Question about Canon imageRUNNER 2200
How Do I empty the waste toner bottle on a Canon 8095?
muleskinner2
  • 270 Answers
SOURCE: having trouble replacing waste toner receptacle on Canon imageRunner 3750
If the copier indicated to empty the waste toner you will have to reset in the counter in service mode. Press the additional functions key, the 2 & 8 keys at the same time, then the additional function key again. This should get you into service mode. If not depress the reset key and try again. Once there at the top right you will see counter. Depress it then you should see a menu and depress MISC. Depress WST-TNR, then depress "C" on keypad. Counter should go to all 0's. I think that the waste toner message displays at 250,000 copies made.
Posted on Feb 12, 2008
spinal
  • 287 Answers
SOURCE: Clear Error Message
Hello Bruce,
I want to help but I am a bit confused. First of all just to provide you with additional info, there are basically three criteria that cause a need to replace the drum. One ,as in your case,is when the waste toner level reaches a level that the waste toner sensor gets covered with toner and it gives you the prompt you received. What happens is that despite the fact that in an ideal world ALL of the the image that is formed on the drum to be transferred to the paper actually does transfer completely and therefore no waste. Real world is that a small portion of the image remains on the drum and is cleaned off and deposited "into" the cavity of the drum where the waste toner receptacle resides and the waste toner sensor does as well. Once the waste toner sensor sees an excessive level it generates the prompt you received and the cpu begins to count pages (and I'll be d$%&ED if I can find the exact number) and if the drum is not replaced the device will give an error code and shut down. We will return to this topic in a moment as it is truly the source of our dillema. The second reason to replace the drum is that copy quality has turned to ****. The 1023 drum is good for........laugh with me as to how they determined this number, 26,900 copies. Not 26k. not 27k. Collective ROFL. This second criteria manifests itself in just crappy looking copies, and the end user calls for copy quality problems. The third reason is the abstract. For example a foreign object damages the drum. This includes the human hand.LOL.
So, after all that hot air I just expelled I am at a loss as to why you are still getting an error message. The new drum should have satisfied all the requirements as the waste toner sensor is happy now, and there is no counter that needs to be reset. I am sorry that I could not be of more help. I know you will cuss me for saying this, but, power off and power on and see if that helps. And we cannot eliminate the fact that the waste toner sensor that resides in the drum unit is bad. Entirely possible.AND...remember that the cpu is counting only sheets of paper not toner usage. So if the copier thinks the waste toner is full, and it does not "see" that everything is ok now, it will give you an E-19 error code after so many sheets of paper pass by. I looked in the service manual and could not find a finite number of copies after the waste toner sensor gets pissed. Then the machine goes wheels up. If I can help further(like I helped alot this time) let me know. ...........SPINAL.......
Posted on Jul 19, 2008
checkitright
  • 1362 Answers
SOURCE: Canon iR6570 waste toner
look on the right rear of the machine, there should be a door with 2-4 screws. A big white plastic container should be there, remove dump toner and seal bag, replace. Make sure it is sitting properly, it uses a weight system.
Posted on Sep 08, 2008
  • 59 Answers
SOURCE: Changing Waste Toner in CANON IR3245I
Open up the toner cover, undo the screw.
Then on the flat surface under the paper delivery tray there is a round cutout , remove this little cover to reveal a screw, undo this and slide the front cover off to the left. The waste toner bottle is now visible.
Posted on Apr 01, 2009
  • 118 Answers
SOURCE: I have Canon ir5075 and it asks me to change waste
I am not familiar with this model but usually Canon waste bottle has:
1. Check if the waste toner botlle has some clear portion near the neck, (as in IRC3200) or other part of the bottle ,even the waste toner was removed but if this portion is still clouded by toner the sensor will still detect the waste is full
2. If the situation is not like this some Canon Ir machine needs to reset waste toner counter in the service program mode even the waste toner bottle was emptied
Posted on Jun 22, 2009
I have canon ir 6570 continueing errod code e0013 solution
This is the standard Canon code for waste toner feed screw is locked. Most likely someone reset the waste toner counter and the waste toner has backed up in the auger screw. You should first empy the waste toner bottle located on the right side lower right. Remove the two screws and empty the bottle you find. You may even have to remove all the associated covers motors and circuit boards to get to the waste toner system. You will have to either clear out the auger tube, or replace the whole assembly. Check for broken parts, bound up screw, fused toner, etc. I've done this a couple of times and it's not fun. I try to make sure that I empty the bottle at every 1 million copy mark just so this doesn't happen again. Good Luck.
