Question about Health & Beauty
Shuttle scooter will not move forward or reverse
Had control module repaired and new batteries (fully charged) but only tries to move, does not move forward or reverse?
  • 118 Answers
SOURCE: New batteries, fully charged, still wont work
I have the book if you can figure a way to post you email without getting too much SPAM. Be sure the charger is un-plugged, and that the free wheel lever is engaged.
Posted on Nov 27, 2008
  • 32 Answers
SOURCE: no movement, forward or reverse
sounds like it is in neutral, look for a lever on the bottom, rear of the scooter to pull up
Posted on May 07, 2009
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
  • 13 Answers
SOURCE: golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
Posted on Jun 18, 2009
  • 175 Answers
SOURCE: The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Posted on Jul 12, 2009
Battery in 610 4x4 mule not maintaining charge. Fully charged battery placed in mule will stay charged for about a week.
I recently tried
the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. it wont move forward or reverse, engine is good both solenoids for forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.comAll the best
Mar 23, 2018 | Cars & Trucks
I have a victory pride mobility scooter the battery is fully charged and it won't run I tried to reset but nothing worked
Have the controller module checked. You can also download the service manual from Pride's website. It has a lot of information in it as well as a complete wiring diagram.
May 21, 2014 | Pride New Mobility Legend 4 Wheel Scooter
Can you help me try to figure out why my scooter will not move forward or backward? It is fully charged and the horn works.
I would get the batteries checked for power. Just because your charger shows fully charged quite often the batteries are low but enough power for lights or horn which does not take much power. i suspect bad batteries.
Apr 13, 2014 | Ctm Health & Beauty
GoGo Elite 4 wheel scooter - appears to be fully charged but when you try to go forward it goes a foot then stops. I get 2 beeps. It will go in reverse with no problem. If I am not sitting in it you can...
How old is the scooter? 2 Bleeps indicates low battery voltage, and such, require replacement. When you are in reverse, the current draw is a lot less than when going forward, just like not being sat on the scooter too. As soon as any real load is applied to the scooter, the power will drop down below 16v and will cause a controller trip (2 bleeps)
However, this could also be caused by bad battery connections, either inside the battery box, or where the contacts meet on the bottom of the pack - onto the chassis. Check for discoloured pins / connections.
Sep 23, 2013 | Pride Health & Beauty
Same problem
If your batteries have ever gone dead, they can show fully charged, then completly discharge very rapidly. Take them to autozone and ask for a "load test". If they don't hold a load, replacement is nessary. smithrm70@hotmail.com for more if the batteries pass load test
Oct 06, 2009 | Pride Celebrity Xl 4 Wheel Scooter
When I switch my mobility scooter on lights etc all work but no drive
hi, I first suggust you make sure that Freewheel is disengaged,
to test this try to push the scooter forward if it moves forward move the lever ,
Check the Wigwam or throttle controls to make sure they are not loose,
Check for reset switches under the seat or on the steering stem,
Check for car type fuses under the seat.
Jul 23, 2009 | Pride Victory 4 Wheel Mid-Size Electric...
Have Zoom 220 HMV 3 wheel scooter. Charged battery in house socket. Shows green, turn key shows fully charged but will not move forward or backwards. Horn works.Moved don't have the manual. It is only 1...
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Jun 08, 2009 | Zoom 220 HMV 3-Wheel Travel Scooter
Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
Jun 03, 2009 | Pride Value Line Revo Scooter 3 Wheel
Health & Beauty Logo
23 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
