Question about Video Game Consoles & Games
Ksafone not connect now...GK 125: Call channel not available,please contact provider
  • golap Apr 03, 2013
    not good
    not good
Unable to make calls in KSAFONE dialer
call problem with ksafone
Feb 20, 2012 | Cell Phones
I would like to buy and convert a Gallien Krueger 800RB bass head from 110Vac to 240Vac operation. Do the new ones have multi tap primary windings at the transformers that can be converted to accept...
GK does have a version that runs under 240Vac, but it may not be available in the US. I would check with GK directly. Also, an option would be to use a tramsformer for this unit. These are available for around $50 or so for the power requirements of the GK unit. This would allow you to use the amp at either 240 or 110 without the need to change anything inside which would void any warranty.
Dan
Nov 02, 2010 | GallienKrueger Gallien Krueger 800rb
Error code 32004
Error Code: 32004 Please check the following:
  1. Satellite Internet often causes this Error Code. You must have a cable or DSL internet connection. Other connection types, such as dial-up and satellite, are typically not compatible. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  2. Ours servers may be trying to handle an unusually high amount of traffic (especially if a new Wii update is available). Please wait a few hours and try the connection again later.
  3. Does your internet service provider (ISP) require that you log in whenever you wish to use the internet? If so, your ISP may not be compatible with the Wii console. Please contact your ISP for additional information.
If you are still unable to connect, and have waited a few hours, please try the following:
How are you attempting to connect your Wii console online?
    Wireless Router:
  1. Adjust the Wii's manual settings. Click here for more information.
  2. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
  3. If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
  4. Try temporarily disabling your router's firewall.* Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
  5. If you are still receiving this error code, please click here for assistance.
    Nintendo Wi-Fi USB Connector
  1. Does your PC have any security programs (firewall, anti-virus, anti-spyware, anti-adware, etc.) installed? If you are using the Nintendo Wi-Fi USB Connector, and have a software firewall or other computer security program installed on your computer, there may be additional steps you must complete to allow a successful connection.
      "Trusted" Applications:
      If your firewall or PC security program keeps a list of trusted applications (also known as a "trusted zone"), the following programs are installed with the Nintendo Wi-Fi USB Connector, and require internet communications. If prompted by your firewall or PC security program, add these to the list of trusted applications. This information may also apply to certain computer security applications, such as anti-virus, anti-spyware, etc.:
      • Nintendo Wi-Fi Connector USB (NintendoWFCReg.exe)
      • Setup.exe (when installing the USB Connector)
      • SoftAPInstDrv.bin
      • mdriver.exe
  2. If you are using a router, you may need to temporarily disable the router's firewall to allow the Wii console to connect online and receive a system update. Once the update is received, you can turn the firewall back on. For information on locating and disabling your router's firewall, please consult the router's manual or contact the manufacturer of the router.
  3. If you are still receiving this error code, please click here for assistance.
*While Nintendo provides this information for our consumers' use, it is up to each consumer to determine what security needs they have for their own networks, and to decide how best to configure their network settings to meet those needs.
May 15, 2010 | Nintendo Wii Console
Trying to connect my wii to internet but getting error code 32007 how can i fix
Error Code: 32007 There was a problem downloading the latest Wii update.
  1. Our servers may be down temporarily or experiencing a high amount of network traffic, especially after a new update has become available. Wait a few hours and try again. If you are still receiving this error after waiting, check the next steps.
  2. Satellite Internet often causes this Error Code. You must have a cable or DSL internet connection. Other connection types, such as dial-up and satellite, are typically not compatible. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
    Wireless Router:
  1. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
  2. If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
  3. Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
May 09, 2010 | Nintendo Wii Console
Getting error code 209600 while trying to download of wii shop channel
Error Code: 209600 Errors within this range usually indicate that the console timed out when attempting to communicate with Nintendo's servers.
The Nintendo Wi-Fi Connection servers could be experiencing a high amount of traffic. Please try your connection again later.
If you have waited several hours and are still unable to connect, there could be an issue with your connection. Please review the folliwing information:
    Wireless Router:
  1. Make sure you are using a "broadband" internet connection, such as high speed cable or DSL. Slower connection types, such as dial-up, may not work properly with the Wii console. If you are unsure what type of connection you have, please contact your Internet Service Provider (ISP) for more information.
  3. Make sure that any other interfering devices, such as microwaves and cordless phones, are turned off. Wireless keyboards and mice may also cause interference.
  4. If this error occurs regularly, it is may be a connection problem related to the firewall settings of your wireless router. It may be necessary to disable wireless security on the router. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). For detailed information on where to locate your router's firewall settings, please consult the owner's manual for your router, or contact the router 's manufacturer. (More about firewalls)
  5. Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
Feb 14, 2010 | Nintendo Wii Console
Am hooking up our Wii to our wireless inter-net, got an error code of 32oo7? Was up.
From Nintendo.com:
Error Code: 32007
  1. Our servers may be experiencing a high amount of traffic with a particul update, especially after a new update has become available. Wait a few hours and try again. If you are still receiving this error after waiting, check the next steps.
  3. Ours servers may be trying to handle an unusually high amount of traffic (especially if a new Wii update is available). Please wait a few hours and try the connection again later.
  4. Does your internet service provider (ISP) require that you log in whenever you wish to use the internet? If so, your ISP may not be compatible with the Wii console. Please contact your ISP for additional information.
    Wireless Router:
  4. If you are still receiving this error code, please click here for assistance.
      • SoftAPInstDrv.bin
      • mdriver.exe
    • "Trusted" Applications:
  3. If you are still receiving this error code, please click here for more assistance from Nintendo.
Nov 20, 2009 | Nintendo Wii Console
Trying to run wii systems update through the new BT home hub connections fine but I get an error code of 32004 can you help. Many thanks
Error Code: 32004Please check the following:
    Wireless Router:
Nov 12, 2009 | Nintendo Wii Console
Unable to get cable channels past channel 33.
Your problem is likely not your TV. It's due to the signal being provided by your cable company. I suggest that you contact the cable service provider which you are using and advise them of the problem.
Mar 18, 2017 | Spectra KT2313 Combo
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
