Question about Uniden BC244CLT Base Scanner
Bear cat 760xlt low volume how do I fix it
Bear cat 760xlt has gradually been looseing volume is there a solution
My phone is on "vibrate." How do I get it to ring.
Try pressing and holding the volume UP button while the phone is idle (not in a call). Most phones will switch from completely silent, to vibrate, to low volume and gradually increase to full volume as long as your are pressing the volume UP button. Also, make sure your phone's "Airplane" mode is OFF.
Oct 23, 2015 | LG Cell Phones
Chain case bearings leakings arcticcat saber
Put a dual sealed berring in the lower chain case and make sure the o ring arount the berring is good and in place.
Mar 16, 2014 | Arctic Cat Sabercat 600 EFI LX Winter...
Does the 5.7 hemi, have low oil presser ,at a idle and jumps hi when you are talking of
This is always less than desirable.If the bearings and such are loose enough to allow this, there is too much room there. If the oil pump is worn so that, through internal leakage, it cannot keep up with what the engine requires at idle under normal condition, then when adverse conditions arrive you could suffer oil-starvation damage.
The easiest fix is to replace the oil pump with a high volume oil pump. All that requires is getting the oild pan off. Then you will know that you have a good pump, and without tearing the entire engine apart you can meet the oil needs a loose engine presents. Any excess volume will be spent by the pressure relief valve.
Jun 15, 2010 | 2007 Dodge Ram Truck
Marshall DSL 100 - volume fades away and gradually comes back on
IF this is a vacuum tube unit, these symptoms are that of a tube that the heater is intermittent, that is it cools off due to a break and then liights again.
Open the back and observe the heaters in the tubes. DO NOT be fooled by some that have TWO heaters in them. (use a mirror if necessary) A single one that comes and goes can cause the problem and the voiration can make it come and go. This behavior in a tube is NOT somthing readily spotted in a tube checker. The delay in fading and coming back would be the delay in warm up following a heater going out and cooling.
Feb 14, 2010 | Marshall Amplification Marshall MG250DFX...
Crank shaft moves fore and aft under engine load
Yes, this is a problem which is very common to this particular vehicle. It is slightly an expensive fix, yet if you could get the bearing fixed instead of replacing it, you'd save some cash!
Aug 07, 2009 | 2002 Ford SVT Focus
2006 Volvo S60 AWD rear humming noise
Wheel bearing is the most likely cause. Prob a 1.5-2 hour labor rate job in the shop.
Oct 27, 2008 | 2006 Volvo S60
When i was hooking it up it made a big spark and now it smells like it is fryed
please always turn off your system befor any connection----clean contact points of socket(the place where you put your jack)with any contact cleaner-connect your cable again and turn power on and try in low volume and increase the volume gradually until you get good sound-----if all above failed you will have hardware problem inside your receiver and can fix through field technician
Aug 06, 2008 | Audio Players & Recorders
Sony xm-1652z 1000 watt amp
a loose or corroded connection can cause this problem...do not overlook possible loose fuse holder...also look into remote control line...also check speaker line for a loose or shorted connection...a loose connection in any of these locations can cause a spike in the current drawn from the power supply... a bad speaker can play at low volume but short at high volume; if the flex wires from frame to cone on the speaker start to fail, it happens at high volume first, and sounds like a crackle, and gradually becomes present at lower levels; a voice coil can warp at high signal levels, causing it to short intermittently, in addition, you might check the cooling capability of the amp...i don't recall whether you have a fan on this amp...
Jan 11, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Volume is too low on my old Sony Trinitron KV-27S45
Volume is too low on my old Sony Trinitron KV-27S45 Can i fix it with out parts? no as it requires tech help as tv is high voltage device. would it be less expensive to just purchase a new tv? it would be less expensive. no need to purchase new tv. please get check 1 speaker paper cone might be hard or defective 2 loose contact in sound section 3 supply to sound might be absent. 4 connector loose. 5 any capscitor defective in sound section. 6 ic might be defective in sound section hope this will help.
Sep 25, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Uniden BC244CLT Base Scanner Logo
62 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
