Question about Watches
The alarm on the umbro chronograph watch does not make any noise?
Even with the bell showing in the display, the bell does not ring. Have also done bell test, and no sound. Is it broken or is there a setting for turning sound on? Also can't figure out how to change the day the alarm rings.
SOURCE: GapKids Watch turning off the alarm
If you don't have the instructions, the buttons are labeled as follows:
Top Left is "Light" - Button A
Bottom Left is "Mode" - Button B
Top Right is "Start" - Button C
Bottom Right is "Reset" - Button D
With the time displayed, press the reset ("D button as listed in the instructions) and the alarm time should be displayed. While holding the "D"/reset button down, press the start or "C" button to toggle the alarm on or off.
Hope this helps
Posted on Dec 20, 2008
Vicko5000
SOURCE: Sector 250 Chronograph Alarm
the middle dial on the right side of the watch is used to switch from watch settings to alarm settings..
pull the middle dial out to put it in alarm mode.
To set alarm:
-pull the center knob out.
-with it out you can now use the bottom (right) knob to set the alarm.
-pull the bottom right knob out one notch
-turn the knob clockwise or counter clockwise to set the alarm time
-push the knob back in (all the way)
the alarm is now set
if the center (right) knob is pulled out the alarm is ON
if the center (right) knob is pushed in the alarm is OFF
I have owned this watch for about 10 years now and love it.
the past few years the chronograph buttons (on the left side of the watch) were not working well rendering the chronograph and count down timer functions unusable.
repairing a chronographs is expensive and watch makers usually charge several hundred dollars which is not a feasible fee for a watch of this value so i decided to open it up my self and clean it up and that did the trick.. its working like new!
enjoy the watch!
Posted on Jan 09, 2009
SOURCE: Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Posted on Aug 23, 2009
SOURCE: Paul Jardin Chronograph watch
How do you change the battery?? We can't get the back off.
Posted on Sep 16, 2009
  • 3 Answers
SOURCE: Seiko Chronograph Sport 150 - Problem: After
Please folow this link:
http://www.seiko.co.uk/support/instructionbooklets
Enter your calibre code (its on the back of your watch, it will explain which numbers to you on the website), you'll then be able to download an instruction manual for your watch, this will detail how to adjust hands to their corect starting position :)
Posted on Dec 01, 2009
Testimonial: "PDF link states reseting the watch is the problem, and now that I have instructions, I should be able to reset the watch. Thanks"
Do I reuse 2 batteries for my Umbro chrono watch?
Normally the Umbro Chronograph watches having analog and digital clock works on single battery. When u put the battery inside ur digital is working fine but some times for analog hands do not move due to the loose button which is used to move the watch hands. So pull it out again and insert it agin gently till tick sound comes and u r good to go.
Let me know if ur watch is working successfully:)
Jan 27, 2017 | The Watches
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
I just replaced the battery on my seiko. Watch is working fine EXCEPT the alarm will not ring. Help!
mcdevito75 here, By pressing the MODE button until you get to the alarm function and turn it to on or, set an alarm time for the alarm to go off.
Oct 11, 2010 | Seiko Coutura Chronograph Watch
On the casio a158w how do I turn off the hourly chime? Thank-you
Hi Ms. Sophie Desro,
If the alarm has sounded, press "A" (top left-hand button) to stop the sound.
To switch the Daily and Hourly Time Signal on and off:
Press "C" (lower right-hand button) while in alarm mode in sequence:
a. }}}} + BELL = Both alarms on.
b. Display Blank = Both OFF.
c. }}}} = Daily alarm on only.
d. BELL = Hourly Time Signal on only.
Test the alarm by holding down "C" to sound the alarm.
Please note b. and c. to turn off the alarms.
For more information, Casio has an Operational Chart for your watch, Module QW-1275. You may download a PDF file here:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1275.pdf
Try this and let me know if this works. Thanks.
Regards, Bill
Sep 16, 2010 | Casio DW290 1V Classic Alarm Chronograph...
Coutura Chronograph Watch: set the alarm on a coutura chronograph...
pull the crown out 2 clicks.... set the alarm the same as your current time on your watch..... push the crown in 2 clicks..... than pull the crown out 1 click ..... set the alarm at the desired time with the lower button..... than push the crown in 1 click .... the alarm is ON
or go to this address http://caliber.seikowatches.com/ select the desired language than - alarm chronograph and play the alarm option on your right
May 17, 2010 | Seiko Coutura Chronograph Watch
I have an athletic works stopwatch. All it says on the front is chronograph. I bought it at Walmart. It has 3 buttons on the top and one on the bottom. I can't find the directions. I can't get it to...
I have the same Athletic Works stopwatch. I just figured out how to turn off the alarm: press either of the two mode buttons (middle top, or bottom right) until you see the regular time displayed (the seconds will be changing, but nothing else, and nothing will be flashing). Press and hold the reset button (top left); while holding down the reset button, press the start/stop button (top right). Watch the bell icon on the display in the upper right corner; with each press of the start/stop button you will see the bell either appear or disappear. When the bell disappears, release the reset button. The alarm is now off.
Apr 14, 2010 | Watches
Mar 03, 2009 | Bulova Watch
Need instructions for Timex 1440 Sport watch
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to sesume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Nov 22, 2008 | Timex 1440 Nylon watch
10 year old alarm chronograph
good morning ! your anadigi chronograph 388 is veery easy to operate,just change the battery then short the reset button the fix the case back and set the time use the crown and the button to set the time calendar and the alarm !thank you ! god bless !....
Sep 01, 2008 | Casio DW290 1V Classic Alarm Chronograph...
Watches Logo
19 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
