Question about Samsung Refrigerators
Samsung RSG5DURS compressor not starting
20-12-12 Unit was showing -20C Freezer and +3 Fridge but actually not cooling. When switched off,then back on, then showing +6 Freezer and +14 Fridge. Xmas shopping spoilt. 04-01-13 Samsung replace PCB and Inverter circuit boards,plus cable and connection unit to compressor (except for the Relay Protector item part number 4TM 319SFBYY-82 IFM8K written on existiong unit or possibly ends with BK190 as per buyspares.co.uk??) Compressor still not starting. Claim to be unrepairable??? Internal wiring fault?? Unit is 3 years old, immaculate as new condition in appearance. My findings: When the unit is swithed on the compressor seems to trip a relay on the PCB therefore not allowing to start. Multi meter shows 240V power to compressor terminal connector at all 3 cables?? Compressor not to gound after multimeter test. The Relay Protector which is attached to the conection unit on the side of compressor possibly faulty? It rattles, multimeter shows closed circuit, has 2 wires attached,brown cable live 240 V. This unit does not connect to the common terminal of compressor at present, so not sure if this relay is complete or missing a bridge to the common terminal of the compressor? Anyone have any ideas? A wiring diagram would be very helpful if anyone has. Should I bridge the 2 wires from the relay to see if starts? Could the compressor be jammed, tripping the relay before starting? how can you check? Samsung only offer a partial refund towards the cost of replacent so I really need to fix this as it's now been almost 3 weeks without a fridge freezer, family of 5. Am hoping to get a replacment Relay Protector via the Samsung Technician to try. Anyone give any advice on above please Thanks Jeff
3 Suggested Answers
  • 27 Answers
SOURCE: kenmore fridge start relay wiring
there is no need to shroten the lengths of the wires, u can directly connect it
Posted on Mar 10, 2009
  • 531 Answers
SOURCE: Refer will not get cold.
my advice to you call service
Posted on Apr 02, 2009
Refrig won't cool on either freezer or refrig side. Confirmed manual settings & allowed 24 hrs for cooling. Is there a reset switch somewhere other than manual switches inside refrig?
check that the compressor is working by feeling for motor vibrations at the compressor, hot compressor unit or hot fins or back wall of the fridge
if there is not heat then the compressor is not working
call a technician as it could be a start/run capacitor failed or compressor seized
get a quote as some compressor replacements cost as much as a new fridge
check that the utility power is getting to the fridge/freezer
Jul 10, 2016 | Refrigerators
Freezer fine, fridge not cooling
This sounds like a small Freon leak. It could come from cleaning the coils, or movement by the compressor. A technician with a gas tester (locator) can find any small leaks and repair that section. The cost is not excessive and a new unit is over $1000, so consider the options.
Mar 10, 2014 | GE GTS22WCP Top Freezer Refrigerator
Fridge freezer probs
From the sound of it I would looking at the evaporator fan in the freezer. This is what circulates air and actually cools the refrigerator as well as the freezer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 21, 2012 | Maytag Refrigerators
Samsung refrige error code OF OF
OF OF means the fridge is in Demo mode and the compressor is turned off; this mode is used in the store so the unit can be displayed with actually cooling. Press FREEZER and POWER FREEZE simultaneously until the OF OF message disappears to put the unit back into normal home operation.
Oct 03, 2011 | Samsung RSG257AARS (241 cu ft) Side by...
My Samsung Freezer isnt working but the fridge is fine
without checking equipment you can only assume things that may go wrong...1st..try fully defrosting complete unit,clean all vent/drain holes then switch back on and let unit do its thing for 24 hours.then check temperatures are minus 18-20c for freezer and plus 2-5c for fridge (approx)unless you have electrical meters to check, this is just about all you can do..
Feb 19, 2010 | Samsung RS2630SH Side by Side Refrigerator
Maytag Performa PTB2153GR making a clicking noise and food is thawing in freezer, fridge not staying cold
check no ice around pump unit. then try manual defrost both.no hot water. clean filters/drain holes.dry as best you can then switch on.
use thermometer to check temp -20c in freezer
Feb 07, 2010 | Freezers
Fridge is not cool enough 12 degrees C. Freezer is -3 degrees
The cooling air outlet is clogged or blocked. Cool air is not entering the fridge section as indicated by the low temperature in the freezer section. It shows that the compressor is working fine and the system is good. If your unit has a brushless DC fan motor that circulates air to the fridge section, it may not be working properly or not working at all. You have to replace it.
Nov 08, 2009 | Refrigerators
Refrigerators Logo
202 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
