Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Install drive belt 1993 yard pro tractor - Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
4 Suggested Answers
  • 376 Answers
SOURCE: i cant get the drive mower belt on my poulan pro lawn tractor!
The belt you should have bought is part # 140294 and yes, it is longer.
Posted on Jul 29, 2009
harlan301
  • 205 Answers
SOURCE: belt is slipping off pulley
your should have a tension spring on the idler pulley. that maintains the tension on the drive belt. check to make sure you have the right belt and that is not worn or stretched out. also check to make sure your variable drive assay is working
Posted on Oct 11, 2009
  • 6468 Answers
SOURCE: part number for a Poulan Pro 46Inch 22 HP Yard Tractor with Briggs and Stratton Engine PB22H46YT belt
try sears parts online
Posted on Mar 29, 2012
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
Need drive belt for a 1993 yard pro y2050 tractor
Go to MTD website and download the manual for your machine.
Dec 02, 2013 | Mtd Garden
I struck an object while mowing my yard and the tractor wont start or even crank what could the problem be?
start by disengaging the blade and putting the deck to it's highest position, prior to attempting to start the mower inspect under the mower deck making sure there is no Debee wedged interfering with the blade rotation, check your spindle's for play and inspect your mower and drive belts. once complete than give it a try. if by chance it does start but turns over you more than likely sheered the flywheel key.
Oct 10, 2013 | Poulan Pro 46Inch 22 HP Yard Tractor with...
We are needing a diagram on how to put a deck belt on a 42 inch yard machine
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a Poulan pro, 42 in, 18hp, How do i adjust or replace the drive belt?
steps:
1. elevate tractor.
2. lower blades all the way down.
3. remove battery and battery slot
4. place belt through battery slot around first pulley and then feed it through the middle two.
finally loosen the front pulley and slide new belt over the front of the last (front) pulley,
note: be sure to feed belt through all medal guides on the bottom of the tracoitr or else the belt will continue to fall off.
May 02, 2011 | Poulan Pro 46Inch 22 HP Yard Tractor with...
We have a 48" 23 hp poulan pro riding mower, our problem is the drive belt from the engine to the deck is always breaking, this is the 4th one we bought this summer. what could be the problem
More than likely, you are using a automotive belt not a "V" belt. Automotive belts are pretty tuff but can not stand up to the beating a mower takes. Go to your mower place and get the proper size "V" belt for your Poulan. Make sure it is both the proper size and a quality belt. I recommend "Gates" belts.
When you start your mower, start it with the engine at slow speed, to lessen the shock that the belts and clutches take.
Thanks for your interest in FixYa.com
Aug 16, 2010 | Poulan Pro 46Inch 22 HP Yard Tractor with...
Adjust the drive belts,
if you have the belt installed correctly, the idler pully is the only adjustment and thats automatic. i trust you have installed the correct belt.
Apr 29, 2010 | Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
87 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
