Question about Kenwood Car Audio & Video
Parking off light on - Kenwood Car Audio & Video
Ground the park switch wire
Posted on Jan 27, 2013
Problem with parking back lights on my school bus I changed all the fuses and nothing my headlights work reverse lights work
Do the front park lights work? The front and rear park lights should be on the same circuit. If no park lights operational, possible switch or power/ground issue. If only rear park lights not working, suspect burned out bulbs/wiring problem to rear lights
Jan 28, 2016 | Cars & Trucks
Why does the parking brake light stay on in my 2006 mira i alrady checked the brake fluid and hand brake system but problem is stil there kindly advice
Parking Brake Warning Light - RepairPal
repairpal.com/parking-brake-warning-light
  • As long as there are no problems detected in the parking brake system, the parking brake light will stay on until the parking brake is completely released.
Oct 08, 2015 | Cars & Trucks
Why won't my Buick Rainier parking light shut off?
What year is it ? Parking light or Parking LIGHTS
It's probably the park lamp relay in the rear fuse box , contacts stuck together ! The body control module turns on the relay after receiving a input from the headlamp switch !
The rear fuse box is located beneath the left rear seat !
30
PARK LP Relay
F PARK Fuse, LR PARK Fuse, RR PARK Fuse, TR PARK Fuse
Mar 24, 2015 | Buick Rainier Cars & Trucks
No parking lights in back
parking, yes, tail ,park.
(the correct name is park toy calls them tail, tell me how a tail lamp works in front of car, this name is from 1920cars , that only had 1 or 2 tail lights. (fun history that, with funny names)
if actually park lamps. 1st click of head light? switch?
there are over 20 park lamps in car, inside and out.
side markeres, front park lamps
all dimmable lamps inside are park too. all dead>?
then the park relay is bad (tail/park) or fuse. blown.
Dec 31, 2013 | 2001 Toyota Sienna
NO FRONT PARKING LIGHTS WHEN HEAD LIGHTS ON
Could be as simple as the park light fuse is blown.
Jan 19, 2013 | 1995 Jeep Grand Cherokee
I have a 2004 Ford Taurus whose parking lights will not turn off. Sometimes they just go off eventually, sometimes the battery has to die in order for them to turn off. How do I fix this?
Sounds like the light switch is not always switching off. Try getting at the back of the switch and figure out which wire goes to the park lights (probably one of the smaller wires, you can possibly identify the colour of the wire by removing the tail light cover and seeing which wire goes to the park light globe). Once you identify the wire switch the lights off (I assume the rogue park lights stay on) disconnect the wire. If the park lights go off, the fault almost certainly lies with the light switch. If the rogue park lights remain on then power is getting to the park light wires after the switch. You could try to find where the park light wires are touching live wires ( a difficult job) or cut the old wires off at the switch and the park lights and run new wires from the switch to the park lights.
LPG
Sep 10, 2012 | 2004 Ford Taurus
Dodge ram 1500- when car is in park, the "park lights" dont work.
The parking lights would not normally come on unless you turn them on with the headlight switch. The daytime running lights would come on in drive and go off in park.
If you can't turn the parking lights on with the headlight switch, you would check the fuse, the relay if equipped, and the headlight switch.
Aug 25, 2012 | Dodge Cars & Trucks
Why does the parking break light stay on in my 97 Olds Cutlas Supreme. I have checked the level of the break fluid and it is full. I did have new break lines put in last year. I did have to slam on my...
Apply the parking brake with the vehicle parked, engine turned off and transmission in Park. Release the parking brake completely, then apply it again, and ensure that it is fully released. Turn the ignition on, check to see if the Parking brake warning light is on. If it is NOT on, apply the parking brake and check to see if the warning light comes on. If the light come ON wihen the Parking brake is applied,.....fully release the parking brake and check if the warning light goes OFF. If it does NOT go off, then an adjustment is needed at the parking brake switch.
Jan 09, 2011 | 1992 Oldsmobile Cutlass Supreme
No parking lights on my 1993 Jeep Cherokee
Recap of my problem:
no parking lights, have headlights, light switch seems to have sweet spot that turns on both head lights and parking lights.
Solution is:
Blown fuse on 15, it works the radio, parking lights, dome lights.
Dec 21, 2008 | 1993 Jeep Cherokee Country
93 Grand Cherokee no rear park lights
2000 grand cherokee no rear park light when the park light come on no brake
Oct 31, 2008 | 1993 Jeep Grand Cherokee
Car Audio & Video Logo
16 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
