Protector/push power comes on when powering up sony home theater. checked wires for shorts and cleaned air vent . what else can I do
Can't get protecter/push power off display
    Genius:
  • Audio Player... Master
  • 1,054 Answers
Usually means there is a short in the amp section. Depending on the model, this can only be fixed by replacing the amp ic or the amp pcb.
Posted on Jan 10, 2013
SOURCE: push power protector showing up in sony dvd home theater system
Always be the audio amplifier IC damaged
Posted on Jun 24, 2010
bobhifi
  • 635 Answers
SOURCE: Have a SONY DAV DZ370
Push power protect is an indication of an output failure ( Amplifier ). The Home theater system is asking you to switch off the power to prevent further damage. This mode is called protection mode and you will need professional help sort it out.
Posted on Aug 11, 2011
I brought the unit to an authorized Sony repair depot and they concluded that all the power transistors were fried. They replaced the system board under warranty (at no charge) and the system has functioned perfectly since. Thanks for your help. -Steve.
Posted on Oct 29, 2008
welcomejee
  • 10594 Answers
SOURCE: I have Home Theater Sony DAV- DZ151Kb. Display
Push power protect message appears when home theater got problem in amplifier output section and any output amplifier chip becomes bad, receiver set protection mode and refuse to power up to avoid further damage in circuit board.
It is very hard for novice to troubleshoot what output chip is defective out of six amplifier output ICs in unit, check by professional is needed to solve this issue.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Jan 14, 2011
Testimonial: "Thanks for the support, it really is a very good recommendation I will check if you are getting voltage to the integrated and review the external components. "
dunnbiker
  • 8546 Answers
SOURCE: sometimes, when I power my
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Mar 30, 2011
DAZ 310 push power protector problem
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Aug 14, 2011 | Sony DAV-DX255 System
My home theatre dvd system (dav-fz900kw) showing as push power, protector.
Jul 29, 2011 | Sony Audio Players & Recorders
It display 'PUSH POWER/PROTECTOR
Jul 12, 2011 | Sony DAV-DZ720 Theater System
Push power protector
Jul 05, 2011 | Sony DAV-HDX500 System
Power protector light is on
Jul 03, 2011 | Sony DAV-HDX266 Theater System
Problem is that my home theatre says push power protector
Jun 25, 2011 | Sony DAVHDX265 System
My sony dav - hdx265 is not turning on - it keeps saying push power protector
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Jun 07, 2011 | Sony DAVHDX265 System
Sometimes, when I power my sony home theater system,it only displays PROTECTOR. PUSH POWER. How do I solve this problem?The system is just about six weeks old!!!
Mar 29, 2011 | Sony Audio Players & Recorders
System is not switching on.put on power protector being flashed.wherw is the location of power protector in sony home theater model DAV DZ 120
There is no 'switch' or control for Protection.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
Mar 03, 2011 | Sony Dream Home Theater System, DAV-DZ120...
231 people viewed this question
 Grubhead
Grubhead
