Question about Sony PlayStation 2 (PS2) Console
Disc tray on my ps2 broke
My son didnt have the dvd in the tray right and then tried forcing it to close and broke it.can i replace it with another driver disc tray?
    New Friend:
    Problem Solver:
  • 5 Answers
Its difficult.. but not impossible...
there r 2 push-buttons when you disamble the ps2 and u need to press them continuously in order to run your cd!
here's the solution go to youtube and search play ps2 cd's without the upper tray cover....
Posted on Jan 28, 2013
tukidoman
  • 80 Answers
SOURCE: ps2
hi check if the button is stuck you might need to open it becareful not to disconect anything and if you do first see were it goes ho it helps.
Posted on Jun 25, 2007
greedo1989
  • 3 Answers
SOURCE: disc tray rattles
the screws on top of the disk tray may be loose u can take it in or fix it yourself if u dont mind takin your ps2 apart or have already just make sure screws on top of disk tray are tightend down all the way its an easy fix but be doing this it voids warranty and i i think that if seal on back is broken u cant take it in to have it fixed.
Posted on Jan 02, 2008
thaurfen
  • 623 Answers
SOURCE: My ps2 doesnt show anything on screen!!
video out is out
Posted on Aug 05, 2008
MNfisherman
  • 11896 Answers
SOURCE: Disc won't spin so I can't play the game/DVD/CD
replace the motor. The motor has burned out causing the disc not to spin.
Posted on Jan 20, 2009
RixsFixes
  • 2200 Answers
SOURCE: I tried to fix a problem with my sons PS3 disc
Hi
You can get the assembly for around $140 from the likes of gamerepairworld.com
There are some good videos on youtube on how to replace the drive - see example here - this guy also sells them on ebay which is another good place to have a look at prices.
Hope this helps - please do rate this answer.
Posted on Aug 02, 2009
I nudged the loading tray with my foot when changing a disc. As a result the tray is not opening or closing, presumably because it is no longer aligned properly. Is this likely to be something I might fix...
Mechanical timing and alignment is the problem of your dvd player.
This comes when you accidentally force the disc tray to close.
You need to open the cover of the dvd player..take out the dvd mechanical loading system try to eject it manually by turning the gear with your hand.
Make sure that the cd loader reaches the limit switch before it closes. This will return back the right timing and alignment.
Feb 04, 2011 | Denon DVD-1930CI DVD Player
The DVD Player won't Open/Close and there is a DVD inside. How do I force it open?
The DVD player jammed, that is why it is not opening.
To get it to open and close, you will have to unplug the player, then unscrew the screws around it. Take off the cover then you will have access to the disc tray. Then you can plug the player and press open, it will attempt to open but stop, then you can try to apply a little force in pushing the disc tray towards the open direction, it will sit properly and open up.
You can as well unscrew the disc tray and remove your disc, then you press the open button and sit the disc tray properly it will open freely and easily after then.
Take care and good luck
Oct 30, 2010 | Mitsubishi DD-4020 DVD Player
Display flashing Hello and clunking sound from DVD RW. Will not change from Hello nor will it open or close
sounds like you have broken piece moving around on the inside or broken dvd inside my youngest son put a music cd in my dvd player and didnt put it in right and it broke causing player to make clunking sound and door refused to open. The broken cd was found when player was opened up and sorry to say the tray was broken because of it
Aug 09, 2009 | RCA DRC8030N
Disc Tray won't stay closed on Playstation 2
I HAD THE SAME PROBLEM OUT OF MY PS2 AND MY SON PS2. I FOUND THIS NEW SITE THAT TOLD ME WHAT WAS WRONG FOR FREE AND FIXED IT WITHIN A FEW DAYS. http://PS2EARTH.synthasite.com I LOVE FIXYA BUT THIS SITE IS BETTER FOR GAMERS. THEY CARE.
Dec 30, 2008 | Sony PlayStation 2 (PS2) Console
Tray keeps opening and won't play dvd
no your son broke the loadi tray and now it will not aline properlycheaper to buy a new the fix!
Dec 08, 2008 | Toshiba SD-2715 Multi-disc DVD Player
Open Tray
DVD wont close
I just solved this problem, very simple actually. Possibly can happen when the drive WILL close, but then loud noise as it tries to spin the disc up. Open the drive up (4 little screws on the bottom) and lift the lid up. If you look on the top white magnet spinner, the bottom side of the magnet system broke off of the disc motor. It will look like a little metal ring stuck to the white spinner thing whatever it's called. I popped that off and examined it, then used some krazy glue to stick it back on the motor spindle and it's away and going now. The reason the drive will not close, is because when the little magnet first breaks off it can get misaligned then when it tries to shut it gets in the way. The MAY be the cause to the problem. I fixed this issue today with mine, hitachi drive.
good luck
please mark the post with a fixya!
Feb 20, 2008 | Microsoft Xbox 360 Console
Cannot Close Sony DVP-NC665P 5 disk tray
There is a possiblity that he may have shifted the unit while discs were in it causing the discs to slip off the tray and into the unit. You have to open the unit to check if there are loose discs.
Nov 12, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
DVD Tray won't stay closed
It can only be repaired by the repair shop I think your son broke a lug on the inside it may need a new tray?
Sep 13, 2007 | Zenith DVD5201 Multi-disc DVD Player
PS2 cannot read
YOU PROBABLY NEED TO TAKE IT BACK WHERE YOU BOUGHT IT CAUSE MY SON HAD THE SAME PROBLEM AND NOT EVEN AT A FIX IT SHOP COULD THEY FIX IT THE COMP HAS TO REPLACE THE READING LENS.
Jun 03, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
44 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
