Question about Kenmore Oasis HE 27082 Top Load Washer
Machine leaks when i use hot water repairman said that the detergent despencer had a hole, but hasn't been able to get a replacement. where can i get one and how much will it cost.
  • 54 Answers
If you get the model #.. you can goto sears.com.. under parts you should be able to find what you are looking for.. good luck..
Posted on Jan 22, 2009
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Dec 01, 2014 | Whirlpool Washing Machines
Why does my washing machine leak water from the detergent tray?
Check the water pressure of your house. If it is above about 75 psi, it will cause the problem you describe.
If you house pressure is fine, then either your water inlet valve on the wash machine is opening up too much during fill, or the dispenser itself is defective.
If your wash machine is still under warranty and your house pressure is fine, then have a repairman take a look at it.
Oct 19, 2014 | Washing Machines
My figidaire pauses after two or three minuets
Hello.
what you need to do to solve the problem of the washer is to troubleshoot below are step by step solution on how to solve the problem.
If your washing machine is out of whack, check for these easy fixes
before you spend money and time on a repairman.
1 Make sure the cord is plugged in and that the breaker hasn't tripped.
2 Reset the overload switch - according to the manufacturer's directions - if the machine won't turn on but the breaker hasn't tripped. (Make sure you take some of the clothes out before you run it again or you'll have the same problem.)
3 Check the hot water faucet if the water isn't warm. Also clean the filter screens and make sure that your hot-water heater isn't out of hot water.
4 Make sure the faucets are on, the filters are clean and that the hoses aren't kinked if the washer is filling too slowly.
5 Clear any obstructions in the hose if the clothes are too wet at the end of a cycle. Also, be sure the washer is spinning; if it isn't, remove some of the clothes and redistribute the load. Reset the overload switch. Tighten the drive belt if this doesn't fix the problem.
6 Check the hoses for damage if you are seeing water leaks on the floor.
7 Put a nylon stocking on your hand and feel around the inside of the washer if you are finding snagged or torn clothing. Sand rough spots with fine sandpaper.
Thanks.
Nov 13, 2011 | Frigidaire Washing Machines
Why would the machine leak out the detergent drawer when filling?
When the machine starts to wash water passes into the detergent dispenser and carries the detergent into the drum, if the detergent outlet is blocked, or resticted, this will cause the water to leak out of the dispenser.
Check the dispenser to see if an accumulated crust of powder is clogging the outlet holes, most dispensers are removable for cleaning, check your machine instructions for details.
Dec 13, 2010 | Whirlpool GHW9400 Front Load Washer
Water leaks from front of machine
dealng with a leak of this nature, it could be anything from a tear in the door boot (rubber peice between door and tub), a pin hole in the water pump or hoses, or a bad tub seal. Ideally you need to take the top off of the machine and run it to determine where exactly the water is coming from. One other thing to check, if you are using a detergent that suds up too much, a front load washing machine will leak around the door seal... they are designed for non-sudsing detergent.
Oct 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Asko 1805 dishwasher detergent door does not despense the detergent during the wash cycle. At the conclusion of the dishwasher cycle the door is still closed. How do you repair?
First make sure that nothing is blocking it.. when you load the dishwasher...next make sure your dishwasher cycle is NOT on rince and hold ( water spraying on a plate symbol) as this cycle will not open the despence door..
last you can remove the screws in the door check the vax motor and or check if you are getting power to the despencer ( no power replace control)
power to vax motor replace despencer motor
Hope it helps if Not let me know more about you problem..I can help
Sep 05, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Water spilling out of the detergent compartment
see if it is plugged up the hose might have fallen off
Mar 24, 2008 | Kenmore 43142 Front Load Washer
Maytag front load washer leaking water from detergent dispenser
The other end of the dispenser to outer drum hose only connects to the outer drum and if you remove the top cover of the machine, you will see it clearly. You can unclamp the hose from the bottom of the dispenser and feel inside the hose for any obstruction. Do not remove the hose from the outer drum. Pour some hot water down the hose and squeeze the hose from top to bottom to remove build up of detergent and softener on the inside walls of the hose.
Oct 28, 2007 | Maytag MAH6500 Neptune Front Loading...
Water in soap holder after washing.
my washer is about 1 year old. It started leaving water in all the the compartments,soap,bleach and softner. I tried everything also. Nothing seemed to work. I finally took the hoses off the back of the machine, and the cold water hose screen was clogged up going into the machine. I cleaned all the screens and haven't had that problem again. I think there wasn't enough water pressure to flush out the containers. I dont think its gravity or suction, its water pressure. unless you get a blast of water into these compartments, there will always be water left in these containers.
Oct 27, 2007 | LG WM-2277HW Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
37 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
