Question about Acer TravelMate 2300 Notebook
How many atoms are present?
A solid cube of aluminum (density 2.70 g/cm3) has a volume of
0.200 cm3. It is known that 27.0 g of aluminum contains 6.02 x
1023 atoms. How many aluminum atoms are contained in the
cube?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
(0.540 g)(6.02 1023 atoms) 27.0 g 1.20 1022 atoms
Because density equals mass per unit volume, the mass of the cube is m V (2.70 g/cm3)(0.200 cm3) 0.540 g write this relationship twice, once for the actual sample of aluminum in the problem and once for a 27.0-g sample, and then we divide the first equation by the second: m sample m 27.0 g kN sample kN27.0 g
m sample m 27.0 g
Nsample N27.0 g
To solve this problem, we will set up a ratio based on the fact that the mass of a sample of material is proportional to the number of atoms contained in the sample. This technique of solving by ratios is very powerful and should be studied and understood so that it can be applied in future problem solving. Let us express our proportionality as m kN, where m is the mass of the sample, N is the number of atoms in the sample, and k is an unknown proportionality constant. We
Notice that the unknown proportionality constant k cancels, so we do not need to know its value. We now substitute the values: 0.540 g 27.0 g Nsample 6.02 N sample 1023 atoms
Posted on Jan 21, 2009
If a aluminum has a density of 2.7 g/cm^3, what is the volume, in cubic centimeters, found in 54 grams of aluminum?
There are probably several ways to solve this, but I like setting them up in ratios.
weight (g) 2.7 54
volume(cm^3) 1 x
Multiplying both sides by x, we get 2.7 x = 54
Dividing both side by 2.7, we get x = 54/2.7
x = 20
Therefore, it is 20 centimetre cubed.
Good luck,
Paul
Feb 20, 2018 | Homework
If volume of water is 20cm3, water density is 1g/cc, what if the mass sammple
Sounds like a trick question. A "cc" is a cubic centimeter. "cm3" is technically the same thing. So if the mass is 1g/cc, then the mass of the volume is 20g.
Mar 05, 2015 | Office Equipment & Supplies
I have a scotsman CM3 with aquaarmor ice machine. There is a constant trickle of water coming from each leg. Why is the happening???
Try taking off a side or back panel and see if there is frost building up. If frost is present, it could be low on refrigerant.
If there is condensation, it could be the insulation is saturated with water allowing thermal transfer to condense water out of the air.
Feb 06, 2015 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Percent error
The difference is 7.59 - 6.7 = 0.89 in the low or minus direction.
Taking the correct value as the basis, the error is
0.89 / 7.59 x 100 = 11.73% low
This may be quoted as - 11.73% of true value
Sep 05, 2014 | Office Equipment & Supplies
Why Scotsman CM3 ice machine shows diagnostics water problem?
should you have any questions, Thanks John Tripp Appliance 911
First let's look through the different service manuals. CM3 Water level sense diagnosticsDOWNLOAD
Head Pressure Control Kit - CM3DOWNLOAD
Reduce Air in CM3 ModelsDOWNLOAD
Replacement of the CM3 controllerDOWNLOAD
Service Handbook to 2007 - CM/CM3DOWNLOAD . I am here should you have any questions, Thanks John Tripp Appliance 911
May 15, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
135g=how many ml ?
The gram (g) is a measure of mass (or quantity of substance). The mL is a unit of capacity (volume). What links them together is a physical characteristics called volumic mass or specific density (gravity).
That property depends on the substance. Some solid sunstances (aluminum) are light , others are very heavy (lead, mercury).
The reference density is that of water, which is taken to be 1.
Because of this a lot of people confuse the mass and the capacity, that is why we see questions like the one you just asked.
It has meaning only if you are talking about liquid water at a temperature of about 4 degrees Celsius. At that temperature 1 gram of liquid water ocupies a volume of 1 mL or 1 cm^3. Thus, 135 g of water occupies a volume of 135 cm^3, or 135 mL.
Mar 02, 2012 | Office Equipment & Supplies
How many grams of aluminum acetate contain 2.24 x 1022 atoms of hydrogen?
1 Look up the formula for the aluminum acetate.
2 Count the number of Hydrogen atoms per molecule: Call that nH.
3 Dividing 2.24*10^22 by nH you get the number of molecules of acetate.
4. Divide that number by Avogadro's Number to obtain the number of moles required.
5. Multiply the number of moles by the molecular mass of the aluminum acetate (look it up or use the periodic table to calculate it), you will get the mass of aluminum acetate that contains 2.24*10^22 hydrogen atoms.
Sep 14, 2011 | Texas Instruments TI-84 Plus Calculator
If one side of a cube measures x cm what is the volume of the cube
let's look at volume. Consider a volume of a cube that is x on a side. The volume of the cube is X x Xx X = X3 (with the appropriate units - meters3 or km3 or cm3 (if you cannot handle metric))
Mar 30, 2011 | Computers & Internet
Computers & Internet Logo
272 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
