Question about Schwinn 220 Recumbent Exercise Bike - 2012 Model
I unplug my Schwinn 220P to move it and now the computer will not activate after plugging in the electrical.
    Top Expert:
  • 14,161 Answers
1 (800) 626-2811
Schwinn Bicycle Company, Customer service
Posted on Jun 08, 2015
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: schwinn 220P no resistance
see this steps and fix it. God bless you
  • 1
    Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
  • 2
    Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
  • 3
    Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
  • 4
    Check the hand bars. While not all people use them, as they can elevate your heart rate by up to 20 percent, they can become worn, too. While loose hand bars typically need a simple tightening of the bolt, be sure not to overtighten as the bolts can break.
  • 5
    Know that if the axis is bent, it's likely you need a new machine. The axis is the central alignment of the elliptical. If the machine was used by a person who is over the maximum weight limit, it can be bent or damaged. It's not an easy fix and a better idea is to upgrade to a sturdier machine.
  • Posted on Nov 23, 2012
    Owners manual for schwinn 220P recumbent bike
    This link will take you to the owner's/service manual for the 220P
    http://www.sportsmith.net/images/product_support%5Cschwinn%5Cservice_manuals%5C220%20electronic%20trouble%20shooting.pdf
    Mar 29, 2015 | Schwinn Cycling
    Is it possible to get hold of a manual for a York Cardiofit 210p Fitness Platinum Series #8570, Exercise bike. Thanks
    York Fitness manuals are available at:
    http://www.yorkfitness.com/store/IIT_Instructions.asp
    The 210p is a discontinued model, replaced by the 220p. Not much changed between the 210p and the 220p. The manual for the 220p would likely suffice.
    Hope this helps.
    Apr 27, 2011 | Cycling
    My schwinn 240 recumbent bike shows E-3 on console. the magnet is stuck to the flywheel and won't come off. i've tried adjusting the resistance on the console, unplugged the brake sensor cable, etc. how...
    Hello, do you have a manual or electric resistance control? The manual one has a return spring, the electric on has a resistance motor that could be bad.
    Feb 05, 2011 | Schwinn Exercise & Fitness
    Cannot adjust the tension on Schwinn 202. Computer is on but tension will not move up or down
    I have the same problem with a schwinn 202 that someone gave to me because the resistance adjustment no longer worked. They were advised by Schwinn that the motor needed replacement, but after testing mine, the problem seems to be a lack of power from the computer to the motor. Schwinn tech support will get a call from me tomorrow.
    Nov 21, 2010 | Schwinn Cycling
    Install battery
    First make sure the scooter is off.
    Unscrew and take off the deck
    Unplug and remove the old battery pack
    Put the new battery pack in and plug it in, using the same connection as the old batteries pack.
    Screw the deck on and your done!
    Oh, and make sure you give the battery a good charge(the full charging time). The first charge of a battery is the most important one.
    May 16, 2010 | Mongoose Currie Schwinn Gt Izip Scooters
    Where can I download a copy of a Schwinn 220P operators manual?
    After some research, I have not been able to find a manual that can be downloaded. This is probably due to the fact that it is relatively large in size. Some manufacturers simply dop not digitize their larger manuals. You may be able to find someone who has done the work for you - but that may take some time. If you wish to buy it, here is one place: http://www.fitnessrepairparts.com/cart/ViewItem/13000747
    As you may already know (which is probably why you are here), Schwinn does not have it in their download section for stationary bikes, which is here:
    http://www.schwinnfitness.com/schwinn-fitness/customerservice/manuals.jsp?lid=Owners+Manuals+-+Manuals
    but you may wish to try model numbers close to the 220p and the information may basically be the same.
    Please be advised, this is free-of-charge information and opinion I am providing you. Please do not give me a low rating for simply trying to help. I may not have given you an answer you like, but it is an honest one, and one based on research. Thank you.
    Jul 05, 2009 | Schwinn Cycling
    Schwinn s-400 scooter no motor activity.
    I had same issue, bought a new controller. 40 bucks from the manufacturer. Works great.
    Jul 20, 2008 | Transport Schwinn Rechargeable Portable ...
    Schwinn 220 Recumbent Exercise Bike - 2012 Model Logo
    183 people viewed this question
    Top Schwinn Exercise & Fitness Experts
    David Payne
    David Payne
    Matt Olenzek
    Matt Olenzek
    Bill Boyd
    Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
