Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Compressor is running but nothing is staying cold or frozen
Trying to find the location of the defrost timer i think it might be stuck on
  • Anonymous Mar 13, 2014
    The defrost timer may be stuck because the turbo fan motor is not running
  • 700 Answers
Its by the thermostat control. but that does noit sound like the problem. i wotuld take and clean the condenser coil thats underneith the unit real good with a shop vac and a long brush first.
Posted on Jan 21, 2009
My Kenmore refrigerator was working fine until one day it suddenly stopped becoming cold. All the food in the freezer felt watery and not frozen. Whats going on?
is the compressor running? can u hear it? the defrost timer may have gone out and stopped on defrost? do u see or hear the fan going? u can manually turn it off defrost by inserting a small philips screwdriver into the tiny hole or slot under the defrost timer in the fridge. and turn it clockwise till u hear it click this will turn the defrost cycle off and u should then hear the motor and fan come on? this will give another 8 hours before it gets stuck agin andf u have to go in and turn it off agin till u replace the timer or cold control thermosttat
Mar 08, 2015 | Kenmore Refrigerators
Hotpoint CTX21 ELA
Check and lobe the fans! The evaporation coil fan could be stuck, worn out or blocked. That fan is the cold air circulator and if it doesn't work, nothing will get cold! Also check the condenser fan usually located next to the compressor to blow room temp air across the condensing coil and across the defrost drain water pan. It's the hardest working fan and really takes the worst beating with dust, pet hair and heat.
Aug 21, 2014 | GE Refrigerators
Evaporater coil was frozen. Thawed out. Fan is running. Refrigerator was warm. Restarted, refrigerator warm. Freezer to cold frosting. Dampner to refrigerator not staying open.
My first guess is defrost timer, is stuck in defrost, if you can find it, turn it, and if the compressor and fans turn on, you got your answer.
Jun 30, 2011 | GE GBS22HCR Bottom Freezer Refrigerator
Pluged in not running
most of the time these are either stuck in defrost or cold control is bad and sometimes the overload on compressor is bad...the relay can be bad or even the compressor.....BUT, check cold control and see if its stuck in defrost..no model given , but locate defrost timer...if a manual type..you can advance it out of defrost. if it comes back on..order new timer...if not it..remove cold control and make bypass on terminals to see if it comes on.., is , order new cold control,,...UNPLUG before doing anything
Jan 28, 2011 | Kenmore Refrigerators
Fridge not cooling
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 10, 2009 | Refrigerators
IMy freezer is not getting cold enough anymore
We need to check to see if your freezer is defrosting properly. I am pretty sure your refrigerator has a defrost timer located inside the fresh food compartment behind the control panel. Unplug the refrigerator and remove the rear panel inside the freezer to have a good look at the evaporator. If frozen over defrost with a hair dryer. Then let me know so we can test the defrost heater and thermostat. Your model shows a defrost timer and that is the most likely reason if you find the freezer evaporator coils frozen over. See if you can locate the timer first and turn the timer slowly clockwise until compressor stops. Wait 25 minutes and the timer should turn the compressor back on. If it does not the the timer will need replaced. Let me know what you find, Thanks, Sea Breeze
Jul 22, 2009 | Refrigerators
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
Freezer staying frozen fridge not cooling
HI,
thanks,
May 09, 2009 | Kenmore 73503 Stainless Steel Bottom...
Compressor runs less frequently freezer warms between cycles
any further question let me know.
thanks,,
Mar 29, 2009 | GE Refrigerators
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
