How do I reduce scanned file size of .pdf document on Canon MX860 scanner? One scanned page is 2MB!
Scanned .pdf file size is too large - could not e-mail a 10 page .pdf How can I reduce the file size of scanned documents, but still save them as .pdf?
  • 3 Answers
Here you will find a product to compress your PDF documents http://www.systoolsgroup.com/pdf-toolbox/compress-pdf-files.html
Posted on Feb 08, 2013
  • arronwall1
    arronwall1 Mar 10, 2014
    I am testing another PDF compressor these days. Do you have any ideas about it? Or any good suggestion? Thanks in advance. Best regards, Arron
  • arronwall1
    Here are the tutorials about the pdf compressor.
3 Suggested Answers
PegBox60965
  • 51 Answers
SOURCE: Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
Posted on Dec 31, 2008
HansPP
  • 2510 Answers
SOURCE: 1) whether the scanned document from this
The answer is yes to both questions. Follow the instructions below:-
Go to Adobe Acrobat. Click on FILE. Click on CREATE PDF. Click on FROM SCANNER. Click on SCAN. You should now be scanning your first page, after completing it you will be asked if you want to scan any more pages or close. Select to scan more pages till finished. You can also select to have Acrobat do an OCR after the scan which will allow you to search the document. To do this, click on DOCUMENT, click on RECOGNISE TEXT USING OCR and click on START
Posted on May 10, 2011
How do I scan multiple documents and email them as one attachment
1. Click PDF on the Custom Scan with One-click tab or click PDF in the one-click mode screen to open the PDF dialog box.
* If you wish to convert the text in a document to editable text data, scan the item with the OCR. The precision of OCR is affected by the nature of the scanned original
2. Select the type of document to be scanned.
Important
To scan correctly, select a document type that matches the document to be scanned.
3. Select a file type to save the scanned image.
Select PDF, PDF(Multiple Pages) or PDF(Add Page)
Important
Click Set... to open a dialog box and specify the PDF compression type and other advanced settings for creating PDF files.
4. Place the first original on the scanner and click the [Scan] button at the right bottom corner of the PDF window.
5. When scanning is completed, place the next original and click the [Scan] button.
6. Repeat scanning by clicking the [Scan] button until you finish all the originals.
7. When all the original is finished, click the [Exit] button.
8. When the scan is complete, it automatically starts the application program that displays PDF files and opens the scanned image file in it.
To scan a text document or black and white document, you are recommended to set the Scan Mode to Black and White or Grayscale.
You are recommended to limit the number of pages in any one multiple PDF file to 20 or less if you are scanning a color document with the Image Quality set to 300 dpi and the size to a setting equivalent to Letter size.
Aug 07, 2013 | Canon MP Navigator EX for Windows
Scanned documents' size is too large (the least I got was 600kb), how can I scan a document to a PDF with the normal size of 200kb?
You need to install a PDF writer program first. There are quite a few freeware PDF writer programs on the Internet you can download one such as CutePDF.
Scan your document the click on File - Print and select the PDF writer as the printer device. Then name and save the PDF file.
Feb 09, 2011 | HP Scanjet 5590 Flatbed Scanner
I'm finding that the scanning on the brother MFC-7840W creates a big file (a two page document is over 2MB). Is there a way to condense the pdf files?
Hi, you can reduce the file size by decreasing the DPI (dots per inch) or resolution of the scanned image. This can typically either be done from the scanner's control panel or from the software installed on your computer. The less DPI you set it for, the smaller your file will be.
Some scanners will also allow you to compress files. If the MFC-7840W will let you, the option would be in the software program, and it should say "enable file compression" or "enable image compression" or something similar.
Sep 14, 2010 | Brother MFC 7840W Printer
I scanned a document, but when I go to attach the file, it stays in attaching files forever??
Greg, Do you mean that when you want to send it by email it keeps attaching the file forever? If yes then check the size of the scanned document. What happens is that the moment you attach a document to an email Windows start sending it to the email server and that takes time as uploading is slower than downloading. And if the file a large one as scanned documents can be, then it will take that much longer. Try a smaller document first. Size wise small document. If that works fine then you can try larger documents. yes it may be time consuming but there is no price for mental satisfaction. To reduce the size of the scanned document, reduce the pixels in settings of the scanner. or reduce the page size. You will find the document reduced many times over.
Nov 19, 2009 | Gateway Audio Players & Recorders
Canon MX860 Scan to PDF 10 times bigger than source PDF file
My suggestion would be to check your scanning software and change the quality of the scan. If it is a document - you really don't need a quality above 200 - maybe even lower if it's available. I would guess your scanning software is defaulting to a much higher quality.
Sep 21, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Don't know how to set scanner for multiple page scan into single pdf file
The supplied Canon software is horrible, but it can be done!
Launch ScanGearStarter, choose advanced tab and click preferences button, then select scan tab.
Untick box "Automatically quit ScanGear....." then click ok.
(This box being ticked totally prevents multipage single file scanning).
Now choose simple mode tab, select the document type, dpi and document size.
Now click the green "Multi Scan" button, place the document on the scanner glas and press next in the new window.
The page will be scanned and the ScanGear window will return, just click "Multi Scan" again and place next document, press next. Keep repeating until all pages are scanned, then close the ScanGear window.
This will bring up a third window showing thumbnails of each page, any of these pages can be deselected if required.
The other important step is to choose from the pull down list Saved as Type: "MultiPagePDF".
Choose the location for saving the file and click save.
Hallelujah! .......stupid software.
Jun 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Dec 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
Scan images file size seems very large
That entirely depends on your scan settings. The resolution has a huge impact on file size - doubling the resolution from, say. 150dpi to 300dpi actually quadruples your file size. That being said, your scans are probably saved as BMPs. If you scan to Paint or a proprietary image editor (like Photoshop), then you can save in a compressed format like JPG or PNG and reduce the file size some more.
Bottom line - if you're scanning a full size (8.5x11) page, then less than 2MB per page is pretty decent, especially if the file is a BMP. If these are 4x6 photos, then it's still not bad if you're using a resolution like 300dpi. My digital camera takes photos at 5megapixels and the files are often 1-2MB each, and those are just photos.
Jul 08, 2008 | Lexmark X7350 All-In-One InkJet Printer
CD-4050 Scanner
First scan a single page and note the file size. Then scan two pages and check if the file size is changed. If the file size is changed, then you have problem with your viewing software. If the file size is same, then check your setting in the scaniing software.
S. Moha, India
Nov 29, 2007 | Canon CD-4050 Path-Through Scanner
620 people viewed this question
jasbo
jasbo
