Question about Kenmore 75503 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
Kenmore Elite Dual Fuel Range 790.75503 burns too hot
The gas burners, even the smallest one set at lowest setting burns too hot.
jsrock516
  • 5911 Answers
SOURCE: Gemini Range Dual Burner
Unfortunately, you cannot repair one element of a dual burner. It all comes as one unit. When one portion of a dual or triple element goes bad, you must replace the whole element. I believe the part number is 1032746 and runs about $70. You will have to lift the glass top to access the burner elements. If you decide to pursue this on your own follow these steps: 1. Unplug range and/or turn off main breaker. 2. Open oven door to access screws under front edge of cooktop. Remove two screws and the top should tilt up. 3. The top will not stay up on it's own, so you will need some assistance holding it up. Some ranges have a couple of disconnect plugs that you can unplug, so you remove the entire top and lay it somewhere to work on. If this is the case with yours (as I suspect it is), lay some soft towels down on the kitchen table or counter top and lay the cooktop upside down. This will make it much easier to work on. 4. Remove affected element by disconnecting the wires first. You may want to write down how they came off, so you can be sure to reconnect them in the right order. 5. Remove mounting brackets holding element in place. Pay particular attention to the numbering scheme on the bottom of the element and where the brackets are mounted. The new element usually doesn't come with new brackets which means you have to take the brackets off the old element and put them on the new element. Make sure you install them in the same numbered holes as they were located before. 6. Reconnect wires and reinstall cooktop, making sure you reconnect the disconnect plugs if equipped. Now, be careful when working on the cooktop while it is upside down. Make sure you don't apply too much pressure on the glass or you could crack it. Also, use extreme care NOT to touch the element surface as the oils from you hands can cause hot spots and effectively ruin it. The bake light material in which the element is mounted is also very fragile. DO NOT put to much pressure on it or it may crack and break. Once you get the cooktop reinstalled and power reapplied, op test it to make sure BOTH elements are working. It is normal to see a little bit of sparking at first with new elements and/or an odor. Test the entire range of the element and make sure it regulates like it should. I hope this helps you.
Posted on Aug 04, 2007
SOURCE: Kenmore Elite 790 Range
I can't believe I found this today. Today, my Elite 790 inner coil also stopped working! A little too coincidental.
When I turn on the burner, I can hear like a relay click on, but it does not heat. The middle and outer burners are fine.
Posted on Dec 21, 2007
  • 148 Answers
SOURCE: Kenmore elite 790 79363400 dual fuel oven door does not close all the way a
if your locking it to make the light goes off it sounds more like the light switch on the oven needs to be replaced
Posted on Jul 08, 2008
jtbjtb
  • 135 Answers
SOURCE: Kenmore elite dual fuel range top ignitors clicking like lite mode is on, but it's not.
You probably have a shorted spark module. send model # for more help. Hope this helps!
Posted on Feb 16, 2009
SOURCE: Kenmore electric range 790. Both the broil and
I have the same problem... I checked both elements and they are fine. I was wondering if it was the ERC. Have you fixed yours yet? Please let me know.
Posted on Dec 06, 2009
I have a Belling Richmond dual fuel cooker (electric & LPG) and can't simmer anything on the burners because the flame is too high even at the lowest setting
Most gas ranges and cooktops are set for natural gas at the factory. If the flames are too high this could be an indication the range or cooktop was improperly converted from a natural gas setting to LP, (Liquid Propane) gas setting. Contact your installer or local Gas Company to correctly convert the range or cooktop.
Dec 10, 2016 | Belling Kitchen Ranges
Elite dual fuel range/oven. Why isn't it heating past 100 deg and burner igniters do not spark?
sadly it sounds like you need to call a service repairman . being an appliance that can explode I do not suggest you try and fix it yourself .
Oct 27, 2015 | Kenmore 30" Slide-In Dual Fuel Range...
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
Kenmore dual fuel oven model 79075503201. bottom element in oven will not heat. element has a resistance of about 22 ohms. 110v on each leg while off. 110v on each leg during bake cycle. I suspect the...
It seems that the control board is faulty. You would need to get the board repaired since it is no longer available for purchase from the manufacturer. You get the board fixed from www.partsimple.com at the lowest price compare to the rest of competitors online.
Here is the direct llink to the control board: http://www.partsimple.com/318010102-frg-r-12.html
Frigidaire Range Control Board Repair Service 318010102
Mar 15, 2011 | Kenmore Elite Stainless Steel 40" Dual...
Kenmore elite dual fuel range - all burners' igniters are clicking without being in use /trying to ignite the burners
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 06, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Gas cooktop flames are too high
are you natural gas or lp
and is your range set correctly
is your flame blue
or orange
Sep 15, 2009 | Kenmore Kitchen Ranges
Burners burn too hot at lowest settings
what type of range? what type of gas? propane or natural gas? thats a start...
Jan 15, 2009 | Kitchen Ranges
Kenmore 75503 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
475 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
