Question about Toshiba Satellite Computers & Internet
Default bios password for toshiba l355-S7905
I HAVE A TOSHIBA L355-7905 MY SON LOCKED MY BIOS BY MISTAKE HE GAVE ME THE PASSWORD BUT EVERYTIME I PUT IN THE CODE THE SCREEN GOES BLACK AND THERE WAS NO CPU ACTIVITY OR HARDRIVE ACTION HELP!!!
You should get a error code. You can buy a service on Ebay and for about 13 dolllars you would give them your code and they will give you a code to unlock it.
Posted on Jan 09, 2013
SOURCE: Hp compaq 6910p BIOS Bypass
I removed the keyboard, unplugged the bios battery, holded down the power button about 30 secs, plugged back the bios battery, assembled the computer, didn't plug the battery and instead of that just plugged the ac adaptor and the bios passwd was gone =)
Posted on Mar 12, 2010
SOURCE: toshiba notebook HDD problem
I think you may find your hard drive has failed? I suggest that you replace the hard drive with a new one. But, just to check.. remove the hard Drive from the machine... (usually acessable under the machine via a couple of screws and usually just slides out etc) Then try to "Boot" the machine from CD or floppy.. (on say ya Windows XP CD, choosing Boot from CD from PC menu) if it does.. then it IS ya HD, if not then ya may have a Motherboard fault. So do NOT change the drive.. at this juncture I would suggest ya go to a reputable PC repairer and ask for a "Quote" for the fix, and an explanation of what is/was wrong.
Posted on Aug 31, 2007
SOURCE: default bios password toshiba satellite a135-s2276
I have a Satellite A135-S2356 that had the same problem. I tried the solution from PCTServices above and it worked great.
"Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw."
Just short the two little solder pads and it worked great! I thought I would have to send it back to the manufacture but I am back in buisness. Thanks for the help.
Bryan
Posted on May 24, 2008
  • 16 Answers
what you need to do is pull both the laptop battery as well as the cmos battery. in some instances, the battery can be pulled, but on other models, i have seen the battery as an actual physical part on the motherboard or somewhere where it is not easily accessible, in which case you need to clear the cmos by using a jumper on the motherboard, since it is a laptop, they are all different. you may need to see if you can locate a copy of the motherboards schematics and go from there.
Posted on May 29, 2008
SOURCE: reset bios password
it's the 'clear cmos' jumper you need to move on the motherboard. If you move that over one pin for a moment, then back, then boot up, your p/word will be cleared.
Posted on Jul 29, 2008
What is bios password?
Ask the administrator for the password.
Dec 17, 2015 | Toshiba Satellite L355-S7811 Notebook
BIOS LOCKED
To unlock your BIOS you have to remove your BIOS battery for few minutes which is onboard, then replace the BIOS battery again on the motherboard will not only reset the BIOS password to default but will put all the BIOS settings to default. For which you will have to reconfigure your BIOS settings, but remember any wrong setting in the BIOS may damage your laptop.
Jan 18, 2014 | Computers & Internet
Forgot my bios password
PC BIOS toolkit is a password removal/decrypt and BIOS settings modification/backup/restore.
http://www.syschat.com/download120.html&act=down
CMOSPwd - CMOS password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
Using a computer with Internet access, download the files from these WEB sites and create a bootable CD disc to run them.
Jan 07, 2013 | Toshiba L355-S7905 (PSLD8U0Q3033) PC...
Toshiba satellite L355-S7812 keeps crashing
You might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below...
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Jun 30, 2012 | Toshiba Satellite L355-s7812 C2d...
BIO PASS WORD
Reset BIOS password, it can be done in two ways
Manual
Open the cover under laptop, remove the CMOS battery about 7 seconds, then plug it back. Turn on laptop, BIOS password will be lost. Perform setting date, time, etc.
Online (conditions: the laptop can desktop access)
Toshiba gives services, online flash BIOS. Download and install software ACPI Flash BIOS, according to model of laptop.
Example: Toshiba Satellite L305-SP6983R, software version: ACPI Flash BIOS version 2.20 for Satellite/Satellite Pro L300/L305/L350/L355
Nov 17, 2011 | Toshiba Satellite Laptop L655S5150
HOW DO I RESET THE BIOS PASS WORD ON A TOSHIBA LAPTOP L355
Hi if you want reset bios password ( asume you forget it) You need reset bios find reset CMOS jumper or take out battery for few sec. All settings in BIOS will be reset. Let me know if you need more help
Aug 25, 2010 | Toshiba Satellite L355-S7811 Notebook
I HAVE A TOSHIBA SATELLITE L355 S7831 AND I FORGOT MY PASSWORD TO START THE BOOT OF THE COMPUTER AND IT GIVES ME 3 GUESS' AND THEN SHUTS OFF??? WHAT ITS ASKING FOR IS A CURRENT PASSWORD?
When you installed the system, you entered a BIOS password.
There is nothing you can do to bypass that password. The only solution is to take laptop to Toshiba Certified Service Center to have password disabled.
Hope it helps
Sep 11, 2009 | Toshiba Satellite L355-S7811 Notebook
Computers & Internet Logo
153 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
