How do you fix a INF Install failure - Computers & Internet
  • 2,878 Answers
INF are device driver files. Remove from object from startup, or re-install drivers for affected hardware.
You may be also using the incorrect version of the driver. Match OS, make and model for correct driver to use.
Posted on Jan 10, 2013
Cant install u-disk to pc
Do you have internet access with this computer?
If so, you should be able to google the brand and model number and find a driver to download.
I would give that a try.
There is no need to reinstall windows to fix this. The driver or inf file is damaged. Visit another computer with win xp, search for files named usbstor. Copy files usbstor.inf and usbstor.pnf into windows/inf folder and usbstor.sys into windows/system32/drivers. Now just search for new driver and that's it, usb storage will be recognized.
Car Transmissions
Jun 12, 2012 | Audio Players & Recorders
Sir, i need cq50-21us windows xp pro sp2 driver path
Try the following drivers,
XP Drivers for CQ50-210US
NVidia Chipset,(install and reboot before other drivers), here
NVIDIA GeForce 8200
Nvidia ForceWare X 179.28 for Windows XP/2K 32bit, here
3-step process to install:
1. Download driver, double click and select extract,
2. Download modded INF and replace original INF in extracted folder,
3. Install & reboot.
or you may try other versions, joint their forum for further details
Note:
If you found errors (hopefully it has been fixed) when installing Nvidia 8200M G video driver, you need to force install the driver.
Pieter's INF forgot to put hardware ID for 8200M G, see this post.
MS-UAA (required with a reboot before Audio, Modem and nForce HDMI Audio drivers), here
Conexant SmartAudio 221 (fix microphone problem by forum user) here
How to install:
Unzip to a folder.run installer.
if it errors use Device Manager.
From Device Manager,right click "Audio Device on HD",choose Update driver,
No to connect, Install from a list or specific location,
Select Don't Search, I will choose the driver to install,
For the Hardware Type select 'Show All Devices'
Remove the check from "Show Compatible Hardware" and click on "Have Disk".
Next...browse to the unzipped folder and choose the "WiSVHe5.inf".
Ignore XP when it complains.
Reboot.
Conexant HDAUDIO Soft Data Fax Modem with SmartCP Driver, here
nForce HDMI Audio Driver, here
.Net Framework(required before Intel Wireless and HP Quick Launch Buttons), here
HP Quick Lauch Buttons, here
If you had Intel PRO/Wireless Driver, here
If you had Atheros Wireless driver, here
or if it does not work try here
If you had Broadcom Wireless, here
Realtek usb 2.0 Card reader, here
Synaptics Touchpad Driver, here
If you had Bluetooth, here
If you had for 7 unknown devices (buttons drivers), here
Installation --> right click machine.inf, choose install.
Good luck
Oct 01, 2010 | HP Compaq Presario CQ50-210US Notebook
I have problem in realtek hd audio driver failure error code oxe0000227. how to rectify immediately
first reformat your pc and update inf driver then download MICROSOFT UAA HDA this driver from intel web site. and install it on pc then install sound card driver.
Dec 11, 2009 | MSI 945GM2 H-F (816909015911) Motherboard
I have an acer Aspire 5100. wont start up
Install xp cd,boot to xp cd,recovery,press enter for password, select 1 for C: Type:Fixboot Agree,type:CHKDSK C: /R Once its thru, type:EXIT Let xp start,remove cd.
Oct 01, 2009 | Acer Aspire 5100 Notebook
Installation failure Error Situation Code 11612095
formet the hdd and install the win xp and after install the HP J4680 driver in pc and ....check
Jul 15, 2009 | HP J4680 Office Jet All-In-One Printer
Hpc20155.xml is needed. i don't know why this happened. i can't use my printer HP LaserJet P2015.
You have to end a .inf file from Microsoft to get it to work. Open up c:\windows\inf\oem16.inf in your favorite text editor. Search for "hpc20155.xml" and you will find this section:
;hp LaserJet 2015 files
[DATA_FILES_20155]
hpc20155.xml,,,0x00000020
hpzsc43e.dtd,,,0x00000020
hpc20155.gpd,,,0x00000020
hpc2015b.ini,,,0x00000020
Change hpc20155.xml,,,0x0000002 to hpc2015.xml,,,0x00000020 (take out the last 5 in hpc20155.xml). Save it and go back to add a new printer in windows. This should fix the problem.
There is one thing to add, however: the name of the oem inf file might be slightly different on different computers. Easiest way to find it is to go to Start –> Search –> Files and Folders; Set your search location to C:\Windows\Inf, and enter “hpc20155.xml” in the field labeled "”A word or phrase in the file”. If you get multiple results, you’ll have to check them one by one; just follow the rest of the bjones’ walkthrough from that point on.
Thanks.
Jul 01, 2009 | Office Equipment & Supplies
INF error with crystal eye webcam on vista premium.
you're crazy installing vista on that netbook. acer doesn't have vista drivers for that model.
Apr 26, 2009 | Acer Aspire One PC Notebook
I have Aspire 4730Z acer laptop. but can't install blue tooth. when going to install driver from utility CD showing no device found. let me clear how can I resolve the problem
Method 1: Rename the Bth.inf file loadTOCNode(2, 'workaround'); Rename the %WINDIR%\inf\Bth.inf file to Bth.bak before you install or reinstall the third-party device or stack. When you rename the file, you prevent Windows Plug and Play PNP from using that INF file to install the Bluetooth driver that is included with Windows XP SP2. To rename the file, follow these steps:
  1. Click Start, click Run, type %windir%\inf in the Open box, and then click OK.
  2. Right-click Bth.inf, and then click Rename.
  3. Rename Bth.inf to Bth.bak, and then press ENTER.
  4. Install the third-party Bluetooth driver.
Method 2: Update the Bluetooth driver in Device Manager loadTOCNode(2, 'workaround'); To replace the Windows XP SP2 installation of the Bluetooth stack, update the driver in Device Manager. When you do this, specify your third-party driver. To update the driver in Device Manager, follow these steps:
  1. Click Start, click Run, type devmgmt.msc in the Open box, and then click OK.
  2. Locate the device.
  3. Right-click the device, and then click Update Driver.
  4. Follow the steps that appear on the screen in the Hardware Update Wizard to specify your third-party driver for the Bluetooth device.
Mar 05, 2009 | Acer Aspire 5610-4648 Notebook
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Service installation section in this INF is invalid
If the player is showing up in your Windows' Device Manager under "portable devices" with a yellow "!":
1.) Right-click the yellow "!" and choose "update driver".
2.) When given the option to connect to Windows Update, choose "no, not this time" and click next.
3.) Choose "Install from a specific location (advanced)" and click next.
4.) Choose "Don't search. I will choose the driver to install" and click next.
5.) Click the "Have Disk" button. Browse to C:\Windows\inf and choose the file marked "wpdmtp.inf"
I can't believe the generic players have such crappy support when so many people have this problem! I think the Windows file problem might be caused by "compressing old files" when you do a disk cleanup.
Mar 17, 2008 | Audio Players & Recorders
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
