Question about Coby MPC-848 MP3 Player
Battery location on mp3
Where in the world is the battery compartment on this mp3? :(
  • 432 Answers
Remove the USB cap. On the back side, Slide open the battery cover towards the USB end. Insert the AAA battery. Make sure to match the + and - ends of the battery. http://cobyusa.com/manuals/MPC848.pdf
Posted on Jul 02, 2007
  • Raymond Scott
    Raymond Scott Jul 02, 2007
    This valid on all #MPC-848 USB MP3 Players.
SOURCE:
Wr100m. What is battery type?
for safety fuses are always located in the fuse box or compartment . thanks .
Mar 02, 2016 | Casio Watches
Find the cmoss battery d505
Unplug the Dell Latitude D505 laptop from AC power. Turn over the so that the base of the computer faces upward. Locate the battery panel on the bottom of the computer and then press the latch on the battery panel in the direction of the arrow on the latch. Lift the battery from the battery compartment.
Press on the latch located toward the front of the computer inside the battery compartment. Pull the cover that is released out and down and remove the cover from the battery compartment.
Grasp the small battery in the slot uncovered when the cover was removed and pull the battery away from the slot to detach the battery from the laptop
Dec 12, 2011 | Dell Latitude D505 Notebook
How to change the battery ? where is it ? MP3 SMPK2312
Your MP3 Player has a Lithium Polymer battery that powers your device. I don't know if there's a battery compartment you can take off to change your battery, but I'm pretty sure there's a battery compartment either on the side or the back of your device. I can explain to you how to recharge your battery, but I don't know if these directions apply to your device, as this solution is the best possible solution I can give you. To recharge your battery, you need to make sure that the ON/OFF switch is switched to ON. If you have a charger, connect the smaller end to the MP3 Player and the larger end to a wall or surge protector outlet. A light beside the ON/OFF switch should turn on. Another light next to the earphone terminal (port or socket, however you want to call it) should light up too. This indicates the charging status, as this light will go off when charging is finish. I hope this solution helps and my instructions are related to your product's model number.
Mar 21, 2011 | Sylvania SMPK2312 (2 GB) MP3 Player
I bought my wife Conair massaging slippers model VSW32. There was no instruction manual. I need to how to install the batteries. Can you help
Underneath the pink inside sole is a box for the battery. Pop the plastic cover with a small screwdriver. Install 1 "AAA" battery in each slipper and replace plastic cover. The button to turn the massage off and on is on the side of each slipper on the outer sole.
Dec 25, 2010 | Clothing Accessories
My mp3 dosent want to turn on and its charged
First try and reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 30, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
Charging mp3 player
If your MP3 has an inbuilt Li-Ion battery (e.g. no compartment for a standard/Ni-MH AAA battery), then connecting the player to your computer will normally charge it - this is the case for the PD-6070 'stick' player. Your player will also indicate that it is being charged (or not charged!) via the battery level/power indicator which is located on the top RHS.
Hope it helps!
Dec 19, 2009 | MyMusix PD-6070 MP3 Player
Cant find battery compartment
there are integrated batteries in mp3 players.
take it to a engineer to fix it
sagar
Jul 29, 2009 | Audio Players & Recorders
New world gas cooker (apex hl 500)
the battery compartment is located right at the bottom of the cooker on the front, slightly to the left. It's a little compartment that houses a aa battery. it's unclips on the right hand side. hope this helps
Jan 31, 2009 | New World 50HLG Gas Kitchen Range
I cannot charge the battery of my MP3 Sansa C200 that I bought last March 2008. What should I do?
Thank you for your quick response.
I solved my problem.
After spending half of my Sunday afternoon trying to charge the battery, I opened the battery
compartment to check the number etc.
I re-inserted the battery carefully, closed the compartement, and connected my MP3 to my
computer ( for fun...) and it worked ! !
I appreciate your interest in my predicament.
Thanks again !
dmduch
Dec 07, 2008 | SanDisk Audio Players & Recorders
Where is the serial number located?
try checking inside the battery compartment.
Jun 12, 2007 | SanDisk Sansa e270 MP3 Player
Coby MPC-848 MP3 Player Logo
50 people viewed this question
Top Coby Audio Players & Recorders Experts
Ekse
Joe Negus
Joe Negus
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
