Question about Fossil JR9413 Watch for Men
Won't run, it it battery operated? - Fossil JR9413 Watch for Men
  • 1 more comment
  • dasjostrom
    dasjostrom Jan 12, 2013
    This was a good answer, but I found that if you take the watch to a Fossil Store, they will change it for $10.
  • Les Dickinson
    Les Dickinson Jan 12, 2013
    it doesent av to be a fossil dealer any jewlers will do it, if you feel confident you can doit yourself it's not very hard to do
  • Les Dickinson
    sent you video please rate me if helps you gud luk
  • Fossil Master
  • 18,402 Answers
Yes it is battery operated,sudjest you get the battery changed at local jewelers.
Posted on Jan 10, 2013
Watch won't work after changing battery
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs..
Apr 20, 2013 | Watches
My Sportline won't zero the steps
find your watch off this link below click on it and download the manual
http://www.sportline.com/products/heart-rate-monitors.html
Sep 20, 2012 | Watches
Stop screen flashing on nike trax fury
Nike Triax Fury 100 Super
Yes you need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Nov 29, 2011 | Nike Triax Watches
Won't run anymore where can we get it fixed?
it's only a problem in the battery. you can replace on any watch service centers.
Jul 17, 2011 | Armitron Watches
What type of battery does the Fossil Ch2473 use? I called Fossil and they could not help me, instead they insisted I pay them $15 to replace the battery and wait 2-4 weeks for shipping. However, I...
The vast majority of Fossil analog wristwatches take either a #377 or #379 watch battery. The #379, being slightly smaller, is somewhat more commonly found in women's watches than in men's watches, but I have seen both types used in men's and women's watches alike. However, the Fossil CH2473 includes chronograph functions, which means that you can have multiple motors inside the watch running simultaneously. As a result, it's possible that this watch will require a different / bigger bigger. However, if it's not one of these batteries, or even if it takes a 3-volt lithium battery instead of a 1.5 volt watch battery, it will still be something pretty mundane.
In general, common batteries like the type I expect you'll find inside your watch are commonly found at many drug stores, jewelry store counters at places like Walmart and Target, and even at some dollar stores. Be aware that cheap dollar store batteries are usually alkaline, not silver oxide, versions of the same size battery. Alkaline batteries may work perfectly well in many watches, but they have a somewhat different energy performance curve over time, and, in general, they won't last quite as long as a comparable silver oxide battery. In addition, for reasons I've never been able to figure out, some of the Fossil watches that I've serviced would not function with an alkaline battery--but would work fine when I put in a silver oxide battery of the same size and voltage. I have not been able to see a pattern to predict when this will and will not occur. Lithium batteries, whether "brand name" or generic, should have the same performance curve.
If you do open up your watch to change the battery and don't recognize the battery type/code on your battery, don't give up. Watch batteries have different numbering schemes, depending on the manufacturer. Here's a link to a cross-reference chart that will help you "translate" one code into another. I would suggest starting by looking at the #377 line to see if one of those cross-reference codes matches what you have. However, you may need to look around the chart to get an exact match:
http://www.watchbatteries.com/custom.aspx,,id,,75
As a final thought, the backs of some Fossil watches are very snugly fitted to their cases. You can generally get them off without too much of a problem, but there's a good chance you may need a jeweler's press to get them to snap back on properly. I've noticed this most with round watch backs; I generally haven't needed a press to close oblong or tonneau-shaped Fossil watches (or some round watches, too). A jeweler's press spreads the pressure evenly around the edges of the watch back and watch case, preventing damaging pressure on the watch crystal, watch movement, and watch back. Clamping the watch in a regular vise to try to press on the back runs a high risk of damaging your watch, and I do not recommend trying that, no matter how frustrated you get. It's much safer (and cheaper, overall) to tip someone with a vise a couple of dollars to close up your watch for you.
May 15, 2011 | Fossil CH2473 Watch for Men
I am needing to find out what kind or size battery The Fossil Blue AM-3574 takes and where I can purchase them.
