Question about APC Smart-UPS SC 1500VA UPS System
Changed out batteries on my APC SC 1500 UPS beeping won't go away.
  • 55 Answers
SOURCE: APC Smart UPS 1500 will not start.
It could be that the cable to the front-panel got damaged during the battery replacement.  After all these years you would think APC would improve that aspect of their design.  All I can suggest is inspecting the cable and where it connects to the front panel.
Posted on Apr 26, 2009
SOURCE: smart ups 1500 apc making loud noise
tighten the screwa on the body
Posted on Jun 10, 2009
  • 25 Answers
SOURCE: APC BR800 Overload light with beeps
Your main control board is defective, you need a new unit.
Posted on Jul 11, 2009
jvpacoin
  • 91 Answers
SOURCE: Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
Posted on Aug 14, 2009
SOURCE: APC Back UPS RS-1000 Overload LED with beeping sound after on.
in the end solution is you have to bring it nearest apc service.
if you loaded more than its max. capacity at past, the sensor of power is geting burn the sequare wave generator IC.
so you need help with that, olso complicated.
I live the same position with my rs1000, horrible :((
Posted on Jan 09, 2010
Install instruction for ups sc 1500
Hi Can you provide more info about this one?
Aug 28, 2014 | APC Computers & Internet
APC RS 1500 82v output
Many UPS Systems have a squared wave when working on batteries. Cheap multimeters do not give the correct measure on squared waves. Connect a 100 watts resistive lamp to the output of the UPS, if the light is almost the same when UPS is working on batteries, everythinf is fine.
Dec 23, 2013 | APC BX 1500 Back-UPS XS 1500 (APNBX1500)...
Why does my APC Conext UPS beep after power is restored?
After about 2 to 3 years the batteries usually have to be replaced. I found with our UPS's we get about 3 years maximum from the batteries. Ordering the originals from APC is rather expensive.
Locate a professional battery distributor in your area. Get the part numbers written on the batteries in your UPS, and including the detailed descriptions. You can then order these from the distributor. APC uses industry standard batteries. We found the Panasonic and Portilac brands to be excellent.
APC manufactures the UPS's. They use various battery manufactures depending on bid costing.
Jerry G.
Jun 29, 2012 | APC Conext UPS System
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
Beeping
These UPS systems do a self check everytime you press the power button. If the voltage in the battery is too low, you'll get a long drawn out beep. A new battery should solve that problem and it is even economical with a unit this size. Here's a link: http://batteryinternational.com/apc-backups-es-be350es-ups-battery-ups-batteries-f1.html
Simply remove the single phillips screw on the bottom of the unit and remove the battery cover. Replace battery and that's it. Very simple to do.
Apr 14, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Apr 18, 2009 | APC Smart-UPS 1000VA UPS System
APC Smart-UPS SC 1500VA UPS System Logo
102 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
