Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Pressure is set, will fire, won't stay lit
I've checked the pressure and adjusted it. This heater was turned on by thermostat and kicked of and on several times throughough one day, then i turned it off for the night. Came back the next day and it would fire just for a second, might even fire 2 or 3 times, but will not stay lie after that first day. Any ideas?
  • 2joshd Jan 22, 2009
    owners manual recommended 6.0 psi and set it to that. I found the solution.....out of fuel. The furnace was purchased 3 days ago and the guage read 3/4 of a tank. It was spraying fuel, but just enough to get the flame started. Yeah, don't trust the guage, they hang up really easy. I started to move it to a new place to work on it and didn't notice a slosh. Thanx tho
  • 3 Answers
Is pressur sensor set at 0.65 cfm??
Posted on Jan 21, 2009
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
Pilot stays lit but heater will not fire up
so it is a millivolt .and the answer is yes there is a water pressure switch inside the heater, but also there is a internal flow control valve in right side of the heater,check by removing the 2 bolts, and look inside if there sand left ,by brucken laterals inside filter, also check for gas pressure ,the pilot stay lit ?
Jun 15, 2013 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Raypak problem, Pilot is lit, can jump TH to TH to lite, goes out when jumper is removed.
check how many millivolts the pilot is generating. if pilot stay lit and burners wont fire u have a problem with one of the safties, lose wire connection, tstat control
May 28, 2013 | Raypak Pool & Spa
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
I can light the pilot and the burner will come on, but it won't stay lit. I bought a new pilot assembly and installed it. the burner and the pilot light still won't stay lit. This is the unit that...
Most gas water heater problems can be solved by having service technician perform yearly maintenance. Or by doing maintenance yourself.
This maintenance includes cleaning burner parts and combustion chamber, checking gas pressure and supply, bleeding air out of gas line, checking vent draft, making sure air supply is adequate and not exposed to chemicals, cleaning air intake. Also adjusting flame sensor so it is positioned correctly. If water heater is connected to electric circuit, the outlet must have correct polarity.
You can get gas to appliance indicates the gas control valve and water heater are not locked out. But the gas control valve thermostat can still be bad.
Open following link for illustrations, typical service manuals, and maintenance information, and images of gas control valve thermostats.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 20, 2011 | Reliance & Pilot Assembly for Natural Gas...
Pilot is lit but the heater won't fire up
A few things dictate when the main burner turns on. One is a thermocouple not getting hot enough, the other is a bad thermostat ot thermostat wire, and another is the gas valve. First look at the gas valve located on the heater and make sure it is in the On position and not in the Pilot position. Remove your thermostat and jump the two wires together. The heater should light. If not, go back to the gas valve and find the wires up to the thermostat, the should be attached to terminals marked TH and MV or something similar. Jump the terminals. The heater should start. If not, you may need to replace the thermocouple.
Sep 04, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Not getting any fire
Can you give us a make and model number?
Nov 11, 2007 | Heating & Cooling
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
104 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
