Question about Olympus SP-560 UZ Digital Camera
Where are my pictures?
Camera screen shows that the pictures are being recorded to the memory card, but once I put the memory card into the computer, it says there are no pictures to display. When I turn on the camera and push the playback button, I can see all of my pictures. What is the disconnect?
  • Savannah Jan 10, 2013
    I have found the solution. It turns out my card reader at work is too outdated and cannot handle the 2g card.
  • Olympus Master
  • 32,281 Answers
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Posted on Jan 10, 2013
    I am using a memory card reader. I am sorry I didn't make that clear in the description.
Jeap
  • 114 Answers
SOURCE: Camera does not work when memory card is inserted
just look in the slot for a short circuit. some times it does hapen on cf cards or on xd cards.
Posted on Jan 19, 2007
SOURCE: memory card error
The problem seems to be that the card has been formatted incorrectly (probably by your computer, if you used it in a card reader?). Unfortunately the camera can't reformat it itself, and default computer formatting is incompatible. You'll want to download the program Lowlevelformat.exe from this website--http://olypan.quotaless.com/forum/viewtopic.php?t=8, install it, reformat your memory card with it, and the camera will be happy with it again.
Posted on Jul 01, 2007
  • 3 Answers
SOURCE: Not focusing
Do you hear any unusual friction noise while the lens assembly projects out.. if so then the traction assembly of your zoom barrel has developed mechanical obstruction, in which case it has to be serviced. Take it to the service centre and the problem will be solved. If the zoom assembly does not fully extent to its homing position, the camera retracts and lens and powers itself off. Enjoy
Posted on Sep 06, 2007
SOURCE: camera acting strange.
i have the same problem. wat did u end up doing with it?
Posted on Dec 02, 2007
SOURCE: "Card-Cover Open" Warning
Have same problem when camera is used underwater. Take out battery and xd card. Put camera in front of fan with lid open and facing fan for several hours.
Posted on Jul 01, 2008
Why, when i take a picture and try to see it it comes up with a picture error on my sp-600z camera
The manual says:
Problem with selected image
Use photo retouch software, etc. to view the image on a computer. If the image still cannot be viewed, the image file is corrupted.
But try this. Switch of the camera, remove the battery and memory card. Check if all contacts are clean and shiny. On the battery, on the memory card and in the camera. Then replace the battery and memory card and switch on.
I hope this solves the problem.
Jun 04, 2014 | Olympus SP-600UZ 12MP 15x OPT Zoom Digital...
Please Help
hmmm you should try the followings:
First insert your SD card and try to make a copy of your pics from camera memory to your SD card. And then use this SD card to your computer.
Or Using Camera manufacturer and model no. search some driver and software for you so that you can transfer the pics to computer.
if still not fix, let me know your manufacturer and model no.
Thanks
iqbal
Mar 23, 2008 | Samsung Digimax S630 Digital Camera
When trying to take a picture or record a movie, the screen is a solid light pink.
try an sd card from another source. the format function of the camera should be used to prepare the sd card for the camera before you take pics with it. this may be a format issue with nintendo. format will erase all images on card, so save them first somewhere else.
Jun 14, 2013 | Cameras
Communication error shows when trying to download photos
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Feb 05, 2012 | Fuji FinePix A360 Digital Camera
My lumix DMC-FS5 camera keeps saying "Pictures will be recorded to to built-in memory". No pictures have recorded to the memory card and I cannot retrieve pictures that have been taken and that...
In the camera menu, you will find an entry for "copy" which gives you the option to copy the internal memory to a memory card. Once that is done, remove your card, go back into the menu and find "format"...follow the on-screen instructions to erase the internal memory and promise yourself to never use it again. After that, your memory card should work properly in the camera.
Apr 13, 2011 | Panasonic Lumix DMC-FS5 Digital Camera
Brand new camera, inserted the flash card, formatted per instructions. I take a picture but I can't play anything back. It does not record pictures on the flash card. If I remove the flash card and use...
On some cameras, once you use the internal memory, you must format it and completely erase it before a regular memory card will work. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions. Then, never use the internal memory again.
Feb 17, 2011 | Intova CP9 Digital Camera
When i have my memory card in my computer it shows i have pictures but when its in my camera it shows no pictures
Typically your digital camera uses a particular directory (folder) on the memory card, which it creates as part of the formatting process. The camera only looks at that directory, but your computer will look at the whole card. So, you computer may see pictures that your camera does not.
You should copy any pictures you want to your computer for safekeeping and then insert the card into your camera and format the card from your camera's menu. This is good practice to do anyway. Now any pictures your camera records will be in the correct directory.
Nov 28, 2010 | VistaQuest VQ-5015 Digital Camera
When you take a picture, camera shows memory card error
These cameras are on the list of the ccd problems.
Here is a link to the site you may need. Canon will repair it for free if it is the ccd problem. Note that they will pay for shipping both ways as well if it is the ccd problem. Call them on the toll free number.
Canon Repair Service Center
Aug 31, 2009 | Canon PowerShot A75 Digital Camera
Fe170
You can add memory to your camera by purchasing an xd memory card.
Compatible cards
xD-Picture Card (16MB – 1GB)
There are two ways to record the pictures you take with this camera.
Recording pictures to the internal memory
• Pictures are recorded to the internal memory, and when the number of storable still
pictures reaches 0, you must connect the camera to a computer to download the
pictures, and then erase the pictures from the internal memory.
Using an xD-Picture Card (optional)
• Pictures are recorded to the card when inserted in the camera. When the card is
full, you download the pictures to a computer, and then either erase the pictures
from the card or use a new card.
• Pictures are not recorded to the internal memory when a card is inserted in the
camera. Pictures in the internal memory can be copied to the card using the
[BACKUP] function.
g“BACKUP Copying pictures in the internal memory to the card” (P.25)
“The card” (P.60)
Number of storable still pictures and recording length of movies
Still pictures
Movie
• If you use a non-Olympus card or a card used for another application, such as for
a computer, the message [CARD ERROR] is displayed. To use this card with this
camera, use the [FORMAT] function to format the card.
g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
Additional shooting tips and information
Increasing the number of pictures that can be taken
IMAGE QUALITY Image size
Internal memory Card (128 MB)
SHQ 2816 × 2112 2 25
HQ 2816 × 2112 6 76
SQ1 2048 × 1536 8 108
SQ2 640 × 480 60 726
Remaining recording time
HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
Dec 15, 2007 | Olympus FE-170 Digital Camera
Olympus SP-560 UZ Digital Camera Logo
27 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