Sep 07, 2012 | Canon IMAGERUNNER 6570 Copier
The window on the canon ir 5055 says the waste toner recepticle is nearly full. Do I need advance notice to order a part once the recepticle is full?
Basicly, the waste toner bottle is emptied out by your service person or if you work on it, then it is you. There is a counter that will display that it is nearly full. The counter will need to be rest and the waste toner has to be looked at and emptied if needs be. The waste toner & the cleaning web have about the same life / couter life. It is not a big deal..... I've never saw a waste toner bottle over file before, but if it is not looked at or checked it may cause some problem. Good Luck
Mar 29, 2011 | Canon imageRUNNER 5570 Copier
How to remove error code e000019-0000 in canon photocopy ir3200 machine
This is a code for the waste toner bottle being too full. The copier usally displays that the waste toner is getting full and needs to be dumped. But if the customer ignores this message for too long it goes into this code. Empty the waste toner bottle behind the front door. Be sure to clean the neck of the bottle also. Reinstall the bottle and power down the copier and turn it back on. Things should be OK then.
Jan 25, 2011 | Canon imageRUNNER C3200 Copier
(6981A002AA) for imagerunner 2200, 2800, 3300 Print Server: I have also facing the same problem of Error code ...
So, you need to do next:
Because of statics and plastic bottle, the toner is collected on bottle neck, where is two circles. Even if bottle isnt full but the neck of bottle is dirty the error will occure.
Clean the neck with dry cloath, and then with some antistatic detergent, this will take care of the bottle.
But more permanent solution is to disconnect the waste toner sensor. You will see it above the waste toner bottle.Its a white connector with wires. Pull it out.
But then you need to take a very good care of amount of waste toner in bottle, because if it gets too full it could broke the waste toner gears. So that means that you must every time when you replace the drum, empty the bottle too.
May 17, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Where is the waste toner bottle located?
Remove the small cover on the lower left hand side( one screw only) and remove the waste toner bottle and emptied it ensure that bottle neck is not clouded with toner otherwise even the bottle is empty still it will detect waste toner is full .hope this will help
Jul 09, 2009 | Canon imageRUNNER 2000 Copier
Remove the waste toner cartridge from a canon imagerunner 6020. I wasn't sure and couldnt get the instructions from the 5570 to work
i think the waste toner bottle is on right side, its on the lower level of right side of the machine there is four screws, unscrew them and empyt the bottle, but u have to clear the waste toner bottle mode after. if this machine the waste toner in the front cover, just open the front cover, left the green handle and pull the waste toner,.the empty it and put it back
Jul 08, 2009 | Canon imageRUNNER 5570 Copier
Error code E000019-0000
This error indicates that the waste toner bottle is full
Jun 29, 2009 | Canon imageRUNNER 2200
I have Canon ir5075 and it asks me to change waste bottle. I empty the bottle. But do not know how to tell the printer that it is empty.
Jun 09, 2009 | Canon imageRUNNER 5000 Copier
Canon IR 5070 waste toner?
Hi
If you losen the lower right cover of your machine you will find the bottel there.
This lower right cover you will find on the right side of the machine,it is the lower small cover.There is only one skrew to losen,remove the cover and then the bottle.Empty the bottle and put it back.
Hope this will help.
Nov 24, 2008 | Office Equipment & Supplies
Cannot print canon ir2200
toner waste bottle full. Take it out and clean it well particularly around the neck...which is where the sensor is.
Aug 17, 2007 | Canon (6981A002AA) for imagerunner 2200,...
Canon imageRUNNER 2200 Logo
324 people viewed this question
old marine
old marine
