Where is the high limit switch on a york diamond 80? red light blinks 4x
    Genius:
  • 1,033 Answers
The limit switch will typically be the size of a credit card and flat looking swiych between the burners and inducer motor, there will be 2 wires attaxhed to it.
Posted on Jan 09, 2013
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: york diamond 80 heater does not fire up
Mostly likely the problem is in the pressure switch that tells the board that the blower started and it is okay to fire the burner. The pressure switch is usually a 2" or so round thing about 1" thick, it will have one or two tubes coming out of it that go to the blower or heat exchanger. Make sure that the tube is not cracked or that it has not come off at either end.
The pressure switch can be jumped out to check out if that is the problem, but you need to jump it out after the cycle has started and the switch needs to open after a cycle for the heater to refire again, so that fix would be very temporary. But it may tell you for sure what the problem is.
Posted on Nov 14, 2009
heatman101
  • 43501 Answers
SOURCE: Main blower fan is not starting on my York Diamond
Check to see if the blower motor is actually getting power to it...You will have to check for power on the heating speed terminal... and the neutral wires....you should have 120v across those two wires....
If you have power then the motor is bad...if no power then the heating relay went bad on the circuit board and you will have to replace the circuit board...
That is a common problem as those relays are often to light and wear out...
Just realize that without an electrical meter to trace things through you are really just grabbing at possibilities and not really able to correctly diagnose your problem...
heatman101
Posted on Dec 08, 2010
  • 120 Answers
SOURCE: Hi, I have a York
a limit open is saying that your furnace is over heating. a few things could be wrong. dirty filters, blocked air return or closed vents. the roll out switch,if your furnace has one , is also in this loop .it normaly will be needed to reset and is on top of the roll out sheild in the burner compartment. call a repair company if this is the problem.
Posted on Feb 03, 2011
Therinnaiguy
  • 1420 Answers
SOURCE: York Diamond 80 Furnace: blows cold air after
There may be more than 1 limit switch. Look at the wiring diagram and follow it to all switches. Or jump out the complete circuit.
Posted on Jan 21, 2010
York diamond 80 - continuous flashing red
Is there a chart on it somewhere that describes what each mode of flashing means? Most of them do. Inside the front cover,,,somewhere on the inside of the panel that covers the filter? I've never seen one of these without that diafram.
Oct 24, 2013 | Tools & Hardware - Others
York 80 furnance model P3HUB12N08001A curcuit board light blinks 4 times. What does this mean?
Check on the back of the bottom blower cover...I think it is either pressure switch or high limit...
But the codes are always listed on that bottom cover on the inside...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Jan 22, 2011 | Heating & Cooling
My central AC is a York Diamond 80 (also my furnace). Thermostat set on Cool, isn't cooling. and when i shut thermostat off, it continues to blow air. red light flashing inside unit code = Limit switch...
One of the limit switch in the furnace is tripped or went bad....
Try to find all of the reset switches and push the little red button on the top to reset them...
If that don't work you will need to take an electric meter and test each switch to see which one is bad...
heatman101
Aug 23, 2010 | Heating & Cooling
York "high Aux or spill limit switch open"
how can I fix the spill limit switch, also how do I found it
Mar 05, 2010 | York Furnace Draft Inducer Blower Fasco #...
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
Heating & Cooling Logo
558 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
