Question about Hand Tools
Need a manual for a sears model 315.10411 hand drill , and where to buy brushes
Does any body have any info. on this electric drill? "pejd2001@yahoo.com
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Where is the body control module on 1999 chevy blazer lt
1999 CHEVROLET BLAZER Body Control Module (BCM)
www.rockauto.com/catalog/x,carcode,1353619,parttype,2888
... V6 > Electrical > Body Control Module (BCM). 1999 CHEVROLET BLAZER 4.3L V6 : Electrical : Body Control Module (BCM), Price, Core, Total, Add to Cart ...
electric problem maybe bcm? - Blazer Forum - Chevy Blazer Forums
blazerforum.com > ... > 2nd Gen S-series (1995-2005) Tech
Oct 25, 2009 - I have seen on line it could be the bcm module. ... In my 1999 Chevrolet Blazer it is located under the cd/radio and computer climate control. Looking for a Diagram or Info on the Body Control Module
Feb 4, 2012
body control module
Sep 25, 2009
More results from blazerforum.com
ACDelco 19153625 GM Original Equipment Body Control ...
Dec 06, 2015 | Cars & Trucks
Where is the body control module located?
Feb 4, 2012
body control module
Sep 25, 2009
Login to my account yahoo
Every body seems to be having trouble. If you've forgotten your password, fill out the form on this page: http://edit.yahoo.com/config/eval_forgot...
You'll have to verify security info about your account so that Yahoo can be sure you're the account owner.
Aug 21, 2014 | Yahoo Mail
The chuck on my old dewalt reversing drill unscrews itself from the drill body when used in reverse mode.
You are more than likely missing the chuck retaining screw. If you give me the model number I will get you a part number and info on how to order. It is a left hand screw.
May 03, 2011 | Dewalt 12 Chuck and Key
I have an 18volt Dewalt XRP 1/2 inch drill. The drill has been working perfectly up until this morning when I took it froms its case. I was using it the evening before to screw in some 2 inch screws into...
Check electrical contacts in drill body where battery connects. Check wiring inside the drill, trigger and check also brushes. You do not have to invest 329, you can buy "body only" machine for few bucks and reuse your charger and battery packs. Juraj
Oct 20, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Some body is accessing my yahoo mail and sending mails to all the address received in my mail box. Today i tried to access my yahoo mail i am unable to access
In case of a hacked account send a mail describing your problem to account-security-help@cc.yahoo-inc.com. If this doesn't help, call Yahoo: 1-408-349-1572 (personal account) and 800-318-0783 (business account), explain to a customer service person what happened. They will ask you to do certain things and then they compare your original info with the changed info. Within 24 hrs you should get your account back!
May 02, 2010 | Yahoo Mail
Drill chuck removal
Look down into the chuck and you will see a screw. It must be removed so that the chuck can be pried off. It should be righthand(standard thread) lefty loosey. An impact driver is my favorite tool for removeing the screw, as you must not strip it or you will have to drill it out. Once the screw is removed, put the drill in a padded vise if one is available and do what is necessary to pop the chuck off. Something with enough width to span from the chuck to the drill body can be carefully driven between the two to break it loose.
Apr 04, 2010 | Dewalt 3/8" Electric Drill D21009
Hi, My drill(Dremel) just doesn't turn on. The sliding switch moves, but nothing happens. The switch moves losley too. It seems dead! I wasn't present when it broke. I do not know any details on what...
With the machine unplugged, check the motor brushes. They may be worn.
I have not had success doing any other repairs to the motor part of a Dremel. I do know they have a service center. Go here for more info:
http://www.dremel.com/en-us/customerservice/ServiceAndRepair/Pages/default.aspx
Thanks for your question at FixYa.com
Jan 15, 2010 | Drills
Why does my drill turn on and off when I tilt it?
If it's a corded drill, the cord is probably broken where it goes into the drill. If it's a cordelss drill, the battery contacts (on the battery or in the battery receptacle on the drill) are loose or dirty.
In other words, when you tilt it the power is shut off to the drill.
If you want more info, let me know.
Charlie
Sep 30, 2009 | Electric Drills
I cant figure out how to get the motor out of the door or any other way to fix it, it is only rolling up sometimes andsounds like the gear is slipping
Power Door Glass and Regulator Motor REMOVAL & INSTALLATION
This is small so if you email me at bomber6509@yahoo.com I can send it to you as an attachment and it will open bigger....but here is the rest of the info for you.
Regulator
  1. Disconnect the battery ground.
  2. Remove the door trim panel.
  3. Disconnect the window motor wiring harness.
  4. There are 2 dimples in the door panel, opposite the 2 concealed motor retaining bolts. Using a 1⁄2 in. (13mm) drill bit, drill out these dimples to gain access to the motor bolts. Be careful to avoid damage to the wires.
  5. Remove the 3 motor mounting bolts.
  6. Push the motor towards the outside of the door to disengage it from the gears. You'll have to support the window glass once the motor is disengaged.
  7. Remove the motor from the door.
  8. Installation is the reverse of removal. To avoid rusting in the drilled areas, prime and paint the exposed metal, or, cover the holes with waterproof body tape. Torque the motor mounting bolts to 50–85 inch lbs. (6–10 Nm). Make sure that the motor works properly before installing the trim panel.
Jun 30, 2009 | 1994 Ford F250 Supercab
Hand Tools Logo
183 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
