R.A.M. Computers Aqua Computer Aquagra FX 6800 R.2 VGA Water Block GPU + RAM w/ P&C Fittings Graphic Card Logo
Posted on Jan 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Crash with ram
First, i have ram ddr 512 slot in mainboard..it is fine..
and then, i bought 512 ram again..it's be 2x512 ram...but it is crash...
I use motherboard k8m800-m2 elite..
amd sempron 2500+..
windows xp pro..
please answer my question..
thank you..
DEKR
Level 3:
Genius:
  • Master 1,102 Answers
  • Posted on Jan 21, 2009
DEKR
Master
Level 3:
Genius:
Answers
1102
Questions
0
Helped
313065
Points
2384
You need to remove that the new ram
too much for the system
then restart
RAM upgrade on Packard Bell Columbia mainboard
you can only use as much as the motherboard are made for.
1helpful
Crashes from DDR 1 ram over 2 gigs and all usb devices.
Hello from here you can download a manual:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=544&DetailName=Feature&MenuID=24&LanID=0
It supports:
Dual channel DDR memory architecture
DDR400/333/266 DDR SDRAM
4 x 184-pin DDR SDRAM DIMM socket support up to 4 GB
One of the ram modules could have a defect
Try insert one at the time.
You must have a windows 64 bit system to use more than 3 Gb
Try to update the mainboard drivers
The one for the chipset
The ram slots probably not take modules bigger than 1 Gb
There is too types of ram Ecc and non Ecc.
Ecc ram does not work on this mainboard.
Good luck
4answers
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
2helpful
2answers
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Need to install PC2100 DDR 1GB ram upgrade
The PC2100 DDR should be fine on that board. Each slot (which there are 3) will hold 1 gb of ram each. So finding 1GB PC2100 isn't the easiest, you can find 512mb, and put 1 512 in slot 1 and 1 in slot 2, There you'll have your 1GB.
Good Luck,
Don't forget to leave a rating.
Thanks
Mark
Thankx for ur reply this is my ram config. i think it is compatible to each other. 512 MB DDR PC3200 128 MB DDR PC2700 Maximum Memory Capacity: 2097152 MB Currently Installed Memory: 640 MB Available...
I am glad to hear that your PC is running well. If you need any help again in the future we will be here. This is something we like to do, so there no having to tolerate at all. Only us helping you to understand your problem.
Nov 12, 2009 • Baby Gear
2answers
1helpful
Hi, Replacing my 256mb ram (1 slot) with 1Gb (2x512). The computer would not boot. Removing 1x512 memory the computer works fine. I put my old 256Mb back with the 512 Mb and the system only reported 256Mb....
Is the speed of the RAM the same mixing PC 133 and PC100 ram can cause problems working together. Also it sounds as if your board will only upgrade to a maximum of 512 MB total.
1helpful
2answers
I have installed 1 GB + 512 MB DDR II RAM, but it read only 1G I have just bought the Corsair 1GB RAM (DDR II 667 MHz, 6400), and installed it in the slot 1 of my motherboard, but it only read as 512 MB. (...
Nowadays, motherboards supports only a selected number of RAMs. You have to read the manual and select from the given models. I am not talking about DDR2 or 667MHz. The manual will state the manufacturer (ex. Kingston) model no (KVR667XXXXXX) etc. Only those stated in the manual will work correctly with your motherboard.
2helpful
2answers
Two 1GB 400MHz RAM's or two 1GB 333MHz RAM's??
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot
So, yes, you can put two 400MHz modules in the slots.
Top R.A.M. Computers Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a R.A.M. Computers Computer and Internet Expert? Answer questions, earn points and help others
