Question about InFocus ASK Proxima C445 LCD projector - 4000 ANSI lumens - XGA 1024 x 768 -
I need to clean my filter on my proxima c445 projector
I do not have a manuel and i need yo know how or where yhe filter is to clean it and how to clean it
  • InFocus Master
  • 3,904 Answers
There is a slotted panel on the projector held on by a screw or two. Take that off and should be right there.
Posted on Jan 10, 2013
2 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: Proxima dp100x projector shows red background. Is
the colorwheel or the dmd chip may be bad. but first, go into the menu under service and reset the settings to factory default.
Posted on Sep 03, 2009
We have multiple A1200ep Ask Proxima projectors. We are having a problem with two of them. They just shut off after a period of time even when your in the middle of using them. It's like the projector...
Clean air filters. DO NOT BLOW INSIDE!!!
Take the filter out andust it out somwhere outside.
If it does not help, more likely there is fault inside.
Possibly power supply.
Mar 07, 2011 | ASK Proxima DP1200x Multimedia Projector
The projector lamp turns off after one hour.
Very likely the air vent is block or you will need to clean the air vent. The system track the hours of usage and when it is time to clean the air vent filter it will stop working. A clogged air vent will make the temperature of the equitpment rise. To protect the circuits and projector expensive light component it will stop working automatically. After cleaning up the air vent, see the manual how to reset the clock/timer for air vent cleaning timing, so that the lamp would not turn off.
Aug 10, 2010 | InFocus Proxima DP5900 Multimedia...
Proxima 2810 need help
go to http://www.askproxima.com and click support box. select the proxima box
and you should see dp2810. manual is for all model dp2400-2810 click this and
you will get to the manual and other info.
direct link to the manual is http://www.askproxima.com/service/dp2400/downloads/2xxxUG.pdf
judy
Apr 08, 2009 | Office Equipment & Supplies
Projector getting too hot
comman to a projector to get hot in front and top center part
but not at the rear side
this might be
fan not working
filter need to clean
bulb life getting lower
open the cover check safety paper
might be burn out
replace new one.any hard paper
Jul 10, 2008 | InFocus Proxima DP6155 Multimedia...
Same problem- shuts off automatically
Clean the air filters and also check the fan is working for proper
air circulation.
Viren
May 23, 2008 | ASK Proxima Proxima DP2000S Data Video...
Proxima ds1 not lighting
hi
replace or clean the Air filters. Run the lamp reset command if you have.if not solved then check ballast unit which ignites the lamp.
try this also, press the poweroff button on the remote control for ten seconds, the lamp will reset to zero, if you run the projector more than 1100 hours earlier.
Viren
Jan 16, 2008 | Office Equipment & Supplies
Proxima Ultralight Projector 350x
The filters probably need cleaning. Also check and make sure none of the vents are being blocked.
Nov 20, 2007 | InFocus Proxima UltraLight X350 Multimedia...
Proxima DP2000x
that model has issues with the power supply board. unfortunately, there are no replacement boards.
Oct 19, 2007 | ASK Proxima Proxima DP2000X Multimedia...
Screen has vertical lines in the display
either the power supply or the main board (eca).
Sep 21, 2006 | ASK Proxima Proxima DP2000X Multimedia...
InFocus ASK Proxima C445 LCD projector - 4000 ANSI lumens - XGA 1024 x 768 - Logo
41 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
