Question about Ovens
Can't Locate the 3 letter suffix for Magtag model number cwe9000
My Magtag oven Model cwe9000 needs new door hinges. I was told that I need the 3 letters that follow cwe9000 to order the correct parts. Where can I find these 3 letters on the stove? I previously ordered hinges for this model and they turned out to be too small. The parts store told me that I need the three letters to get the correct parts.
Hope someone can help,
Thanks,
Ed
  • edbyrnejr Jan 23, 2009
    I found what I needed. Thanks much !!
    Ed
    President:
  • 2,651 Answers
Wether its under the maintop, perhaps on th elecg of the unit itself, or even on top corner on backside of unit, there should be a "identification plate,listing both model and serial number , and yes i just looked up with just teh few numbers you have, and there are a fewe types, its gotto be there somewhere
Posted on Jan 21, 2009
Need to remove the door, but my hinge doesn't look like the illustration in the manual
Open door alittle push down and pull out and up to remove door.. You may have to wiggle it a bit.
Hopes this helps Mike
May 23, 2015 | Thermador Ovens
What replacement parts should I order to keep my Kenmore oven door from just dropping down when it is opened?
If the hinge is not broken "Check the Springs".
They sometimes come off at one end or can be broken.
There are 2 one on each hinge. They are strong so be VERY careful.
As I remember they have a color code according to how strong that are according to the weight of the oven door.
The surest way is to get the MODEL NUMBER from the tag on your oven. The parts store will be able to look up the proper replacement.
I may be able to tell you more with a model number for Identification, the oven is likely a Whirlpool Product made for Kenmore. Let me know if you are in New York City area.
Hope this helps.
May 19, 2015 | Kenmore 47783 Electric Single Oven
My JenAir oven door doesn't close fully
most likely you have bad door hinges if the door doesn't close correctly,i don't know if you know this but alot of parts are no loner available for this model,it must be old,the only thing you can get for the door is the hinges and that's it,you'll need the rest of the model number to get the right hinges you're missing the last two letters,you can go here put your model number in to look up parts.
https://www.searspartsdirect.com/model-number/JMW8527CAB/1266/0125300.html
go to door and look at part 16 the hinge,hope this helps you out,when you open the door,if it sags down lower to the ground the hinges are bad,when open it should be at a 90 degree angle
Feb 01, 2018 | Jenn-Air JMW8527C Electric Double Oven
The door to my Neff oven is not closing so heat is escaping from the top - please help
You need new hinges use linkhttp://www.neff-eshop.com/eshop/neff/gb/prodlg.htm?Maktx=b1644&eshoptype=A
click on the spares listing for your model (you will need the full Enr from the oven rating plate) and order the hinges (always replace as a pair). Hinges are on page 3 parts list in position 0319 and 0320 (these are not the parts numbers, you need to highlight these positions numbers on the breakdown from your specific model to get the correct part number (six digit part number) You may find that although the position number are different for the left and right the actual part numbers are the same. You can add the items to the basket and order directly from Neff.Hope this helps
Sep 02, 2011 | Neff B1644 Electric Single Oven
My fridigdare oven door won't close I have order new hinges for it but they sent me a motor for it will this fix it?
eh? a motor no that will not fix the issue contact them back and tell them you want the hinges the motor is for the door lock actually what is the make and the model number of your oven and I can see if I can locate the correct part number for your unit I await your reply and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation Thanks Rick
May 04, 2011 | Ovens
Oven door falls open and will not close tight on my Jenn-air Single oven Model #SVE47100w
The hinges and receivers would need to be replaced on this. The hinges are part number 71003351 you need 2, they go inside the door, so the door would need disassembled.
The receivers (hinge receptacles)are part number 71002206 you need 2 also, these go on the side of the oven. You will need to pull the oven out a few inches to gain access to these
Jul 24, 2010 | Jenn-Air Electric Single Oven
Oven door closure
I had the same problem, the door will come off by opening it partially and lifting it up off the hinge brackets. Be careful, because the brackets are spring loaded and will snap shut when the door is removed. You will find a hinge pin with a spring clip at the bottom of the hinge. It's likely that the spring clip has come off of one of the hinges and the pin fell out. You can find the drawings and part number(s) on the "partsdirect" website using your model number, and even order them there.
Jun 27, 2008 | Ovens
Ovens Logo
124 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
