Question about D-Link DCS-3220 Network Camera
Can't see image on my new conputar window 7 using firefox from DCS-3220 D-Link Camera
D-Link DCS-932 Camera - Java Error viewing remotely
Unfortunately due to the limitation created by DLink you cannot set up your camera's Motion Detection feature through the MyDlink Application. (I suspect you are going to myDlink and trying the advanced setttings)
Instead you have to access through your internal netwok. Try access the devices webpage by going to windows explorer (my computer) and select the network drop down in the left hand window to display your network devices, Find which camera your wanting to set motion detection and double click it to connect to the devices webpage, same user/pw you used before, except this time it will display the main image under Java and also the motion detection grid
Jun 08, 2012 | D-Link Dcs-932 Wireless N Day And Night...
Hi!! How can I change IP address on DCS-3220 security camera?
DCS-3220 is fixed IP security camera !!
can't change its ip !!!
Jun 14, 2011 | D-Link DCS-3220 Network Camera
How to set up for email alerts
hi...
please follow the instructions.
1.install the IP surveillance
2.Go to 'my network places'
start---->control panel---->my network places
3.You will see your device
4.Double click it you wil get a window like this...
5.Click on the configration button.
6.you wil get this page...
7.please select 'Advanced'(this is on the top)-------->Network(this on the left hand side)
8.In this page you have an option called as'1st recipient email adress'.please enter your adress and click on 'apply'
Now you can recieve the video clips. thanx
Jul 15, 2010 | D-Link DCS-3220 Network Camera
I have a D-link DCS-3220 and it will not work in firefox. Is there a solution?
No there's not. The camera's video stream can only be viewed in Internet Explorer 6 or higher.
Jul 13, 2010 | D-Link DCS-3220 Network Camera
What is the default ip address of D-Link DCS-3220 ip cam ?
Hello
The D-Link DCS-3220 have DHCP, that means it gets a automatic address from your router.
IT doesent have a STATIC ip, if you not set it manually.
To configure your D-Link DCS-3220 CAM and find the IP you need to install this program.
Install Wizard You need to unpack it first.
Connect your computer and cam to same router and run the program. Then it should find your cam so you can configure it and see what ip it get your you set.
Then you can browser to the cams IP.
Here is the manual and instruktions for you CAM
Here is Quick install guide
Here is you Dlink cam site to get firmware updates and more.
Hope it works.
Jul 09, 2009 | D-Link DCS-3220 Network Camera
Is it possible to record the streaming video on DCS-3220 ? and if yes how to configured the streaming server ip ?
I had a similar issue trying to feed a live stream to the web with a dcs 3220, I found that I had to use this IP configuration; Ip address is XXX.XXX.X.X/cgi-bin/video.jpg then use "jpg pull" from the web server. Hope this helps you let me know http://troyster.com
Jan 26, 2009 | D-Link DCS-3220 Network Camera
DCS 3220 : storing snapshot to ftp server
Sorry I have followup question before I can help you....
Are you trying to take snapshots using the button on the main screen when looking at it on the web page screen in IE or are you talking about hitting the snapshot button (looks like a tiny camera) in IP surveillence?
Apr 18, 2008 | D-Link DCS-3220 Network Camera
D-Link DCS-3220 Network Camera Logo
77 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
