Question about iPhone Apps
Ksafone, GK 125: Call channel not available,please contact provider
  • golap Apr 03, 2013
    very good
Ksafone not working
Posted on Apr 03, 2013
    very good
Why won't Dynex DX-RCO1A-12 pick up all the channels I should be seeing when I do autoscan..I use a local cable service
You may be required to have a cable box depending on your provider to get higher channels. Contact your service provider for assistance.
Jul 30, 2014 | Dynex Televison & Video
Unable to make calls in KSAFONE dialer
call problem with ksafone
Feb 20, 2012 | Cell Phones
All of a sudden at least 5 channels are very snowy with white dots dancing all over the screen.
Based on the information provided, it seems that the issue is with the channel broadcasting. As the issue is happening only with the 5 channels, the issue can be resolved by reprogramming the channels. You can check if the TV is having the option to fine tune the channels. If the option is not available, then check if the Auto Program option is available to re-program all the channels in the TV. This should resolve the issue.
Please feel free to get back to us if you require any further assistance.
Thanks for contacting FixYa.
Jul 28, 2011 | Televison & Video
How i load ksafone
TRY HERE 4 MANAUAL...............http://www.ksafone.com/home.php.
        dt
May 05, 2011 | Computers & Internet
I would like to buy and convert a Gallien Krueger 800RB bass head from 110Vac to 240Vac operation. Do the new ones have multi tap primary windings at the transformers that can be converted to accept...
GK does have a version that runs under 240Vac, but it may not be available in the US. I would check with GK directly. Also, an option would be to use a tramsformer for this unit. These are available for around $50 or so for the power requirements of the GK unit. This would allow you to use the amp at either 240 or 110 without the need to change anything inside which would void any warranty.
Dan
Nov 02, 2010 | GallienKrueger Gallien Krueger 800rb
I have a DVR-520H (Pioneer) and can´t record programs from my DECO (Pace DC550D) with hight channels. A last channel available is 125. Could you help me? Regards
Tell the PIONEER to "rescan" the channels, and be sure to scan for "digital" channels, so see if channels above 125 can be detected.
Sep 20, 2010 | Computers & Internet
Ilo tv shows no tv signal, I believe that the channels are deleted but don't know how to add the channels back
Here is how to try and get them back if they are available.
On the original TV remote do the following-
1. Press the MENU button
2. Use the channel down button to select channel set
3. Select channel add/delete
4. Press volume up
5. Select channel you want to add by using the channel up/down buttons on remote.
6. When you get to the channel you want use the Volume up button and the color of the channel number should become either blue or green if it is added and it will be red if it is deleted.
7. Repeat until you have added all the channels you feel you are missing.
8. Press MENU button to exit.
If the channels are still available this should get them to return. If not contact you cable provider to see if they have moved some of their channels recently or check their web site for the current channel line up.
Good Luck and please rate this solution....
Jan 08, 2010 | iLO IWT3206 TV
Trying to run wii systems update through the new BT home hub connections fine but I get an error code of 32004 can you help. Many thanks
Error Code: 32004Please check the following:
  1. Satellite Internet often causes this Error Code. You must have a cable or DSL internet connection. Other connection types, such as dial-up and satellite, are typically not compatible. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  2. Ours servers may be trying to handle an unusually high amount of traffic (especially if a new Wii update is available). Please wait a few hours and try the connection again later.
  3. Does your internet service provider (ISP) require that you log in whenever you wish to use the internet? If so, your ISP may not be compatible with the Wii console. Please contact your ISP for additional information.
If you are still unable to connect, and have waited a few hours, please try the following:
How are you attempting to connect your Wii console online?
    Wireless Router:
  1. Adjust the Wii's manual settings. Click here for more information.
  2. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
  3. If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
  4. Try temporarily disabling your router's firewall.* Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
Nov 12, 2009 | Nintendo Wii Console
I want to download ksafone &skype dailer
go to www.getjar.com and specify your phone make and model. Then download skype. better still download either nimbuzz or fring. these are two IMs that let you log into all the IMs with just one login after the initial setup. www.fring.com and getjar. Nokia is a Symbian phone.
Aug 05, 2009 | Nokia N95 Cellular Phone
Unable to get cable channels past channel 33.
Your problem is likely not your TV. It's due to the signal being provided by your cable company. I suggest that you contact the cable service provider which you are using and advise them of the problem.
Mar 18, 2017 | Spectra KT2313 Combo
iPhone Apps Logo
49 people viewed this question
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
