Question about Nikon COOLPIX L610 Digital Camera with Basic Accessory Kit
Nikon L610 battery door won't lock
Springs for the batteries are very strong. A minor drop of the camera combined with the high spring pressure pushing on the door broke both small plastic tabs on the door. No glue is strong enough to withstand the battery spring pressure. How can I get a new door? (or doors, because this will be an ongoing problem / design flaw)
SOURCE: Battery door broken
Yes i have fixed it. Sorry for my spell, but i try. First i kutt off the little broken plastic-bits with a knife. Demontage the four skrews in the battery flip. I take a little bit stainless string ca 0,5 mm dia and ca 20mm long. I hold this string with a handtool (tong)and put a soldering-heater on the end off the string and pusch the string troth down two times and get two holes there the two tabs have been.And after that a bend with a tong the string like an U (2x90 degrees) exaktly after the hole-with. And after that a pusch down the string in the two holes exaktly so high so the little finger on the battery-door go in. Test and try with the battery-door. And take a thinn tong and bend out the string to the left and to the right inside the kamera. Thats it. Work with care and slow and exaktly with mm-tholeranse. Good luck !!
Posted on Sep 21, 2007
SOURCE: Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Posted on Mar 26, 2008
  • 15 Answers
SOURCE: Film door will not lock closed
I suspect taht you can obtain a replacement back. The back should be removable by sqeezing together two pins on the hinge side of the back (on the inside). You should call B&H Camera in NYC (866-239-7781). They should be able to give you a price and order you one.
Posted on Nov 20, 2009
Testimonial: "I live in scotland, , but thank you for your advice regarding the pins regards"
amanagni
  • 184 Answers
SOURCE: i broke my nikon d90 battery door. searching
Dear i have a link better than for you.
in this link you could see the manual of your nikon battery door.
https://www.paypal.com/us/cgi-bin/webscr?cmd=_flow&SESSION=a7JqcrKsQQGVfav71QTTIc0JLuta7te9SDOjhDCCaISkL1Kh6V2nBJcZMaK&dispatch=50a222a57771920b6a3d7b606239e4d529b525e0b7e69bf0224adecfb0124e9b5eb2336391e7cbed125f6c5bdaf8a1cdeb9b6b1b7e42e65e
Posted on Feb 15, 2010
SOURCE: battery door replacement how to?
OK IT IS EASIER THAN IT APPEARS TO BE(DONT GET SCARED)#1 REMOVE BATTERIES AND MEMORY CARD AND STRAP(if you have one)#2REMOVE ALL THE SCREWS AROUND THE CAMERA(you will see 3 screws around the tri-pod mounting hole DONT REMOVE THE LONE SCREW THAT IS CLOSER TO THE LENS(AS IT IS NOT HOLDING ANYTHING BUT THE TRIPOD INSERT AND LEAVING IT IN WILL MAKE IT EASIER TO SNAP EVERYTYHING BACK TOGETHER.#3CARFULLY AND EVENLY PRY ON THE BODY TO REMOVE THE SCREEN SIDE.#4 NOW YOU WILL BE ABLE TO SEE THE SMALL CLIPS THAT HOLD THE LENS SIDE OF THE BODY CARFULLY SEPERATE FRONT BODY (* this will enable you to see the large head on the battery pin.) #5 WITH A THIN NEEDLE NOSE PLIERS PULL THE PIN OUT #6 LAY THE NEW COVER DOWN AS IF IT WAS CLOSED AND INSERT THE PIN BACK IN.#7 BEFORE YOU SNAP THE FRONT BOBY BACK IN BE SURE TO PUT THAT TINY RUBBER BATTERY PULL TAB BACK IN THEN CAREFULLY SNAP THE FRONT COVER INTO THE CHROME AND THEN THE BACK COVER. PUT SCREWS BACK AND YOUR DONE.
Posted on Dec 11, 2010
Nikon l610 wont turn on
If your batteries are okay (try charging them overnight) it sounds like you'll have to send the camera in for service. Call Nikon Coolpix support at 1-800-645-6687
Here is a link to the Nikon support page which has lots of good info:
https://support.nikonusa.com/app/answers/detail/a_id/238/~/nikon-support-contact-information
May 18, 2014 | Nikon Coolpix L610 Digital Camera
Camera locks up and wil not turn off
Take battery out of camera to turn off and then reinstall battery and see after fully charging battery if it will work now. Rich
Apr 08, 2014 | Nikon Inc Nikon Coolpix L610 Black
Nikon camera battery keeps losing charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 12, 2012 | Nikon Coolpix S3000 Digital Camera
Nikon s205 battery temperature high
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
Jun 07, 2012 | Nikon Coolpix S210 Digital Camera
My Nikon Coolpix L24 camera's battery compartment spring-loaded latch is operational. However, the lock appears to be missing or broken and the door won't stay shut.
I had the same problem. I found out that the rubber band that is used for celery can be wrapped twice around the camera. Works great.
Oct 27, 2011 | Cameras
My Canon Powershot SX120is camera was dropped on a high school gym floor. Since then it hasn't turned on. I think the battery connections on the little battery door are damaged, since you can tell...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 25, 2011 | Canon PowerShot SX120 IS Digital Camera
Need battery door
You may order battery covers in a choice of colors here.
Jan 01, 2009 | Nikon COOLPIX L18 Digital Camera
Nikon COOLPIX L610 Digital Camera with Basic Accessory Kit Logo
433 people viewed this question
Top Nikon Video Cameras Experts
David Payne
David Payne
 Bob Buchholz
Bob Buchholz
ray gallant
Are you a Nikon Video Camera Expert? Answer questions, earn points and help others
