Spin cycle doesnt work, its not the belt
The spin cycle leaves clothes soaked its not the belt
  • Sharon Mayes Jan 09, 2013
    the washer doesnt even spin on spin cycle
Hi I got same problem but no one seems to be answering me iether
Posted on Jan 09, 2013
  • 68 Answers
SOURCE: Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Posted on Jan 17, 2009
  • 250 Answers
SOURCE: spin cycle leaves clothes very wet
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Feb 09, 2009
  • 58 Answers
SOURCE: Model MAV3855AWW revision 26
The problem is 2 fold. The "knocking" noise is indicative of brake rub. The fix is to replace the rotor & stator. The reason that your clothing are coming out wet is because the brake is dragging along a polished stator when in spin and cannot get up to its proper speed as a result. The 2nd item that should be replaced is the thrust bearing assy. This is what enables the transmission to transition from agitation to spin... Hope this helps... Bill
Posted on May 18, 2009
  • 415 Answers
SOURCE: Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Posted on Aug 20, 2009
BIKER T
  • 909 Answers
SOURCE: will not do final spin cycle leaving clothes
Your drain pump has something lodged in it. Remove drain motor, open it up and inspect for obstruction. remove it then reassemble.retrywashing cycle.
Posted on Nov 12, 2009
Kenmore elite model 11027052602 clothes wet after spinning cycle why
You might have a restriction in the outlet hose. Worse, you might have a bad pump.
It is easy to check for the constriction. Pour water into the tub, set the timer for the spin cycle and watch how strong/fast the water leaves the hose. Check for water beneath the tub.
Oct 07, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine does not spin well and leaves the clothes soaking wet
Likely a bad belt or tensioner causing it to slip. Take it apart and look to see what the belt is doing or call a repair man.
Apr 22, 2012 | Whirlpool Washing Machines
Even after doing the spin only cycle, my clothes
Is drum spinning on spin, check belt tension if not. if this is ok then it could be problem with motor brushes, or if it is induction motor it could be a capasitor
Feb 08, 2010 | Washing Machines
Will not do final spin cycle leaving clothes
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Brand new GE Profile leaves clothes soaking wet
It is under warrenty call the store where you bought it and have them look at it. If you mess with it it will void your warrenty, belt may not be working or transmisson may not be shifting. The house call will be at no charge.
Sep 10, 2009 | GE Profile WPRE6150KWT Colossal Capacity...
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Jan 17, 2009 | LG WM1814CW Front Load Washer
Washer spin cycle
Hi joystoy
I would start with the belt. it sounds like the belt is going and that is the least expensive to fix. try that, if that doesnt work then i would call a repair company to look at it.
brent
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Clothes wet after spin cycle
if its not the belt its your brushes in the motor that need replaced
Jan 04, 2008 | Hotpoint VBXR1090D Top Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
