2XCH) for Fuji Finepix S9000,...
Fuji Finepix S9600 Digital Camera Logo
65 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
