Question about Radio Communications
My jabra pro 920 headset does not have an indication for incoming calls. there is no beep or ring of any sort. how do I fix this problem?
informatica
  • 1114 Answers
SOURCE: Manual for Jabra BT150 ????
You can download the manual & get other information from the link below: http://web.jabra.com/JabraCMS/EM/EN/MainMenu/Support/WirelessHeadsets/JabraBT150/ Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 12, 2007
SOURCE: Incoming alert
Generally you will get a ring in the headset when a call is detected by the lifter that you use or if you don't have a lifter then you would have to use the little microphone that comes with the unit and affix that to the speaker on your phone so that your GN 9120 knows when to alert you of a call.
Posted on Jan 08, 2008
SOURCE: Jabra BT350 Bluetooth Headset
This is what I did:
1. open the headset by following these steps:
http://www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair/
2. measure the voltage of the battery. If it is too low, the internal charger circuit may not like it. Mine was 2.6v.
3. Charge the battery "manually" by connecting to 3 serially connected rechargeable batteries (final voltage should be around 3.7v). Three NiMH AA batteries are fine.
4. Reassemble and hope your headset is back to business.
Posted on May 19, 2008
shaggyrat
  • 1224 Answers
SOURCE: H500 soft persistent beeping
this sound is the sound of count down from going from a standbye mode to shutting off itself to conserve battery thats all this is
cant stop it unfortunatly its built in feature
Posted on Jun 08, 2008
SOURCE: No 3 beep notification in the earpiece of an incoming call
I had the same problem and the cause was the handset lifter and not the earpiece--if the ringtone is too low at the lifter, it won't be detected and transmitted to the earpiece. Cranked up the ringtone and everything is fine.
If that doesn't take care of the problem you might look at whether or not you're using custom ringtones which might cause a problem. Switch them back to the defaults and see if the problem goes away.
Posted on Dec 03, 2008
How to accept the incoming call.
has it been 'paired' with your phone via bluetooth?
Apr 13, 2015 | Jabra Bt2035 Bluetooth Headset...
Auto connect/disconnect
Hi. To turn Voice Guidance off, press the Option button. To find the settings, press up or down slowly until you hear a beep. Press OK to enter the voice guidance menu. From that his menu: Voice Guidance On/Off: Use arrow keys on remote to toggle on and off. NOTE:This menu is spoken even when voice guidance is turned off.
Read more: Turn off voice guidance Jabra extreme 2? - Software to turn off voice guidance of jabra extreme 2 :: Ask Me Fast at
Jun 14, 2013 | Jabra Extreme2 Bluetooth Headset
My Plantronics Voyager Pro begin emitting a continual ringing when I pair to my Blackberry. I've tried deleting the headset and re-finding it and it still rings when connected. This issue first appeared...
It sounds like a defective headset. Call Plantronics directly at 1-800-544-4660 x 5538 to troubleshoot and if it's defective, they will assist in a replacement.
Good Luck from Headsets Direct!
May 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
Cannot hear phone ringing in headset, only on handset.
The HL10 handset lifer is what notifies your headset that you have an incoming call. If you are using the handset lifter and are not receiving the 3 short beeps in your ear piece there are a couple different things that could be going on.
1. The internal microphone could have gone out on the lifter. This microphone is what sends the signal to your headset that you have an incoming call. If the microphone is working you will hear 3 short beeps in your headset.
2. If the volume is too low on your telephone, the handset lifter will not notify the headset of an incoming call, so try turning the volume up on your phone and see if that takes care of the problem.
3. The HL10 handset lifter ships with a ring detector that has a 2.5mm jack on one end and a small round microphone on the other end. This ring detector is intended for phones that do not have the speaker located under the handset. You could try plugging this into the back of the lifter and setting the microphone next to where the lifter is mounted on your phone. This might help pick up the sound of the phones ring tone.
If you are manually lifting your handset out of the cradle and sitting it to the side instead of using a lifter, then you will not receive the 3 short beeps in your earpiece to notify you of an incoming call.
Good luck from Headsets Direct!
Nov 03, 2010 | Plantronics Voyager 500A Deskphone Adapter...
I need an owners manual for jabra model BT4051 headset
You don't need one. After charging set, press and hold for several seconds until unit blinks repeatedly. Now it's on.
To turn it off, repeat procedure.
Press briefly to take incoming calls, or to place calls if your phone is voice activated. You should hear a beep after each press.
Use + and - buttons to increase/decrease volume.
Unit blinks once, intermittently, when it's ON. That is normal operation.
Note: It takes a few seconds for the connection to occur, after you initiate a call or take a call, and other sounds alert you when the connection is taking place. You'll learn as you go.
Dec 02, 2009 | Jabra BT4051 Bluetooth Headset
GN Netcom 9120 unexplained beeping
Actually what she was hearing was the ring tone in her headset when a incoming call comes in. The sensitivity on the handset lifter that picks up the ringing on a incoming call was set all the way up and was picking up interferance from the headset base as they have the tendency to buzz when placed right next to the phone. I just turned down the ringer sensitivity with the adjustment on the handset lifter and that took care of the problem. Thanks for your time.
Nov 06, 2008 | GN Netcom (9120-48) Wireless Headset
CS70N Wireless headset
The earpiece will make 3 short beeps when a call is incoming. Also the phone will still ring if you are within distince to hear the ringer. Hope this helps! SM
Sep 10, 2008 | Plantronics CS70 Wireless Headset
Cant hear
I have the same problem. The lights are on, it's paired, and my caller can hear me. but I cannot hear the beep from pressing buttons on the jabra, nor can I hear anything from the phone.
Oct 31, 2007 | Jabra BT500 Wireless Headset
I cant hear anything out of my headset
Is the headset paired and connected to your phone? Is bluetooth turned on in your phone? Look for the bluetooth icon on top of your phone's screen. Let me know what model phone you have and I can help you troubleshoot.
Sep 03, 2007 | Motorola Mobility H700 Wireless Headset
Radio Communications Logo
1,085 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
