Question about HP LaserJet 4050tn Printer
Hp laserjet 4050tn error 79.4165
Error code 79.4165
Every time I try to print I am finding it starts off fine and about half way through the page it stops with the error 79.4165. I remove the two pieces of paper and re start and it says ready again only to repeat the same problem. I was wondering if anyone can suggest what to do.
Thanks,
Jacqueline
Posted on Jan 28, 2013
5 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: HP Laserjet 4050Tn can't be found by network computers (XP)
To install the HP as a network printer you need to do the following -
1. Configure the HP's IP address so it matches the IP range of your network. eg if your IP's are 192.168.0.xxx then set the HP to a high number say 100.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer to the network hub/router and power up the printer.
4. Click on Printers an Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standart TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's IP address.
8. Click OK and tick Enable bidirectional support and then OK
You need to setup the HP printer the same way on every computer on your network.
You can now print from any computer on your network
Posted on Sep 03, 2009
SOURCE: Unable to reinstall my HP Laserjet 4050tn after upgrade to Leopar
Finally, reconnected with the printer after trying different driver downloads, deleting everything, changing different options on the printer installation...
Posted on Dec 01, 2008
sys_admin
  • 829 Answers
SOURCE: 52 scanner error on HP Color Laserjet 2840
The device has experienced an internal hardware error. Recommended Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
Posted on Mar 22, 2009
atsonev
  • 39 Answers
SOURCE: I have a HP WINDOWS
You need to connect the printer with a cable to the wireless router. Then you must enter the printer menu and set an IP address, subnet mask and gateway corresponding to your NAT network or switch the DHCP option on (e.g. to get them automatically from the router). I suggest you to enter them manually if you are not going to switch the printer every day. Then in Windows 7 you must go to devices and printers, select Add printer, select local prinet and choose TCP/IP port from the list. After clicking next you will be asked for the IP address of the printer, you fill the one you entered in the device menu. Next you will be asked for the printer model and you must select it from the list or show a location with the driver. Click finish and a test page will be printed. Hope this helps. Alex
Posted on Sep 13, 2011
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
    Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Error code message
    What Does Your Treadmill's Error Code Mean? - LifeSpan
    www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
    Free
    May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
    [PDF]ERROR CODES: ADDITIONAL ERROR CODES:
    www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
    ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
    [PDF]Error Code Troubleshooting Guide
    Jan 19, 2016 | Exercise & Fitness
    Error code AC-6
    ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION ...ERROR 1-2: AC SERVO ERROR - MOTOR IS OVERHEATING (SPEED RESTRICTED ... error codes listed by category: treadmills, bikes, elliptical trainers.
    [PDF]Precor Error Codes
    The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
    LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
    Select
    Use our model number finder
    Choose your product type
    Common model number plates
    Close
    LG Refrigerator Error Codes
    These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
    Er FS Error Code
    Er rS Error Code
    F dS Error Code
    r dS Error Code
    Er HS Error Code
    Er IS Error Code
    Er SS Error Code
    Er rt Error Code
    Er It Error Code
    Er gF Error Code Error Code
    r dH Error Code
    Er IF Error Code
    Er FF Error Code
    Er CF Condition
    Condenser fan motor is defective Check/Repair
    Condenser fan motor, wiring or the control board Shop Parts
    Condenser fan motor, Power control board, Wiring harness Error Code
    Er CO Condition
    Communication error Check/Repair
    Communication error between main board and display board Shop Parts
    Display control board, Power control board, Wiring harness
    Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
    How to resolve erreur code E000051-0000 whith canon ir 2800
    the Canon E500 printer is one of the most advanced printer which is build upon the latest printing technology. The printer comes in medium-size device and is reasonably light weight of around 5.3 kg. The black plastic body has no sharp edges, and the design is fairly pleasant to appear. The trays of the Canon printer Pixma E500 are quite flexible to use according to Canon Pixma E500 Printer Supportprofessionals. Its glossy finished touched feature makes the printer most eye-striking among users. But here in this blog, we will be introducing you guys with various Canon Pixma E500 error codes that you need to know.
    List of top Canon Pixma error E500 codes
    Error code 1: Canon E500 Error Code E02 (E,0,2)
    • This error symbolizes that printer is out of paper or is incapable of feeding any document.
    Error code 2: Canon E500 Error Code E03 (E,0,3)
    • This error signifies the Paper Jam.
    Error code 3: Canon E500 Error Code E04 (E,0,4)
    • The error signifies that the "fine cartridge" is not installed accurately.
    Error code 4: Canon E500 Error Code E06 (E,0,6)
    • As stated by Canon Pixma E500 Printer Technical Support experts, the paper output cover is not in a closed state.
    Error code 5: Canon E500 Error Code E07 (E,0,7)
    • The ink absorber is complete and users need to reset the counter.
    Error code 6: Canon E500 Error Code E08 (E,0,8)
    • Here the error signifies that the ink absorber is almost in a full stage. Users are then required to press the "black or color" button to resume it in a proper.
    Error code 7: Canon E500 Error Code E16 (E,1,6)
    • The ink in completely finished as of now. You are required to tap on the "Stop/Reset" button to resume the printing process.
    Error code 8: Canon E500 Error Code E17 (E,1,7)
    • The front tray is totally closed.
    Error code 9: Canon E500 Error Code E30 (E,3,0)
    • The error code defines that the size of the original cannot be accurately detected or even it is possible that the document is too small when the "Fit-to-Page copying" is selected.
    Error code 10: Canon E500 Error Code E31 (E,3,1)
    • The machine is surely disconnected with the computer.
    Error code11: Canon E500 Error Code E40 (E,4,0)
    • It shows that the protective material of the Canon Pixma E500 printer for the FINE cartridge or the tape is still attached.
    Error code 12: Canon E500 Error Code E50 (E,5,0)
    • Scanning of the print-head alignment sheet has failed to function
    Error code 13: Canon E500 Error Code P02 (P,0,2).
    • This is a critical error which shows that the printer is in malfunctioning stage.
    Error code 14: Canon E500 Error Code P10 (P,1,0).
    • This error signifies that the mechanical printer is in total malfunction stage.
    So, these are few topmost errors of Canon Pixma E500 printer that users need to be aware of. Our professional team of Canon Pixma E500 Printer Support experts is always available for you to help overcome with any kind of unexpected issues. Call us or even you may drop us an email to our professional email ID.
    May 16, 2015 | Canon IR-2800 Copier Reconditioned
    Erorr code 4003 zebra zxb8
    Error Code 4001
    System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
    Error Code 4002
    System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
    Error Code 4003
    System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
    Error Code 4004
    System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
    Error Code 4005
    System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
    Error Code 4006
    System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
    System Error Codes
    Sep 15, 2013 | Zebra ZXP Series 8 Thermal Card Printer
    Open Questions:
    HP LaserJet 4050tn Printer Logo
    76 people viewed this question
    Seeker5211
    Seeker5211