These batteries are commonly found at many drug stores, jewelry store counters at places like Walmart and Target, and even at some dollar stores. Be aware that cheap dollar store batteries are usually alkaline, not silver oxide, versions of the same size battery. Alkaline batteries may work perfectly well in many watches, but they have a somewhat different energy performance curve over time, and, in general, they won't last quite as long as a comparable silver oxide battery. In addition, for reasons I've never been able to figure out, some of the Fossil watches that I've serviced would not function with an alkaline battery--but would work fine when I put in a silver oxide battery of the same size and voltage. I have not been able to see a pattern to predict when this will and will not occur.
May 12, 2011 | Fossil Blue watch #AM3574 Watch for Men
Need to know what battery goes in the fossil blue AM-3860?
Hello:
The battery number will be imprinted on the dead battery (for that watch it's most likely 379), however, I wouldn't recommend replacing a battery on a Fossil yourself. They are notorious for their back being incredibly difficult to remove and put back on and if you're not a professional, you will most likely break the crystal in the process. If it's a screw-back (and you can tell because it will have six rectangular shaped notches around the edge of the back) you won't be able to get it off unless you have a case wrench and a case vise. Take it to a jeweler and have them change it for you. Screw-back Style Case
May 12, 2011 | Fossil Watches
My battery is running dead . Can I have it replaced ?
Yes, the battery for this watch can be replaced. Timex estimates that the battery should last 2-3 years, but that assumes an "average" use of the Indiglo backlight. If you never use the backlight or audible alarms, your batteries would have lasted longer; heavy use of both would have run the battery down more quickly.
If you want to replace the watch battery yourself, you'll need a very fine philips or flathead screwdriver, the new battery, and a bit of patience. It would also be helpful to have a pair of tweezers, but that's not absolutely necessary. If you carefully look on the back of your watch, Timex usually lists the battery type so that you can buy a replacement battery without first opening the watch. If you can't figure out what the numbers mean, take it to a jewelry counter at Target or Walmart, and they should be able to help you decipher it. I don't know which battery this specific watch takes, but many Timex watches use a #1620 or #2016 3v battery. Look for a number like that on your watch back.
To open up the back of the watch, open the strap so that you have good access to the back. If you have a steel band, you might need to slip out one of the adjustment pins to separate the band into halves. Yes, you might be able to take the back off without this step, but it makes it a lot easier.
Place the watch face down onto a soft surface. I like to use a dark towel, so that if I drop one one of the tiny screws you'll be dealing with in a minute, they won't bounce and you can easily find them again.
Use your screwdriver to loose the back of the watch, one screw at a time. I find it very helpful to loosen a screw, then use the tweezers to pick it up out of the hole. These guys are tough to grab with your fingers! Put the screw in a safe place, then carefully remove the back of the watch. A little black neoprene gasket may be stuck to the back or be floating around--don't lose that!
You should be able to see where the battery is kept. On most Timex watches, there's a metal shield covering the watch and completing the power circuit. Using your screwdriver, gently pry the tabs of this shield away from the watch movement, one tab at a time. Try very hard not to snap off any of the little plastic anchors. On a Casio watch I recently serviced, I had to remove the movement from the watch to get at these little tabs; I don't remember ever having to do that with a Timex.
Once the shield is loose or removed, the battery should slide right out. Replace the battery, and gently snap down the metal shield. Turn the watch over to check whether it's working again. If it's not, you may have to push a little "reset" pin on the watch movement to clear the registries. The back of the metal shield usually has instructions on where that little pin is located. If the watch is already working, you won't need to do this.
Closing up the watch is the reverse of what you did to get it open. Make sure the neoprene gasket is back in place--that's what's keeping sweat and water out of the watch--and carefully set the cover back in place. Tighten the screws in an "X" pattern--i.e., top left, then bottom right, then bottom left, then top right. I get all the screws loosely screwed in before tightening them down in earnest. This watch has a plastic case, so you want to tighten the screws snugly, but not over-tighten them so that they strip out the screw hole.
May 10, 2011 | Timex Ironman 30 Lap 53952 Wrist Watch
Replace battery for PULSAR Y911. how ro start it?
To restart the watch, you have to short the battery with a pin that sits under a sticker on the back of the watch. The sticker is supposed to explain that. You can usually do it with a pair of sharp scissors or tweezers. Without "jumpstarting" the watch, just installing a new battery won't start the watch. (I don't know why.)
Dec 04, 2009 | Pulsar Watches
Fossil JR9413 Watch for Men Logo
66 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
