Question about Fuji FinePix S3000 Digital Camera
Fujifilm S3000 not turn on
Just basically it will not turn on ,,replaced batteries with fresh new ones to no avail... It basically does well....it does absolutely nothing It has been a great camera taking thousands of pics with no prob I dont feel there is any loose screws Hmmm dont hear any rattling and nothing seems to or appears loose Any help is much appreciated
  • 6 more comments
  • garyech Nov 26, 2007
    Same problem here. Just will not turn on. Put in new batteries, memory flap is shut. Any other possibilities here?
  • jack j Nov 28, 2007
    camera went dead right after use - shut it off went to turn it a few minutes later - it was dead.
    tried new batteries, a power adapter - nada
    will look at memory flap again
  • cherrymom Dec 10, 2007
    I have noticed that the camera goes through batteries faster than it used to, but now even with new batteries in, the low battery light comes on and it automatically shuts off. I can't even take one shot. Help!
  • badcameraman Dec 27, 2007
    Tried to turn on one time and noticed the power light flick off as soon as it came on and repeated to the same avail. New batteries and same problem. It wont turn and stay on. Memory flap door is fine to.
  • mytwoboys Dec 28, 2007
    My camera started shutting off out of no where. Had nothng to do with the power save feature. Then started going through fully charged batteries too fast. Then sometimes would turn on, other times would not. May get 1 picture, maybe not. Tried new batteries before and problem was solved temporarily. Now, I cannot even get camera to turn on. It gave up on me completely. Tried new batteries. Was this camera a waste or do I still have hope????? The card slot is fine. The flash will not close, but when I held closed, still camera would not go on. I cannot afford a new one!
  • Anonymous Jan 06, 2008
    I am having the same problem!!  It used to work wonderfully, now fresh batteries, even fully charged ones don't work!  Maybe 1 pic, if I am lucky.  The troubleshoot in the manual says to check the battery terminals and clean them, but with what??  I am very disappointed.  I miss my old regular 35mm.  Plus it takes 5 second delayed shots.  I don't get the shot right as I take them.  Forget action shots...
  • Anonymous Dec 18, 2008
    My camera worked fine on Sunday morning. Sunday afternoon, it wouldn't come on at all. The only thing that did happen, was the red light on the front flashes once when I turn it to the picture view setting. I recharged my batteries and nothing. I cleaned the battery terminals...nothing. I've had the camera for a couple of years now and it seemed to work awesome....until 3 days ago. :(
  • 3baseman Dec 25, 2008
    Yup, exact same problem. The batteries are good and I cleaned the ends with an eraser, checked the memory door, removed and reinserted the memory card, and tried a 4.5V DC plug-in adapter (with the correct polarity). The green light sometimes comes on and sometimes I can switch to the LCD screen, but as soon as I hit the button to take a picture the camera goes dead.
  • 3 Answers
Mine had with this problem....After checking everything I found some corrosion in the battery compartment so I cleaned the contacts at the bottom of the compartment and put a new set of batteries in...The camera started working again....DON'T leave batteries in if you are not using the camera >>>
Posted on Jul 03, 2007
Check the memory flap door - the on the eop their is a small prog which tells the camera that the memory door is closed its probably brokne like mine and then it will not turn on. Andrew
Posted on Jul 23, 2007
SOURCE:
Why won't my Fujifilm Finepix S7000 turn on, even after I put new batteries in?
Verify batteries are fresh and of correct type, batteries and terminals are clean. If a rechargeable, verify battery and charger are good. Otherwise, camera may need servicing.
Aug 29, 2014 | FUJIFILM Cameras
I have a 1997 mercury mystique. Battery fully charged, turn the key, absolutely nothing. In fact no power to anything, no interior lights, nothing. Battery is brand new
Its seems voltage regulator issue.Get the vehicles charging system inspected.
To troubleshoot these issue i suggest you few helpful links with solutions:---Click the link below:----
How to inspect Vehicles Alternator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-inspect-vehicles-alternator.html
How to Test Vehicles Alternator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-test-vehicles-alternator.html
How to Service Vehicles Alternator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-service-vehicles-alternator.html
How to Replace Alternator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-alternator.html
How to monitor Vehicles charging system?
http://repairhelpcenter.blogspot.com/2011/11/how-to-monitor-vehicles-charging-system.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Working Intermittently?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-working-intermittently.html
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
From start to end troubleshooting these problems I suggest you to check the help link below and follow its procedure: -----
Mostly all types of car no start problems are discussed here with solutions:---
CAR NO START: ENGINE NOT TURNING OVER:
http://alltypesofpartsreplacing.blogspot.com/2012/11/car-no-start-engine-not-turning-over.html
These will help.
Thanks.
Dec 10, 2012 | 1997 Mercury Mystique
How do you load the batteries?
The batteries are incorporated into the photo pack and are not replaceable separately. All original Polaroid photo packs are now so far out of date that the batteries are useless
Fresh, newly manufactured compatible photo packs are now available from The Impossible Project, but the material is absolutely not the same as the original Polaroid product.
All details are on The Impossible Project website.
Jul 26, 2011 | Polaroid Photography
My nikon S3000 has been giving me many problems ever since I bought it. My latest problem is when I turn it on one day, it indicates that 'battery exhasted', but I had fully charged it previously. And...
Rechargeable batteries don't last forever and the ones supplied with the camera are not of very good quality. Try new batteries and also consider getting another recharger as the Nikon supplied one is very basic and does not take good care of the batteries it's used with.
Mar 24, 2011 | Nikon Coolpix S3000 Digital Camera
Fujifilm S3000 zoom error camera will not take pictures
Unfortunately it sounds like the zoom is broken in the camera. I suggest that you try to vacuum around the lens and see if that dislodges any debris. Also fully charge the batteries or use fresh ones before attempting to operate the zoom mechanism. If this does not work for you then you will have to ship or take into an authorized service center. The local center in New York is Photo Tech; www.phototech.com.
Feb 26, 2011 | Fuji Cameras
When I turn the console on, the logo pops up an says "V Smile Motion." However, if I put a game in and turn it on, it does absolutely nothing.
This worked for me!
Ttry removing all of the batteries or unplugging the power cord..and holding down the "ON" button for about 45 seconds. Then replace the batteries (be sure they are fresh) and try your product again. It is somewhat of a "hidden" Re-Set button.
Sep 01, 2010 | V.Smile V-Motion Active Learning System
When i turn on, it says lens error, restart camera - i"ve turned the camera on and off several times and nothing happens, the error message continues to show. I've taken the battery out and put back in but...
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jul 05, 2010 | Canon PowerShot SD770 IS / IXUS 85 Digital...
No electrical power to my bike.
Try another Ignition switch to see if any power is available. Unfortunately this is a problem that can't be solved here, wiring is something that needs to be diagnosed by someone working on the bike.
Mar 19, 2010 | 2000 Suzuki VZ 800 Marauder
Fuji FinePix S3000 Digital Camera Logo
245 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
