Question about Polaroid izone 550W Digital Camera
Camera remains on, with green light
I tried to charge the camera on my apple computer, yet when I unplugged the camera, the green "on" button remained lit up. The camera will not turn on or off and when I try to charge it on my PC, it says the device USB is unsupported. I've tried unplugging and plugging back into the computer several times but this light will not go off and the camera will not turn on. Thank you
  • Anonymous Jan 09, 2008
    i have the izone 550,i took 4 pics and the camera froze! green ligt stays on with last pic on screen. it will not shut off,& and no matter what button i push,nothing happens.
  • Anonymous Mar 16, 2009
    My reset button didn't do a thing. Maybe putting it into a regular computer might work? Idk. . . . but my reset button didn't do a thing
Yes same thing happened here..............you must reset the camera and it worked....................
Posted on Jul 28, 2008
I think i got a fix!!! tyere is a small opening next to the white toggle button,between >> arrows and below the /set .be careful and push a small object like the end of a tiny paper clip etc... this will reset the camera!!this worked!
Posted on Jan 09, 2008
SOURCE:
Green light on my power supply stays lit after unplugging
Usually the light will time out after the capacitor has drained. Your machine is getting a bit old , your PSU may be the problem. If you plug it in and push the on/off button and it blinks, fans spin and shuts down, it's most likely the PSU. Look for a in-line fuse on the Motherboard, if blown, replace. Look at the motherboard closely for damaged components, capacitors, etc.
Jan 27, 2013 | HP Pavilion A820n (PP165AA) PC Desktop
Hello, My Iphone is completely dead. The battery went down and I was about 2 months without using it. Now I'm trying to unlock it but the Itunes doesn't recognize it. The screen is black with no battery....
First, plug the iphone into the wall with your usb cable and power adaptor. Then hold down the sleep/wake button (button on top left) and the home button (bottom middle button). Keep holding those two buttons until you see the Apple logo. This should turn it back on and then charge it. If not, Genius Bar.
Mar 10, 2011 | Apple iPhone Smartphone
Ipod shuffle cannot hear music through headphones
Is it really a Head phone issue? lets find out that first.
If your headphones don't work as expected or not at all, connect the headphones to another audio source, such as your computer's speaker jack or another audio device that has a 3.5 mm stereo headphone jack, and test them. If your headphones are under warranty and still don't work, you can order replacement iPod headphones - Link - https://selfsolve.apple.com/GetWarranty.do;jsessionid=1B9ED1B556F0978A6C914A52711E59AA
And about the yellow and green LEDs
The yellow LED shows when the player is charging and a blinking green LED indicates you've paused the player.
At the back is another LED, the 'Battery Status' button, just below the toggle switch; when pressed, it flashes to give you a general idea of how much battery charge remains... green indicates a full charge... yellow, a low charge... red, very low charge... and no glow means its given up its ghost.
Hope this helps :-))
Dec 24, 2009 | Apple iPod shuffle MP3 Player
Dell 924 all in one printer. Failure to switch off.
Take out the power cable and keep it unplugged for 30 minutes.reboot the computer as well. Plug back and turn it back on. Should be as good as new.
Hope it helped
Keshy
Nov 24, 2008 | Dell 924 All-in-One InkJet Printer
My iPod shuffle will not charge
If iPod shuffle won’t turn on or respond
â If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
â Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
battery may need to be recharged.
â Turn iPod shuffle off, wait five seconds, and then turn it on again.
â You may need to restore iPod shuffle software. See “Updating and Restoring
iPod shuffle Software” on page 26.
Jun 25, 2008 | Apple iPod shuffle MP3 Player
Someone disconnected my apple iPod nano when the screen said do not disconnect What do i do to fix it ???
First try and re-set it. Hold down the play button and select or center button at the same time for about 10 seconds. The apple logo should appear. try turning it on again. I should work, if not plug it into your computer and let it charge for an hour until the charging sign comes on. Then unplug it and try turning it on again.
Feb 11, 2008 | Apple iPod nano
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Fuji F460 no power
Mainboard component failure at a guess or the new battery is not up to scratch- try taking the battery back for a new one as it is a recent purchase. If you can do that and still in trouble contact Fiji for a reapair estimate.
Aug 29, 2007 | Fuji FinePix F460 Digital Camera
Nikon coolpix2100 not turning on
what does the manual say about the Green LED? Take a look through this list http://www.fixya.com/support/p438-nikon_coolpix_2100_digital_camera/solutions
May 20, 2007 | Nikon Coolpix 2100 Digital Camera
Sansa e200 won't turn on
The same thing happened to mine. I tried to charge it and the blue light remained on. After an hour or so of trying to charge I disconnected it and pressed the on button and held it for 30 seconds and the light went off and I could turn it on. I then charged it and it appears to be working.
Feb 12, 2007 | SanDisk Sansa e200 MP3 Player
Polaroid izone 550W Digital Camera Logo
110 people viewed this question
Top Polaroid Cameras Experts
Ekse
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
