Question about Endurance T3 Treadmill
The motor cant run - Endurance T3 Treadmill
    Top Expert:
  • Endurance Master
  • 12,223 Answers
Step 1:
see the video and fix it. God bless you
Step 2:
if the problem persist
a)test the input voltage motor, if there ARE voltage the motor need repair, see my personal TIPS for motor help.
b) adjust the output voltage board , for input voltage motor, if there ARE not , the board is faulty, need replace. see the diagram attached.
Posted on Jan 09, 2013
The motor for the brush on a shark SV75 14 hand held vac fell out when I dropped it as repairing the small plastic wheel for the belt. Thanks
might just be running on the spring u need to get carbon brush in or the spring will reck armature
Apr 14, 2015 | Washing Machines
Wont turn on
a huming motor is all ways bad news,,,,the motor has burnt out or is jamed so it cant turn,,,and that will burn it out as well!
most motors have two windings in there field coiles the start up winding and the run winding,,,if the start up winding has a fult in it it cant "kick start" the motor and if it cant "kick" it over the second run winding wont take over,,,so the motor stalls,,and it just humes??? but it gets very hot doing this!! causing a burn out!,,,,thats about the long and the short of it
boring huh? fitting a new motor should fix it,,,if its worth the price of a motor, plus fitting,,,
Jun 29, 2010 | GE DBXR463EBWW Electric Dryer
Necchi Model 535 FA - Replaced drive belt, after running machine for approximately 5 minutes, machine locks down with motor running, motor pully burns plastic belt into.
The motor is running.That is confirmed that motor is fine.But the wires from motor has to be checked.the motor connections are getting short and this is causing the plastic belt to burn.Check the motor as well as its connection.
thanks.
Jun 05, 2010 | Necchi Sewing Machines
Onan Portable Generator - 5000 , Model# 6500: I have china generator capacity is 2700 watts but ...
Alternately,
• Turn-off all lights first.
Run your pump or water start motor.
• When the motor is running,
Turn on the lights , one at a time.
May 18, 2010 | Watts Onan Portable Generator - 5000 ,...
Cant get my 125cc motor bike going for the first time
hummm check your electrical connections make sure you have the stop run switch is in run position,you have fuel flow to the carb, make sure you are getting spark to the spark plug by using a extra spark plug remove the plug cap and ground it to the head and kick start the engine and see if you are getting spark to the plug.
hope this helps
May 05, 2010 | 2001 Yamaha TW 125
I have a necchi model number 537fa. the light comes on but the pedal and motor isnt running. you can manuely move the needle up and down, but the machine isnt running. could it be a belt?
If it is a belt problem, you should be able to hear the motor running. If you cant hear the motor running then it has to be the foot control or cord or possibly the motor.
Apr 20, 2010 | Necchi 3537 Mechanical Sewing Machine
Cant get running
computer problem??
Apr 14, 2010 | 1998 Dodge Ram 1500 4WD
2002 gmc sierra abs pump runs all the time
find the relay for the abs motor, disconet the raley if motor is off replace the relay if on check for code on the abs system.
Mar 26, 2009 | 2000 GMC Sierra
Washers not working on ford focus
check the motor or hose probable clog. hope this help
Dec 17, 2008 | 2001 Ford Focus
Endurance T3 Treadmill Logo
49 people viewed this question
Top Endurance Exercise & Fitness Experts
Howard
Howard
Tom Chichester
Techmotionusa.com
Techmotionusa.com
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
