Question about Car Audio & Video
Kenwood KA-880 SD stuck in protection mode. I can't get any response from it. Any help is appreciated!
4 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: i got a Kenwood KDC-MP438U and its stuck on
Protected mode means that there is a speaker wire that is grounding out on the chassis, another wire or another wire. Check all the wire connections to make sure there is no loose wire that may be getting grounded out. After it's insulated properly and reconnected, hit the reset and you'll be back in business. k
Posted on Jun 07, 2009
smarthome2
  • 1114 Answers
SOURCE: kenwood kdc-438u stuck in protect mode what do i
Disconnect all speaker wires at the receiver and turn it back on. If it does not go into protection, your receiver is ok. Re connect speakers one at a time and test until your receiver goes into protection, then trace the speaker wire to the speaker for cuts or shorts. If you have a multimeter, switch it to ohms and check the speaker for a dead short, you may have a blown speaker. Hope this helps.
Posted on Sep 27, 2009
  • 12 Answers
SOURCE: kenwood kdc-mp208 stuck in
Protect indicates that there is a short or a grounding problem usually within the speakers2_bing.gif or the speaker wiring. Locate and press the reset button (pinhole). If protect comes back then disconnect all speakers, reset and connect them back one at a time until protect shows up again. This will help you find out where the unwanted DC signal is coming from. If protect shows up when all speakers are disconnected, then it may need service.
Posted on Apr 13, 2010
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
Mar 09, 2012 | Audio Players & Recorders
My Kenwood KDC-MP142 in protect mode. is there a reset button??
My kenwood is stuck completely in protect mode. I ve everything listed and it wont come out of it. So should i assume the unit has gone bad?
Oct 20, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
How to connect a kenwood ka- 9100 to a pioneer vsx-d608
You don't say, what role the Kenwood is supposed to play but I'll assume you want to slave the Kenwood (and its speakers) to the Pioneer.
The VSX-D608 doesn't have multi-channel pre-outs so you wouldn't have local control of the volume at the Pioneer.
http://www.auctiva.com/hostedimages/showimage.aspx?gid=108365&ppid=1122&image=404270323&images=404269872,404269931,404269984,404270049,404270137,404270323&formats=0,0,0,0,0,0&format=0
The KA could be a subwoofer amp as the Pioneer has a pre-out for that.
Outs to Ins. "Power In" on the KA would be for an external volume-controlled source. Otherwise, use one of its non-Phono inputs.
http://tubehacker.com/sale_item.php?item_id=31
May 29, 2011 | Kenwood Audio Players & Recorders
Describe your kenwood manual "ka
Hi, Yes it is safe to leave this connection unhooked. The system control is what the stereo uses to remote control a cassette deck,cd,turntable etc... using the amplifier separately should be o.k. I hope this helps, good luck and thanks for choosing FixYa-Prodzilla
Apr 20, 2011 | Audio Players & Recorders
Stuck in protection mode tried everything voltage good wires good ground good open/close button dosen,t help me at all love amp please help
everything you've tryed is useless(with respect) because amp has shorted output transistors one or more and amp is in protection mode to protect your amp from further damage.take it to repair shop or try to locate blown transistor yourself.good luck
Dec 10, 2010 | Kenwood KAC-X401M Car Audio Amplifier
KENWOOD KA-99 INTEGRATED AMPLIFIER MANUAL
Hi...
Does it look like this?
http://www.hifiengine.com/manuals/kenwood/ka-9x.shtml
Mar 27, 2010 | Kenwood Audio Players & Recorders
Kenwood KA-127 P-off response
This unit is likely to be in "protect" mode. This means that a problem has been detected it the final stage of the amplifier section and the speakers are disabled to prevent damage to either the speakers of the amp. This can be casued by a poor solder connection or defective components inside the amp. Without taking internal measurements, I can not say for sure. Expect a parts cost in the $25-$40 range for this repair. Add in the local labor rate for the total repair cost.
Dan
Nov 30, 2008 | Audio Players & Recorders
First disconnect the subwoofer wires from the amp, turn the car off and back on...is the amp on? If so your subs are shorting it out, either from a frayed wire, or blown subs.
If it is still in protection mode, check the fuses in the side of the amp.
Mar 21, 2008 | Kenwood KAC-7251 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
