Question about Energizer Eveready Utility Lantern Uses 6V Lantern Battery
Replacing a 6 volt battery
I took the top off the lantern, but cannot get the flashlight to work
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 57 Answers
Check that the contacts where the springs on the battery make contact in the light to see if they are corroded. If so scrape or sand them off.
Posted on Jan 12, 2013
Tip
LANTERN OPERATION 1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO ?LANTERN 1+2? OR...
LANTERN OPERATION
1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO “LANTERN 1+2” OR “LANTERN I”. THE LANTERN WILL BE TURNED ON.
2. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “FLASHLIGHT’ TO TURN ON I’HE FRONT LIGHT.
3. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “OFF’ THEN BOTII LANTERN AND FLASHLIGHT WILL BE TURNED OFF.
4. PUSH THE BLINKER/SIREN/OFF (12) TO “BLINKER” AND THE FLASH LIGHT (10) WILL BLINK.
5. PUSH THE BLINKER/SIREN/OFF (12) TO “SIREN” AND THE SIREN WILL BE TURNED ON.
6. PUSH THE BLINKER/SIREN/OFF (12) TO “OFF” AND BOTH THE FLASH LIGHT (10) AND THE SIREN WILL BE TURNED OFF.
7. PULL OUT THE LANTERN (16) AND ADJUST THE LANTERN ANGLE.
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Energizer WeatherReady lantern came with batteries; worked once. Can't unscrew the top to change batteries. Possible battery corrosion? Is there a workaround fix?
Mix water and baking soda together until baking soda is dissolved.
Take a small baking pan or a bowel with a flat bottom and place the lantern in a vertical position, bottom down and slowly pour in the baking soda solution so the solution is 1/4" above the battery lid so the solution can soak into the threads of the lid. Let sit overnight. Next morning, slowly lift the lantern out of the solution without tipping it keeping it vertical, and slowly unscrew the lid over the sink. Keep in mind there will be solution inside the lantern when you first open it, so be careful not to tip it until you dry out the inside.
Aug 31, 2016 | Energizer Camping, Backpacking & Hiking
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
How to fix the switch on eveready lantern flashlight
The switch in the lantern is a press fit switch so you will destroy it when you remove it. Remove the lense and retainer ring. Remove the battery. With a pair of pliers, preferably channel lock water pump pliers crush the switch into small piece and discard. Trail Tech makes the exact water resistant switch model 040-ls-b and you can get it at Amazon or on eBay . The switch runs around $6.25 + $4.00 shipping
Jul 11, 2014 | Energizer Eveready Utility Lantern Uses 6V...
Change a 220-240v/28w/3500k light bulb
The question does not make sense since it doesn't pertain to the 6 volt dc flashlight
Jul 01, 2014 | Energizer Eveready Utility Lantern Uses 6V...
How to test a flashlight bulb
To test a flashlight bulb you use an Ohm meter which will detect a broken filament or an open circuit within the bulb. If the bulb is bad it will read "OL" if it's good it will read "00.0"
Jun 14, 2014 | Energizer Eveready Utility Lantern Uses 6V...
Rayovac 360 sportsman lantern wont work
Since batteries and bulbs are new/ok, check for a bad connection. In older version using 4 lantern batteries, open the battery compartment by unscrewing the knob on top of lantern. The lantern bottom comes off once unscrewed (of course you did this to change batteries). There is a "C" clip on the lantern center shaft; remove this by prying with screwdriver or with pliers. Carefully raise the battery contact plate and check slip-on wire connections. Clean as needed (Scotch-Brite works well) and reconnect. Squirt some contact cleaner in exposed switches, work switches back and forth. Inspect circuit board for obvious corrosion or damaged parts (this damage may "total" the lantern). Re-install plate aligning grooves with ribs. Install batteries and test.
Nov 01, 2012 | Camping, Backpacking & Hiking
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
Manual for coleman lantern model 5348-700
simple unscrew the top clockwise and you will see how the tubes are removed,
Nov 22, 2011 | Camping, Backpacking & Hiking
Energizer Eveready Utility Lantern Uses 6V Lantern Battery Logo
542 people viewed this question
Top Energizer Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
weirdtop
NicK Hale
Level 1 Expert
Are you an Energizer Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
