Question about Azeca BTC008 Stereo Bluetooth In-Car FM Transmitter
How to pair a BTC008 fm transmitter
What is the pairing code
Does the shb4000 pair with more than one device
Not at the same time, but after you paired it with one transmitter, you could pair it with another. Make sure the first transmitter is switched off, because as long as it is connected to a transmitter, it won't accept another source.
Dec 27, 2014 | Philips SHB4000WT Bluetooth Stereo Headset
Great sounding speaker, but nothing but trouble with the bluetooth. It appears that I can only have one device paired at a time. In order to connect another device, it breaks the current pairing. A
Yes this is a 'feature' of Bluetooth. (I have never seen the point of Bluetooth... Wi-Fi does everything it does, but better !)
It DOES usefully enable a phone or tablet to play though headphones or speaker and to use a headset 'cordlessly'...
Consider instead a 'Bluetooth Receiver' (under US $10 from China) connected to a FM Stereo Bug (Transmitter) - Then you can use any number of quality FM Radios (including phones with built in FM) up to 50 metres or so away...
example: http://www.ebay.co.uk/itm/Wireless-3-5mm-Stereo-Audio-Adapter-A2DP-Bluetooth-Dongle-Transmitter-Receiver-/141227224470?pt=UK_Home_HomeDecor_Accessories&var=&hash=item20e1cc6d96
Dec 10, 2014 | Marshall Stanmore Bluetooth Speaker
How to pair the samsung galaxy s4 to the jabra cruiser
  • Touch Apps
  • 2.Scroll to and touch Settings
  • 3.Ensure Bluetooth is turned on
  • 4.Touch Bluetooth
  • 5.Slide the Power switch to turn the JABRA CRUISER on
  • 6.Press and hold the Multifunction button until you have a rapid flashing blue LED
  • 7.Touch the JABRA CRUISER in the list of devices
  • 8.The JABRA CRUISER is now paired
  • 9.The JABRA CRUISER and Galaxy S4 are now ready to be used
  • 10.Press the FM button in order to start streaming audio via the FM transmitter. The FM LED will turn red
Oct 01, 2014 | Jabra Cruiser InCar Speakerphone Black
Sennheiser HDR120 - missing transmitter / alternative OR replacement?
The system is working in the 860 Mhz range, so not that common. Most of the time it is cheaper to by a complete new system then to tray to buy components. Just keep looking in the thrift stores you find a transmitter for this headphone for a good price.
Jun 15, 2014 | Sennheiser HDR 130 Consumer Headphones
Bluetooth adapter for TV
User Fm transmitter instead of Bluetooth transmitter......i doubt bluetooth adapter will work on tv with headphones..
Dec 26, 2013 | Eforcity Computers & Internet
Isound road talk transmitter paring pin code?
Just purchased, couldnt find documentation in the package, tryed toguess the code per usual standard device pin codes. 1234, 0000, to no avail... but I looked a little harder for the documentation in the package, subsequently found the instructions behind a false panel, and the code for pairing is 9999... there you go. Good luck everybody!
Aug 02, 2012 | DreamGear Radio Communications
Got a Nikkai Bluetooth FM Transmitter (A17KC). Lost the instructions and can't remember the PIN code for bluetooth pairing. Anyone help.
Hi Dave
Got one today- the instructions say use 8888.
You have probably found your answer but hopefully this might be useful to anyone else looking for the answer.
Sep 26, 2011 | Radio Communications
Is it possible to connect my PC to my outdoor speakers? I want to play music outside using my PC. Is there a special connector that I need?
There are a couple of ways to go about this. The first would be to locate a similar computer speaker system set up outside - provide power and extend the cable to them - if not too far. When you want to listen to the outside speakers, plug the cable into the headphone jack of the computer. Adjust volume and enjoy.
Another way, would be to buy (or build from kit form) a low power FM transmitter. These devices are available in mono & stereo types and will play over all FM radios and stereos in a 50 to 300+ foot radius (depending on antenna, wall construction, transmitter power, etc.) when they are tuned to the transmitter frequency. These can be found for under $100 or built for as little as $30 or so. The upside to this method is that the music is available over ALL radios nearby.
Still another way is a wireless speaker system. This works like the FM transmitter, but will only work on these particular speakers. These will require power only - but some will work from internal batteries as well as AC power. The system includes a small transmitter, power cord & cable to plug into a headphone jack - all for use at the computer, and two speakers - each with a power cord as well and possibly a remote control.
Use of a spare pair of old stereo speakers will probably not work as the computer's sound card rarely develops more than a watt or two - and most home speakers require 10 or more watts to be driven properly.
Sep 18, 2009 | Bose Indoor/Outdoor Speakers (Pair) -...
I cannot get my nokia 6133 to pair with bluetoothe adaptor wich is a wireless gear in car speakerphone with fm transmitter
you have to give the passcode ,.eg"0000",. &it does not support fm play via bluetooth,.,., coz it needs antenna .// but in bluetooth does't act as antenna for fm ... try it
Aug 27, 2008 | Cell Phones
Azeca BTC008 Stereo Bluetooth In-Car FM Transmitter Logo
Top Azeca Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Azeca Radio Communication Expert? Answer questions, earn points and help others
