Question about Clarity Lands Phones
Clarity reset phone memory - Clarity Lands Phones
How do I pair a Unitron udirect hearing aid with a Clarity BT 914 cordless phone
contact the hearing aid manufacturers website . tech support
Apr 01, 2015 | Clarity Lands Phones
Where can I find manual for Clarity JV35 phone
http://shop.clarityproducts.com/pdf/userguides/JV-35_LARGE_PRINT_User_Guide.pdf
Jan 10, 2013 | Clarity Ameriphone JV-35 (97252)
How do I delete a speed dial number
Lift the head set. Press PROG button twice. Then press MEMORY then the speed dial number. Hang up. Done. Or..Lift the head set, press PROG, enter a phone number you'd like to set to speed dial, press PROG, MEMORY, the speed dial number (1,2,3,4 etc), then hang up..
Jun 19, 2011 | Clarity Ameriphone JV35
Clarity C210 single line trimline phone - ho do
you can change it on the settings... goodluck...
Jun 06, 2010 | Clarity C210 Corded Phone
I have sony cyber shot 5.1 megapixel camera, and images are not shot clearly there is always a blur image. Please show me the setting of image resolution.
this s bcoz of the image setting...bcoz there s two options one s landscape and portait..if u select landscape more memory will be used and the image clarity will be very gud...and if u choose the other the image clarity will be little bit low...so u jus check the image settings...if each photo holds a memory of 2mb...then the photos clarity will be very gud...if the image memory s of few kbs then the image clarity will be less!!!!
Jul 27, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Need the Programming sequence for the "memory" button on the Clarity W300
Wow. Teach a man to fish or just give him the fish?
Here. Try both. Handset up, press Program, dial number, Press Program, Press button.
Or, here's a link to the manual http://clarityproducts.com/pdf/userguides/51299.601_Manual.pdf about page 17 has the instructions.
Carl
Jul 13, 2009 | Clarity W300 Corded Phone
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
Rec. problem regarding
If I virus attacked your player (none has, I'm pretty certain) you could reset it. More probably your firmware or memory is defective and the only solution is to exchange it.
Oct 08, 2008 | SanDisk Sansa m250 MP3 Player
Lands Phones Logo
23 people viewed this question
Top Clarity Lands Phones Experts
Gil Shultz
Are you a Clarity Lands Phone Expert? Answer questions, earn points and help others
