Question about Beko WME7247W Washing Machine
Program seems confused. The programme starts then stops, I think the computer is confused. How do I reset it ?
  • 4 Answers
I have been told that unplugging the machine for 5 minutes allows it to reset and should work again normally I hope this works for you
Posted on Mar 19, 2013
When I go to turn on my bread maker the stop/start light flashes briefly but doesn't stay on and all that comes up in the programme window is a 6. Does it need resetting somehow?
this is normal for some bread makers as some default to program 6 simply select the program you want and press start and the machine should start running its program that it is set to (my grandmother used to own one and she was a bit confused how to use it until i shown her and told her how to use it sadly it didnt get used much at all)
Feb 26, 2017 | The Kitchen Appliances - Others
Candy grand o go1682
you should clean the knob with alcohol careful there is spring and a small ball in it
Feb 09, 2014 | Washing Machines
Aquacycle 1000 will not operate the 30 minute short programme. Advice please
i think there might be some programming fault .
so set the timer again or
start pause button
after having selected the required programme press this button to start the machine the corressponding pilot light stop falshig.
to interrupt the programme which is running depress the start/ pause button the corresponding light start to flash.
to restart the programme from the point at which it was interupteed
press the start/puase bitton again.
Jan 14, 2012 | Washing Machines
I select a programme and then press the start button, the door locks but the start light flashes, and nothing happens
When the program is pressed to start then the inlet valve must open and allow the water to come to the drum. if this is not happening then check the voltage to the inlet valve, if there is no voltage then the program controller is not outputting and so defective.
If not the inlet filter/valve is clogged and will need a back flush .
Apr 11, 2011 | Washing Machines
Incanto Cappacino I was descaling my automatic machine for the 1st time. It had already started when I realised that it was not on the right setting ie. was on steam setting. I stopped the machine and...
Fill the water tank with water, open the steam knob and when the water comes out, take off the water tank and let the machine go to it stop.
Close the steam knob and put back the water tank.
Open the steam knob again to get out the air in the system.
Hope this will help you.
/Mirran
Aug 22, 2008 | Saeco Incanto Classic Espresso Machine
Its actually a WMA54 ... can I change the programmer?
You can change the control unit, but they are not cheap,and once fitted it has to be programmed in a certain sequence to make sure it recieves the correct instructions for your model.
Probably cheaper to buy a new washer and start off with a new guarantee.
Jul 28, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Machine won't start and clicks if turned on with door open
Ok, this is the fix:
No payload. Close the door. Press off, then press on. Then enter a program starting by selecting the fabric and the others as usual. Do not press start, instead press the slip button to advance the programme to the very last phase, ie drain and empty. Then press start. It will perform this operation with no load and pump out the “no water”. This part takes 5 minutes. After the 5 mins the programme will end and the machine will beep annoyingly, but the computer will be reset and you can clear the program and use the machine as normal.
Why?
I had the same problem. The stupid computer inside remembers the program whilst it’s off and unplugged. What has happened is you accidently pressed start and start again to pause it in very quick succession. This confuses the computer and it thinks that a program is in progress. This is why it wants to close the door. There is no problem with the latch (unless it is a separate problem). You have to let it play out a program to reset it, which is why you can play the very last “drain” segment.
Question.
Presumably there’s a way to reset the computer either by a secret button combo or shorting out two pins from the computer box. I don’t know. If someone knows this please tell me.
Good Luck!
Jun 07, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Beko WME7247W Washing Machine Logo
338 people viewed this question
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
