Question about Kyocera Copystar CS-5035 Copier
Our Copystar CS-5035 Copier is not sending the copies to the finisher, instead they are coming out in the middle of the copier.
Instead of the copies stacking in the finisher they are coming out in the middle of the copier.
  • Kyocera Expert
  • 337 Answers
Press the * key and select Machine Defaults. Key in 6482, and scroll down to Select Copy Output Mode and press the Change # key. Select the desired output location.
If 6482 doesn't work use 5000
Posted on Jan 30, 2013
  • 66 Answers
SOURCE: Copystar cd-2550 copier , drum replacment print problems
hi
the drum unit on this model has two plugs which need to be plugged in and one on the dev unit that can come loose.
also the metal mechanism under the dev unit has to be pushed in to enable toner to get onto the drum.
is the transfer roller fitted correctly?
Posted on Apr 23, 2009
goalie39
  • 469 Answers
SOURCE: Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Posted on Apr 28, 2009
  • 523 Answers
SOURCE: Installed upper & Lower Fuser, Turn Copier on saying paper jam 03
its not really a jam, its the cover you have to play with it on order to lock well.
Posted on Jun 14, 2009
  • 5 Answers
SOURCE: setting up a copier to use
hi if enter simulation 1087 1087 and select 000 inmidiatly appear d-l and press enter
after to out do you enter with arrow up and down the number 1 in the display and press enter
Posted on Jun 22, 2009
M2Tech1
  • 313 Answers
SOURCE: My Kyocera Copystar CS-2114 Copier is printing a
have a look at the scanner glass especially the thin strip glass this is the glass that is used when passing paper through the document feeder. if you do a copy from the main glass or print to it and no line apears there is probably dirt or tipex or a ink mark on the surfac, the other thing to look at os the drum charge unit as htese can sometimes fail to connesect correctly at the back and not sit tight in the slot this means the drum isnt charged on the edge.. good luck
Posted on Nov 17, 2009
How do I connect my computer to a Copystar CS-5035 Copier/printer? It does not appear to be a regular USB connection in the back. The specs for CS-5035 read Parallel IEEE 1284 or High Speed USB 2.0.
All 2.0and 3.0 Will work just fine . there should be a cable supplied with the copier . With a fitting to fit the copier at one end a USB fitting at the other end to fit the computer .
Sep 16, 2014 | Office Equipment & Supplies
I have a knoncera 5035 copier for classroom use (my own) Copies got very light & I replaced the toner (INK) but the copiers are still very light. It is not hooked up to print to just copy what do I do...
There are a few things to check
Is your paper fresh
Open the left hand side and check the transfer roller sometimes people break the retainers and loose the springs etcwhile removing paper jams
Oct 28, 2013 | Kyocera Copystar CS-5035 Copier
Kyocera CS-C2525 won't scan
Do you have the option installed on you copier??? Also, there is another ether connector for scanning. If it is installed it is right above the print PCB.
May 22, 2012 | Kyocera Copystar CS-5035 Copier
Download printer driver for cs 5035
go to www.copystar.co,
look under download, choose legacy black and white copiers MFP
the under the subcategory select print driver, choose the KX driver thats support your windows version, then run it and you good to go. let me know!
Nov 23, 2011 | Kyocera Copystar CS-5035 Copier
Copystar 5035 lite copies
Lite copies caused by developer unit, try to run mode 130 which will add toner to your developer, or try change the density of the copier, if non works, this means you have to change the developer unit.
Nov 04, 2011 | Kyocera Copystar CS-5035 Copier
Copies and prints all black
Sounds like you may not have the main corona pushed fully home or you cleaned the grid with the grid cleaner that comes with the toner cartridge.When cleaning the grid you must leave the corona unit protruding out of the copier for 30 seconds to allow the grid to dry.Failure to do so can cause arcing in the machine that will give you black copies.reclean the grid and allow to dry before re-inserting
Aug 09, 2010 | Kyocera Copystar CS-5035 Copier
Ii need to change the number of rings before the fax machine answers on my Copystar CS 5035. How do I do this.
touch the menu button, go to fax default, key in code 6482 and then scroll settings and change the the number of rings
Aug 06, 2010 | Kyocera Copystar CS-5035 Copier
I am just trying to find the driver for a Copystart CS-5035. I cannot find anything on the Kyocera web site.
www.copystar.com go to downloads. select legacy/mfp copiers. then select your model then under technical resources select drivers
Aug 03, 2010 | Kyocera Copystar CS-5035 Copier
Kyocera Copystar CS-5035 Copier Logo
77 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
