When i write the program exception handling in c++. it give the error try and catch keyword. how to handle the Exception handling in c++
    Problem Solver:
  • 17 Answers
You might be using old compiler. Use a latest compiler such as Turbo C++ 4.5 or later. The older versions 2.0 and 3.0 does not support exceptions.
Posted on Jan 21, 2009
What does (Error: 0x007) mean
STOP 0x00000007 errors are likely caused by hardware or device driver issues.
Nov 30, 2013 | Microsoft Windows 7 Home Premium 64BIT...
The error says "Application has generated an exception that could not be handled. Process id=0x (a series of numbers that change), Thread id=0x (numbers that change). Click OK to terminate the applica
did you add any new hardware or software just before this error started. If this is a Windows PC you can go into the safe mode and remove the bad software. You can also (if you can) remove or disable the hardware. Reboot into the PC as normal and see if you are still getting the error.
Jul 31, 2013 | Computers & Internet
Is showing fatal error 05 if i conact it with the tv and the pc is not showing my iomega? what to do ?
The main reason are :-
  • Access to an illegal instruction has been encountered
  • Invalid data or code has been accessed
  • The privilege level of an operation is invalid
When any of these cases occurs, the processor returns an exception to the operating system, which in turn is handled as a fatal exception error. In many cases the exception is non-recoverable and the system must either be restarted or shut down, depending upon the severity of the error.
Jul 22, 2011 | Computers & Internet
Says that a uncaught exception:java lang.nullpoinereException
suppose you have declared a array of 5 ( ie 0-4 ) and you are entering the value for 6 or we can say more than 5 then you will receive this error and also you have not declared the catch block or exception block for this exception to handle the error .
Oct 04, 2010 | Computers & Internet
What does Dim, Try , Me , Private Sub means in Visual Basic
Dim allows you to declare a variable. It is short for "Dimension", and is an old old keyword. For example if you want to declare a variable called i that can hold an integer you would write:
Dim i As Integer
The Try keyword is used to allow you catch errors when they occur. If you didn't catch them, they would cause the program to end with an error report.
Try ' Code goes in here that might throw an error Catch Ex As Exception ' Code goes here to deal with any error End Try
The Me keyword refers to the current instance of the class in which the word appears. For example if the class is called Form1, then Me allows you to refer to the current instance of the class when the code is running.
Private Sub is formed from two Keywords. Private is an "Access modifier". When applied to a Sub it means that the Sub would not be visible outside the class. Sub is short for "Subroutine". A subroutine is a section of code that performs some useful function that you might want to run many times. For example you might want to do something whenever a button is clicked, and so you would write a subroutine with code in that will run whenever the button is clicked.
It would be better to ask programming questions in a visual basic forum. There are many on the internet. Search the internet for "visual basic forum". Also note that when you are using Visual Studio 2005, you can press the F1 key when you have placed the cursor in a word that you do not understand, and it will open the help and the relevant page.
These terms are very very difficult to understand when you have never programmed before. Usually it is best to take a lot of it on faith, and move on through the book or example that you are following without completely understanding it all. Over time, with practice, repetition and perseverance you will start to develop an understanding of the underlying concepts. They are hard to explain and hard to learn.
Jun 06, 2010 | Microsoft Visual Studio 2005 Standard...
What is error statemant?
The try...catch Statement The try...catch statement allows you to test a block of code for errors. The try block contains the code to be run, and the catch block contains the code to be executed if an error occurs
//Run some code here
//Handle errors here
Apr 03, 2010 | ArcMedia JavaScript Source Code 3000 Pro...
Try to start HP Image Zone, get error. Fata Exception Engine Error (0x7927f26e) Click Ok and the get an error Application has generated an exception that could not be handled. Process id = 0xf4c (3916),...
Hi sjt916,
Unfortunately the only way to fix this is to reinstall the program. Somehow the installation has become corrupt and is conflicting with a windows operation producing an error.
Please tell me how it goes.
Nov 13, 2008 | HP Computers & Internet
Excel formula
The IF() is the wrong one to use. Use "Iif()", as in:
=IiF(A3='Audit Exception Register'!B:B, COUNTIF('Audit Exception Register'!P:P,Y), 0)
Caveat about using Iif(), one that doesn't probably apply in this case, but keep it in mind: Don't use Iif when trying to return the values of "real" objects. Examples of "non-real" objects in the VB/A world are:
Integer, Double, etc... all the numeric "objects"
These are fine to use in IIf() statements. If however you will be returning some value that is part of an object, as in:
Iif(x=2, myObject.getSomeVal(), 0)
You run the very real risk that is myObject is null, your program will simply stop running. Iif() will NOT return a null error/exception; it will in fact just stop. This is a bug in the VB interpreter and/or in the Iif() function itself.
I am referring here to classic VBA (ie, pre-VB dot-Net). How .NET handles such cases, I don't know.
Mar 07, 2008 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
