Question about ViewSonic VG150 15" LCD Monitor
Power switch behavior
Hi, For a while, we had to press the tactile switch many times and soon or late, the logic turned on. Then, to avoid this, we left the monitor on all the time. When the computer was turned off, the monitor was turning off but was not really turned off by its switch, the led I think was switching to an idle color, so when turning the computer on, we did not have to face any problem because the monitor was turning on. Now, it is dead. that workaround does not work any more. At a service shop, they told us an IC has to be changed. We do not know which one. Can anybody help on that? Tanks.
  • Russ Melanson
    Russ Melanson Jun 10, 2008
    I have about 6-7 Viewsonic VG150 LCD monitors (both beige and black) that all exhibit the same problem of "the faulty power switch", if that's indeed what it is.
    Problem: Power switch doesn't work, until pressed repeatedly and rapidly. Once turned on the monitor works fine, and the power switch will turn it off correctly, but then you'd have to repeatedly and rapidly press it again until it "catches". Upon close inspection the power LED flickers the more rapidly you press it, so I imagine there's some sort of voltage or capacitance problem, but I have exhausted all my good ideas on what might be causing it. I've taken them apart and tried resoldering and replacing just about every electrolytic capacitor on the logic board.
    This is incredibly frustrating. Can someone suggest something else to try replacing, or a possible cause of the faulty power switch?
    HELP! PLEASE :)
  • 286 Answers
Kbzaloka: That is not a solutiom you posted. If you can't help, then don't post anything.
russolini: I'm having the same problem with a monitor on my bench right now. I did fix another problem it had. It seems some of the surface-mount electrolytic capacitors are going bad. I will let you know if I solve this fault too. If anyone has lines going through their display, and the sides look ripped or torn, your pixel clock is not working correctly. Try replacing the 22uF capacitor C46 right above the pixel clock generator IC09. This should smooth out the 3.3V supply for this IC and correct the problem.
Posted on May 06, 2009
  • 1 more comment
  • Mergatroid May 06, 2009
    I have solved this problem on this model.
    The power switch goes to IC30. Once again, in this circuit there are
    two surface-mount electrolytic capacitors. Lucky for me it was the
    first one I replaced.
    IC30 is in the lower right corner, to the left of the LED on the main
    board. To the left of the IC is a 22uF electrolytic capacitor C112..
    Replace this capacitor and your problem will be solved.
    To remove, heat one lead with solder iron and push capacitor slightly
    in opposite direction. Then heat the opposite lead and push in the
    other direction. Repeat until capacitor comes off. BE VERY GENTLE OR
    YOU WILL DAMAGE THE TRACES ON THE BOARD.
    Once removed, add a little solder to the trace pads. You don't have to
    use a surface-mount capacitor to replace it. You can use a normal
    electrolytic capacitor (22uF @ 16V) and trim the leads to be only about
    4mm long, then bend them out in opposite directions. Place
    capacitor on solder pads making sure you have the polarity correct.
    Heat the solder on one lead and remove the iron, then heat the solder
    on the other lead and remove the iron. Job done, perfectly working
    monitor.
    I didn't put my name in the solution (comment). Mergatroid solved this problem.
  • ruccha Sep 14, 2010
    I just wanted to say thank you, thank you, thank you, Mergatroid -- this worked perfectly!
  • 65 Answers
Well my friend, there are people that have courses , studies , school etc to know "which one" they are called "Technician, Engineer,etc" they can help you...
Posted on Jul 13, 2007
I have a 13 late 2013 MacBook Pro Late 2013 which switches off when and turn it on soon after the startup sound. when i force it to switch on by pressing the power button for more that 5 seconds it bo
Turn it on and boot while holding down the Command and R key.
That should take you to OSX Utilities. You can then check and make repairs to your disk then reinstall OSX 10
Feb 05, 2015 | Computers & Internet
Brightness screen keeps popping up how do I make it stop?
Sounds like the tactile switch is faulty. You know on a telly remote, you press the button to select the channel....well the switches on the monitor are the same. Behind the switch is a rubber contact which has a conductive contact which you must not clean( as such) it sounds like this is in permanent contact with the conductive elements inside it. As the switch is probably only 5mm x 5mm, it is a tricky DIY job to put a new tactile switch in, but easy for someone who does electronics.
Nov 24, 2013 | Sceptre NAGA II X20WG 20 inch LCD Monitor
Need to access the menu
Know what the ->enter BIOS Setup key is?
It's on the bottom of the computer manufacturer logo screen.
Got it?
Now press the CTRL and ALT and DELete keys at the same time.
Restarts the computer.
JUST AS SOON AS IT STARTS, start tapping on the enter BIOS Setup key.
Tap in 2 seconds intervals.
If you hear beeps ignore it. These are Stuck Key Error Code beeps, and it is you that is making them.
Still No?
Turn the computer off by holding the Power On button in, for 10 seconds.
WAIT 20 seconds, then press the Power On button.
AS SOON AS YOU PRESS the Power On button, start tapping on the enter BIOS Setup key. The rest is above.
Regards,
joecoolsvette
[The time period to enter BIOS Setup goes by F-A-S-T!
As soon as you see the computer manufacturer 'splash screen', (Logo screen), it may be TOO late. The above method makes sure you get in BIOS Setup ]
Nov 21, 2012 | Computers & Internet
I have a sony mp3 xplod car radio, buttons wont work on it to operate probaly, any suggentions as to what is wrong?
I had the same problem with my sony CDX-GT540UI and solved it! I just kept clicking the "source/off" button when the display was showing the demo and suddenly it started switching to USB/CD/AUX etc. This means that the contacts inside the micro-switch were stuck in the down position, continuously making contact, and blocking the signals from the other buttons. Have to replace the micro-switch now.
Dec 29, 2011 | Sony XPlod CD Player w/MP3 Playback...
Hi my lap top is vostro 1520 and there is a proble with it that i can not stand by laptop because when request to sleep it shut down or some thing like this (hibernate i don't know).and then when i...
Hi
Go to Control Panel, Power Options,
Then adjust the options there:
  • closing screen behavior,
  • pressing the power button behavior
and, tell us the results.
Good Luck
May 15, 2011 | Dell Vostro 1520 Notebook
Compaq presario cq40
Likely the tactile switch which is under the button is worn out because of the repeated pressure. Do the charging lights or any lights light up? If it is the switch "which is essentially another smaller button under the power button" then the best advice is to get a new/used power board strip which has the power button on it and often others as well.
Feb 24, 2010 | Compaq Presario Notebook
Dishwasher not responsive, just a blinking CLEAN light.
HI, this is a control fault that is located in the logic sector of the circuit board. You will need to replace the control in order to restore proper function.
May 30, 2009 | Kenmore Dishwashers
TV won't turn on
Practice visual acuity technique! Solder any/all bad connects.check power supply. Check tactil switches on front of set. Remove chassis,unplug all connectors,re-assemble,try again.
Sep 25, 2007 | Sanyo DS27910 27" TV
Laptop Power
try this: power up then turn on the hibernate feature of windows. this should eliminate any need to ever hit the power button again.
Jun 02, 2007 | Acer Aspire 5630 Notebook
ViewSonic VG150 15" LCD Monitor Logo
264 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
