Question about Canon MultiPASS MP730 All-In-One InkJet Printer
My canon multipass 730 indicates wrong cartridge
Although I have been using the cartridges for some time, all of sudden "wrong cartridge" came out and cannot print at all.
  • 5 more comments
  • Anonymous Jan 23, 2009
    Yes I have the same roblem with my Canon multipass MP730. I read & tried the problem solving of removing the cartridge and cleaning and drying with paper towel but this did not solve it?????
  • Anonymous Jan 31, 2009
    I changed ink cartridges and it still says wrong cartridge.
  • sng94 Jan 31, 2009
    I put all new cartrdges in and it still says wrong cartridges
  • jakeslin Feb 01, 2009
    I have the same problem
  • ddelauder Feb 01, 2009
    There are NO copper plates on the cartrdige
    The cartridges are made totally of plastic
  • Anonymous Feb 02, 2009
    it didnt help
  • grmerkle Feb 05, 2009
    Same problem. Installed new cartridges and got the same message
  • 684 Answers
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer.................. Now turn on the Printer and chk......... Good Luck
Posted on Jan 21, 2009
My alarm beeping wrong cartridge and not doing anything
stavio sam nove ketride u cano mp 730 i dalje lampa treperi. sta treba da radim.
Feb 12, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Mp 730 "Wrong Cartridge" have been using same cartridge w/o any problems
the cartrige has become faulty or the wire strip that connects to the cartrige holder is comming out or a wire in the strip is broke , a new cartrige would then do the same thing
Oct 18, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
My Canon i850 printer has stopped responding to a
The Canon i850 uses cartridges of type BCI-3. according to Canon, the color cartridges are compatible to:
BJC-3000 Series, BJC 6000, i450, i550, i850 Series, MultiPASS F30, F50, F60, F80, MP 700 and MP 730, S400, S450, S500, S520, S530D, S600, S630, S630 Network and S750.
The black one will work in a few more models.
Feb 07, 2010 | Canon i850 InkJet Photo Printer
My canon mp 730 has an alarm lit and says wrong cartridge. I tried removing print head and cleaning with alcohol...no luck...put in a different cartridge...no luck. What else can I do
On Canon that error means the printhead is bad, nothing to do with the inks. The translation from Japanese to English made the error confusing. You need to buy a new printhead, the part number is on the side of the printhead and starts with QY6-
Jan 31, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MP700 - Wrong Cartridge
Hello !
Many cartridges now have expiration date chips built into them. So, since you mentioned that the cartridges are "old", they may have expired. Check the date.
Hope this helps.
Oct 24, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
I have a canon multipass 730. It will not work and
Wrong cartridge means that the printhead is bad. Don't take it apart yet, you need a printhead.
QY6-0064-000 about $60.00
Sep 24, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
MP 730 Printer alert flashing "wrong cartridge"
I had the same problem. I removed the cartridges and then the printerhead. I cleaned the printerhead with a piece of cloth and then replaced it and then the cartridges. This seems to have fixed the "wrong cartridge" problem for now. I was told by a friend that if the problem persits, replacing the printerhead may be a more permanent solution, but no guarantee.
Mar 05, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
MP 730 Show Wrong Cartridge in the display window.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=9035
I went to canon and found the solution. It took a couple attempts, but it finally worked and I am up and running again. Under 10 minutes.
Nov 20, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
99 people viewed this question
old marine
old marine
