Question about Stamina Products Stamina Seated Inversion Therapy System 55-1541
Missing parts
Need an arm parts for model# 55-1527
    Top Expert:
  • Stamina Prod... Master
  • 12,223 Answers
Go to www.fitnessrepairparts.com and get it.
God bless you
Posted on Jan 09, 2013
The pilot arm on one burner is missing the small nipple that the arm rest on to ignite the burner. where can I find this part
In your internet browser type in the make and model of your unit along with "replacement parts". That will bring up several site for you to choose from.
Feb 23, 2016 | Kitchen Ranges
I would like to find out how I can order a replacement arm rest
depending on what chair you have the cheapest option is to try and get a generic replacement, search eBay for "wheelchair arm rest" they start from around 10 UK pounds or you might be able to find one from the same make and model.
if not then you need to search the web for the make and model of chair you have followed by "parts arm rest" so if you have a pride jazzy 1121 you would search google for "pride jazzy 1121 parts arm rest" that should point you to a replacment, if no joy there another option is to contact the makers, again search for maker to find contact info, or look for a dealer that sells the make of chair you have.
if this helps please click "yes" to let others know.
Oct 06, 2014 | Health & Beauty
My Hp colorlaserjet 37ooDN is showing the error : 59.C0 Pl. HELP
59.C0 Error Displayed on Control Panel Remove all the print cartridges from the printer so the right swing guide will be visible and check for the parts described in the photos below.
If the right side swing guide does not go all the way back, the 59.C0 alienation error will be displayed on the control panel. A plastic part on the swing guide could be missing.
See photo below where the three circles are on the right side of the printer.
Figure 1: Right swing arm assembly
37001See photo for details of the part. Call-out 1 in the photo below shows the parts in place, while Call-out 2 shows the missing part. (The part looks like an upside-down t.)
Figure 2: Missing part causing 59.C0 error
370021 - Part in place
2 - Part missing
Another cause for a 59.C0 error can be the black sliding lock is broken, out of place, or missing the spring. (See figure below) This can cause 59.C0 errors or 10.92.XX errors.
Figure 3: Right swing frame assembly
37003Replace the swing guide. Please look for the missing part in the printer so it will not cause other issues from movement to other parts of the printer.
If the part in the call-out is present, close the door slowly and observe the right side swing arm. It should close uniformally with the left side swing arm. If not, arrange for service on the printer and replace the right swing arm.
Jun 20, 2011 | HP LaserJet 3700dn Printer
I have a Frigidaire dishwasher model # GLD3450RDS0 and the upper spray arm has come off. I have the arm but it will not go back in place. Am I missing a washer or something to secure the arm? how do I...
You will need to get replacment parts...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Mar 16, 2011 | Frigidaire Professional Series 24 in....
Top rack of dishwasher not getting clean
The most common problem with the top rack not getting clean, is either the middle spray arm is broken and not turning (if equipped) or on some model the pop up spray arm is either clogged with debris and not turning or the pop up part is broken. Make sure to check the spray arm under the top rack, if your has one, to make sure the feed tube is attached all the way from the side to the spray arm part. If part is missing or broken, as this is often the case, you will need to determine which parts are either missing or broken, and replace those parts. If the pop up part is missing or broken, this piece comes usually with the bottom spray arm in an assembly. Your owners manual should be able to direct you further.
Good luck.
Aug 11, 2010 | Dishwashers
The top spray arm of my Frigidare model FBD4315LFC0 Aqua Surge dishwasher fell off. Their appears to be a missing part. I've been searching online for a schematic and can't find one thorough enough to...
Hello there:
hey sorry i keep getting disconnected i will be back on really soon i need to find out what is going on i hope these things that i have discussed with you is helping you out the parts are not as hard as they look once you getthenew part it will have theinstallation instructions ok
Best regards michael
Dec 27, 2009 | Frigidaire 24 in. FDB435RFR Built-in...
The arm of my belt tensioner seems to be missing a part. Where the belt touches the arm there is nothing to hold belt on. Am I missing a part? and can I buy it without buying the whole Belt tensioner?
Is the belt loose? It sounds like you're missing the pulley. Pulleys are usually available from Autozone or Napa (usually one bolt through the center to secure it to the arm).
Jul 01, 2009 | 1997 Buick LeSabre
Technics sl-ql 15 linear tracking T/Table
Parts are discontinued for these models. You need what's called a P-Mount cartridge screw. Try the following company:
www.lpgear.com
- DAVIS
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
May 30, 2008 | Technics SL-BD22 Turntable
KitchenAid KUDR01TJ - Top Sprayer came off
Sounds like something is broken. Have you tried the Bosh web site??? get the full model from the d'washer and type that in. the spigot that attach's the arm locks in or is part of the arm on most makes and models
Oct 22, 2007 | KitchenAid KUDR01TJ Dishwasher
Stamina Products Stamina Seated Inversion Therapy System 55-1541 Logo
75 people viewed this question
Top Stamina Products Exercise & Fitness Experts
Tom Chichester
Bill Boyd
Are you a Stamina Products Exercise and Fitnes Expert? Answer questions, earn points and help others
