Question about GE Profile WPRE6100G Top Load Washer
Ge profile top loader "fill" knob broken
The capacity knob broke as I was turning it to the "reset". Do we take off the entire panel to try to fix?
    Scholar:
  • 105 Answers
If it came off cleanly no, but if the glue they sometimes use has a piece unattainable to your grasp, then yes.
Posted on Feb 10, 2009
Dial won't set
you can possibly remove the knob itself, and see if you can turn the dial itself. if you can, then you can probably see the knob is broken. if if the shaft turns, but doesn't move the gears, then you will just need a new dial switch.
Nov 19, 2013 | GE Profile WPRE6100G Top Load Washer
GE High Efficiency washer model WPRE6150KWT--there appears to be a problem with the timer. A 47-minute load was still running after 80 minutes and the timer displayed 23 minutes left in the cycle. I've...
I would check screens on valve and hoses to be sure they are not stopped up. Also an unbalanced load can cause that if it's a top loader. Suspension rods would be the problem in that case.
Oct 11, 2017 | GE Profile WPRE6150KWT Colossal Capacity...
I can no longer set the water level on my GE WPRE615. I'm guessing I need to remove the top panel to replace the knob - but how do I remove the knobs so I can remove the panel?
They usually just slide up off the shaft. There may be a tiny grub screw holding them in place but you will only tell that if you look closely all round the knob itself.
May 19, 2012 | GE Profile WPRE6150KWT Colossal Capacity...
I have a ge profile top load washer and the knob is broken how do I remove it to fix it? The cycle knob just spins I am unable to wash,
I would look at some of the internet appliance parts sites for a replacement part. Uusally a good illustration will give you a clue as to how it is attached. You can also contact GE internet site.
http://genet.geappliances.com/DocSearch/Dispatcher
Worst case senerio is the timer. Post the question to GE.
Jul 10, 2010 | GE Profile WPRE6100G Top Load Washer
TOP LOADER KENMORE WASHER FILLS UP BUT DOES NOTHING ELSE.
Sounds like belt is broken. Open front cover and look at belt, if broke replace. If not broke try unplugging for 2 minutes, plug back in then open and close lid 7 times slowly, this should reset the electronic motor.
Jun 05, 2009 | GE WBSR3140DW Top Load Washer
GE Top Loader Model WASE422OAOWW Profile Prodigy
you have a motor issue, do not run the machine. ther is a risk of fire.
May 26, 2009 | GE Profile Prodigy WPSE4200A
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Ge timer on washer is broken
If it no longer clicks, the timer assembly will need to be replaced. If just the knob broke off, the timer should be good.
Mar 16, 2008 | GE WDSR2080D Top Load Washer
GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Jan 29, 2008 | GE Profile Prodigy WPSE4200A
GE top load Super Capacity 16 cycle washer (one year old)
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing it turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Dec 18, 2007 | GE WBSR3140DW Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
153 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
